Services Overview
Oracle Utilities Network Management System services provide memory-based model management for RDBMS persistent electrical network model information - generally to support real-time access and performance objectives. The services maintain the memory resident data model for the real-time status of the electrical network. The memory model caches the necessary data to build the model from relational database tables. The services then solve this model (fills in the blanks, determine what is energized, grounded, looped, etc.) and optimize the result for client access. Each service generates and passes appropriate incremental model updates to isis (the Network Management System real-time publish/subscribe message bus) for publication. Interested applications subscribe to the published messages to keep the Network Management System end users up to date with current state of the model.
Startup scripts that run when the operating system boots can be used to automatically start the Oracle RDBMS, isis, and Oracle Utilities Network Management System services. How you configure and where you place these scripts is based upon startup (default) Unix "runlevel" and your platform. For Linux platforms you can generally determine your current runlevel via:
/sbin/runlevel
For Linux, startup/shutdown scripts are generally located in the /etc/init.d directory. A Unix softlink to each startup script to run for a given runlevel is generally made in the /etc/rc<run_level>.d directory. Other Unix operating systems have similar but often slightly different conventions. It is presently an exercise left to the system administrator to properly create and configure startup scripts that will properly run on startup for a given Operating System.
Oracle Utilities Network Management System Services are generally flexible and attempt to cater to the functional needs of various utility clients through the use of command line options and run-time parameters stored in the relational database. Below is a brief summary of the primary Oracle Utilities Network Management System Services. Details about available command line options and relational database parameters specific to each service can be found in
Appendix A -
Command Line Options and High Level Messages.
SMService - System Monitor Service
SMService monitors the core Oracle Utilities Network Management System service and interface processes. It reads and caches the appropriate system.dat configuration file to determine which processes to initiate and monitor. In the event that a managed process fails, SMService restarts it based on the cached configuration data from the system.dat file.
The following variations of system.dat files should be located under $NMS_HOME/etc. There should be *.template versions of these files in the $NMS_BASE/templates directory. These configuration files generally define the specific run-time executables and command line options necessary for a given Network Management System installation:
• system.dat.init - defines configuration required for initial setup.
• system.dat.model_build - defines minimum configuration required for initial model builds.
• system.dat file - defines configuration for fully operational Network Management System.
sms-start will launch SMService, which in turn will cache the $NMS_HOME/etc/system.dat file by default and then launch the remaining services, interfaces, and adapters as defined by the $NMS_HOME/etc/system.dat file. The following command sequence can be used to specify an alternate system.dat type file:
sms‑start -f ~/etc/my_system.dat
If the full path is not specified for the argument to the -f parameter, sms-start will first look in the local directory and then the $NMS_HOME/etc directory for the specified "my_system.dat" file. When the sms-start script is called without command line options, it instructs SMService to validate that all processes it is configured to manage are in fact running. The "configuration" that is used by SMService for this validation is from the previous "sms-start -f system.dat" type request. If you make changes to your "system.dat" type configuration file, you can use "sms-start -f system.dat" to get a running SMService to "adopt" the updated configuration (no need to restart SMService). You can use this technique to change command line options for SMService managed processes but be aware that SMService will NOT automatically stop/restart processes. If a process is no longer managed by SMService after configuration, you will need to manually stop that process after SMService has been configured to no longer manage it. If only command line options have changed for a running process, you will need to stop the running process (with the old command line options still active) and call sms-start (with no options) to force SMService to restart the stopped process with the newly configured command line options. This is done so that SMService does NOT have to restart to reconfigure core NMS Services. If/when SMService is restarted WebLogic EJBs must fully re-cache and this will impact active NMS end users. By allowing NMS Service/Adapter configuration changes without having to restart, SMService can reduce the impact to active NMS end users. sms-start can also be run with the -p parameter to start services in parallel. This is generally faster, but requires system.dat to be configured with appropriate start timeouts for each of the configured services.
For a configured standby environment, sms-start -warm starts a new SMService in warm mode. To activate an existing warm instance, the configured recovery procedure uses "
sms-start -f system.dat -hot". The
-warm option is a startup option; it does not change an already running active SMService back to warm mode. See
Warm Services in the
High Availability: Disaster Recovery chapter for prerequisites and the complete recovery workflow.
The smsReport tool can be used to request and monitor the SMService view of the processes it is currently managing. smsReport is a non-GUI tool used to report the state of the system by querying SMService. It is executed in either one-shot or monitor mode. One-shot mode is the default mode that queries SMService for the current state and displays it to the user on exit. However, if the system state is INITIALIZING, then smsReport automatically switches to monitor mode so as to not exit prior to initialization completing before exiting. Monitor mode is set by starting smsReport with the -monitor command line option. It serves the same function as the default one-shot mode but does not close after the system state has been reported.
To shutdown the Oracle Utilities Network Management System (gracefully) use the following script:
sms‑stop
The sms‑stop script will shutdown all of the user environments (one at a time) and then the services in reverse order to how they where defined to startup in the ~/etc/system.dat file. Using this script generally prevents certain deadlock conditions which can occur if an attempt is made to stop all user environments and system services at the same time.
SMService can be configured to monitor any service or process, even non-isis aware processes as it does for lighttpd and the tao-naming service. To configure this, you will need to define a script that supports three parameter options: status, start, and stop. In addition to the parameters, the status should return zero if the process is not running, and 1 if the process is running. See nms-lighttpd and nms-naming-service product scripts as examples. The comments in the template system.dat file will describe how to configure the non-isis processes.
DBService - Database Service
DBService provides database access for any processes attached directly to the isis message bus within the Oracle Utilities Network Manage System environment. The messaging backbone, isis, directs database queries and commands to the appropriate Oracle RDBMS server and returns results to the requesting process.
Note: A given instance of DBService allows a configurable number of queries to occur in parallel but serializes RDBMS updates. By assigning update responsibility of specific tables to specific DBService instances (by convention) parallel updates can be supported which generally increases performance and/or scalability under system load. TCDBService, MBDBService are examples of this strategy. Most major NMS Services (other than ODService) support the ability to leverage a dedicated DBService process. See the provided system.dat.template file for examples of this configuration.
ODService - Object Directory Service
ODService registers new objects as well as caches configuration and (optionally) run-time information that is likely to be requested by applications in a particular form and/or on a regular basis. This caching allows the requests to be handled very quickly without directly accessing the database. Cached information is primarily static configuration data, such as object classes, class hierarchy, symbology assignments and (optionally) device alias information.
DDService - Dynamic Data Service
DDService manages real time (dynamic) information required by the system. In addition to command line options DDService utilizes the srs_rules table for run time options.
Examples of dynamic data that DDService manages include:
• Current status of switchable devices
• Special operating conditions of devices (tags, crews, notes, etc.)
• SCADA information (analogs, digitals, quality codes)
• Operating authority (users and control zones)
DDService uses inheritance to determine which condition classes prevent device operations, and when. Condition classes that inherit from the "tag" base class always prevent device operations. Conditions that inherit from "block_if_hot" prevent operations only in energized areas, and conditions that inherit from "block_if_0" prevent operations when the condition is in status 0. "block_if_1" prevents operations when the condition is in status 1, etc. These condition statuses can be configured to change when safety documents transition to different states, such as Issued, Released, etc.
When you make changes to Oracle Utilities Network Management System control zones (control_zones and/or control_zone_structures tables), you need to tell DDService to update its internal control zone memory structures with the following UpdateDDS command:
UpdateDDS -recacheZones
When you make changes to SCADA device definitions, you can tell DDService to update itself with the following UpdateDDS command:
UpdateDDS -recacheMeasures
After a model build, recache zones and recalculate abnormal devices:
UpdateDDS -recacheAfterModelBuild
MTService - Managed Topology Service
Real-time electrical systems are in a constant state of flux of electrical flow. A single device operation could de-energize a model section, create a parallel on one or more phases, ground one or more phases, create a loop condition, or extend some other form of energization/deenergization. Since the topological state (energization, ground status, energizing feeder, feeder color, and so forth) of a device cannot be accurately determined without taking into account a large number of other devices and operating conditions, it is not possible for each application to independently determine current topological states. Instead, MTService maintains a complete topological copy of the model in memory, which it updates as devices and conditions change. It publishes topological impact updates and services topological data requests from other Network Management System applications and services.
JMService - Job Management Service
JMService is the customer trouble call analysis engine. It relies on MTService to trace device connectivity when determining probable outages in the system. Customer complaints (trouble calls) are fed into the system and JMService groups them using configurable rules to compute and publish the most likely cause of the problem. JMService also manages restoration resources (crews). In addition to command line arguments, JMService uses the srs_rules table for the majority of its run-time configuration options.
After a model build, recache control zone changes:
UpdateSRS -recacheZones
If disconnected customers have been added to the CES_DISCONNECTS table, refresh JMService:
UpdateSRS -recacheDisconnects
TCDBService - Trouble Call Database Service
This is a copy of DBService that runs specifically to improve the performance of JMService by handling database calls for JMService. This lets the main DBService manage database requests from operator activity not directly related to trouble calls.
MBService - Model Build Service
MBService is used in building a data model, which mirrors the customer's existing data model (generally extracted from a Geographic Information System such as ESRI, Intergraph, SmallWorld, or AutoCAD). When changes are made in the GIS a project-specific extractor is used to extract and transform GIS changes into a standard Network Management System format. MBService takes the standardized input, parses and integrates the resulting changes into the Oracle Utilities Network Management System electrical network model. In addition to maintaining the model database, MBService also generates map files, which are optimized for use with Network Management System graphical viewing tools.
