Shift Nudge Module
The Shift Nudge Module is designed to educate utility customers about the environmental benefits of adjusting when they use electricity. By highlighting the impact of high-demand periods on energy generation, the module encourages customers to shift their usage to times when demand is lower and cleaner energy sources are more likely to be used.
This module helps utilities promote more sustainable energy consumption behaviors without requiring significant effort from customers. By clearly communicating when to avoid using electricity, it empowers customers to make small changes that collectively reduce strain on the grid and lower overall emissions.
For customers, the module provides simple, actionable guidance that connects everyday energy use decisions to broader environmental outcomes. This strengthens customer engagement while reinforcing the utility’s role in supporting environmental responsibility.
Design
This is an example of the module:
This image shows an example of the Shift Nudge module.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Table A-4 Configuration Options
Configuration Option Input Value
Image Colors
Colors in the images can be updated to match the utility’s color palette, if desired.
Optional
Choose one of the following:
  • Use the default colors.
  • Work with your Delivery Team to specify other colors.
Peak Hours
Specify the hours that are considered Peak Hours. For example, 4pm - 8pm on weekdays.
Required
Specify your peak hours here:
