EV Why Off Peak Module
The EV Why Off-Peak module explains to the reader why it is important and beneficial to charge their EV during off-peak hours. The module explains how this behavior can save them money, make charging more convenient, and ease the strain on the grid. The module also asks them if they can go the extra mile to use clean energy to charge their EV.
Requirements
There are no module-specific requirements for this module.
Design
This is an example of the EV Why Off Peak module:
This is an example of the EV Why Off Peak module.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Table 6-11 Configuration Options
Configuration Option Input Value
Icons and Images
The images can be configured to use client-specific colors. Other than that, the image can not be changed.
Optional
Specify client branding colors.
To see how this module fits into the overall user experience, see Design and Configuration.
