Installation
The Oracle Utilities Network Management System-Oracle Field Service Adapter is delivered as a single file:
• $NMS_BASE/dist/install/nms-ofs.ear.base.zip (NMS-OFS adapter application).
The
nms-install-config script is used to apply adapter configuration changes and create the
nms-ofs.ear file, which can be deployed to the Oracle WebLogic Server (see
Software Configuration for configuration instructions).
To avoid performance impact on the main NMS application (cesejb.ear), it is recommended that the nms-ofs.ear not be deployed on the same managed server where the cesejb.ear is deployed; however, both managed servers need to be in the same Oracle WebLogic Server domain.
Clustered Deployment
When the Oracle Field Service Adapter is deployed on a WebLogic cluster, the SOAP and REST web service front ends are active on all cluster nodes. A WebLogic singleton service selects a single active node to perform adapter processing. Requests received on other nodes are forwarded to the active node.
Only the active node processes incoming activity, event, crew, and acknowledgement updates, maintains the NMS subscription, and performs outgoing adapter processing.
If the active node fails, one of the remaining cluster nodes becomes active automatically. The adapter initializes on the newly active node, establishes its NMS subscription, and resumes processing.
For clustered operation, deploy nms-ofs.ear to the cluster target. Deploying the application to individual managed server targets does not enable clustered operation, even when those servers belong to a cluster.
Note: Clustered deployment assumes that a software or hardware load balancer directs incoming web service requests to the available cluster nodes.
Adapter Installation Instructions for Oracle WebLogic Server
Create a Managed Server (Optional)
To simplify creation of a new managed server, you may clone an existing Oracle Utilities Network Management System managed server.
1. Log in to the WebLogic Server Administration Console.
Note: The URL for WebLogic will be http://hostname:port/console where hostname represents the DNS name or IP address of the Administration Server, and port represents the number of the port on which the Administration Server is listening for requests (port 7001 by default).
2. Click Lock & Edit.
3. In the Domain Structure tree, expand Environment, then select Servers to open the Summary of Servers page.
4. Select an Oracle Utilities Network Management System server in the Servers table and click Clone.
5. Click the link to the cloned server and edit the settings:
• On the General tab, change the Listen Port and SSL Listen Port to unique values.
Configure Data Source for the Adapters Managed Server
You may configure a new JDBC data source or add the adapter managed server as a target to an existing Oracle Utilities Network Management System read/write data source.
Note: See "Configure Database Connectivity" in the Oracle Utilities Network Management System Installation Guide for information on creating JDBC data sources.
1. In the Domain Structure tree, expand Services, then select Data Sources.
2. In the Data Sources table, click the data source name (either a new data source or an existing read/write NMS data source) to open the Settings for JDBC_Data_Source_Name page.
3. Select the Targets tab.
4. Add the adapter managed server to the list of targets. For a clustered deployment, target the data source to the adapter cluster so that it is available on every cluster node.
5. Click Save.
Deploy the Adapter
1. In the left pane of the Administration Console, select Deployments.
2. In the right pane, click Install.
3. In the Install Application Assistant, locate the nms-ofs.ear file.
4. Click Next.
5. Select Install this deployment as an application.
6. Click Next.
7. Select the server or cluster to which you want to deploy the application. For a clustered deployment, select the cluster as the deployment target.
Note: If you have not created additional Managed Servers or clusters, you will not see this assistant page.
8. Click Next.
9. Set the deployed name of the application to: nms-ofs
10. Click Next.
11. Review the configuration settings you have specified.
12. Click Finish to complete the installation.
