EV Habits Checklist in Weekly Energy Update Email Module
The EV Habits Checklist in Weekly Energy Update (WEU) Email module can be included in Weekly Energy Update emails. This module helps to coach readers about how they can create good charging habits for their electric vehicle (EV).
The module provides two standard charging tips that can save them money and time, and then asks if they can adopt a third tip that will help to alleviate stress on the electric grid.
This module should be included in the first EV-specific Weekly Energy Update email the customer receives, and then again once every six months to remind the customer about good charging habits. The utility can configure how often the module appears in the email.
Design
This image shows an example of the EV Habits Checklist in Weekly Energy Update Emails module:
Figure 6-2 EV Habits Checklist in Weekly Energy Update Email Module
User Experience Variations
This section discusses how the module can vary.
Time-Of-Use Customers
The text of this module varies as follows when sent to customers on time-of-use rate plans.
Habit 1 Statement: The heading reads "Avoid charging during on-peak hours" and is followed by the text "Charge your EV during off-peak hours when savings are greater."
Habit 2 Statement: The heading of this habit statement remains the same, but the text reads, "No more going into the garage to plug in when off-peak hours start. With an automated schedule, you can plug in anytime, adding convenience to your routine!"
Extra Mile Statement: This header for this statement remains the same, but the text reads, "Help reduce grid strain at the start of off-peak hours, when many people begin charging their vehicles, by scheduling your charge to start a few hours later."
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Table 6-4 Configuration Options
| Configuration Option | Input Value |
Recurrence Setting Utilities can specify how often they want this module to be included in the email. Default: Module is included in the email every 6 months. |
Optional Select one of the following:
Images The images can be configured to use client-specific colors. Other than that, the image can not be changed. |
Optional Specify client branding colors. |
Text and Extra Mile Statement Utilities are encouraged to review the text and statements in this module and adjust them to ensure that they are pushing customers to charge at the times that are most beneficial to the utility. |
To see how this module fits into the overall user experience, see Design and Configuration.