SwService - Switching Service
SwService manages the execution of VVO, FLISR, and Load Shed sheets. The execution of these sheets has to be managed by a service as a client is not required when VVO or FLISR are in Automatic mode or when the steps in Load Shed sheet are executed automatically. Even in Manual mode, SwService handles the execution of the switching sheet and takes over the single user lock on the sheet when the request is made. Users can load the sheet while it is being processed by SwService, but will only have View-Only access to the sheet. This service is also required to properly update switching sheet steps related to two way SCADA integration; particularly the completion of SCADA tagging steps and for reporting SCADA step execution failures. This service is only required to run when the flisr, volt_var, or load_shed modules are licensed or when two way SCADA integration is required for properly updating switching sheet steps.
MBDBService - Model Build Database Service
MBDBService serves the same purpose for MBService as TCDBService does for JMService. It is a copy of DBService that runs specifically to improve the performance of MBService by handling the database calls resulting from model building.
MQDBService - MQService Gateway DBService
MQDBService provides direct access to the database for the MQSeries Gateway. This reduces competing throughput for the DBService reserved for operator interactions.
DMSService
DMSService manages real-time operations power flow calculations that allow you to view the complex voltages and currents at points and devices in the electrical network model. These calculations are performed on an electrical island basis by tracing from each energized source and collecting all the energized objects. SCADA measurements at the feeder head and at various points down the feeder are used to accurately distribute load to each load point. These services send the real-time power flow solution results, as well as information about voltage and flow violations, to various Oracle Utilities Network Management System windows for you to view.
Note: The system allows configurable numbers of processing tasks to occur in parallel, and, therefore, improve performance and avoid operator wait times. Two configuration rules drive parallel processing:
• MAX_BACKGROUND_THREADS: Sets the number of background tasks (FLM, FLISR, FLA, Real-Time Optimization) that can run in parallel. This number should be set to the number of threads/cores that are available for background processing.
• MAX_USER_THREADS: Sets the number of user tasks (Suggested Switching, Power Flow Look Ahead, Study Mode Power Flow Analysis, and Study Mode Optimization) that can occur in parallel. It is recommended that this be set to one thread per five active DMS users - with a minimum of 10 allocated.
CORBA Gateway Service
The CORBA Gateway service provides part of the interface between the Java-based NMS user applications (Web Trouble, Storm Management, Web Call Entry, ) and the other C++-based Oracle Utilities Network Management System services. The CORBA gateway allows the Java Application Servers to get published updates from services like JMService, DDService or MTService and also provides the mechanism to query these services directly on-demand. The WebLogic Java Application Servers must then take these updates and make them available for the Java (end-user) client applications.
The CORBA Gateway service uses isis to communicate with the other Oracle Utilities Network Management System services. The CORBA Gateway service requires that the TAO (The ACE ORB) CORBA Naming Service be running. TAO is configured to run on startup via the sms-start script.
Note: We now recommend that you run three copies of the CORBA gateway for each Oracle Utilities Network Management System environment.
1. The first instance is a dedicated publisher instance that takes messages published via the Oracle Utilities Network Management System services and publishes them to the Java Application Server (WebLogic).
2. The second instance is dedicated to handling Java client application requests to Oracle Utilities Network Management System services. By default, client application requests to issue SCADA controls are rejected. To allow such requests, the instance handling client application requests must be running with the '-scadacontrols' command-line option.
Examples of how to setup these corbagateway instances can be found in the $NMS_BASE/templates/system.dat.template file.
3. The third instance is a generic publisher for publishing to email, and page. This is primarily used by Service Alert.
The WebLogic Java Application Server must be configured to correctly connect to the appropriate corbagateway(s). See the Oracle Utilities Network Management System installation guide for instructions on configuring the Java Application server.
Service Alert Service
Service Alert processes updates from other services such as job/event update information, device operations, as well as receiving notifications from database triggers. These "updates" serve as the triggers for Service Alert to determine when the criteria for sending out a notification have been met. Once triggered, Service Alert gathers relevant data and sends out the desired notifications.
Include Additional Customer Information into Notifications
Service Alert Service can load additional information from the CES_CUSTOMERS database table and include it in "Outage affecting specific customer(s)" and "Outage affecting critical customer(s)" notification messages. The ‑cust_columns command-line option is used to specify a list of columns from the CES_CUSTOMERS table that should be loaded.
Format
-cust_columns [column name 1][,column name 2]...[,column name N]
where
[column name x] is the name of the column in the CES_CUSTOMERS database table
Example
-cust_columns city_state,zip_code
To include additional customer information into notification messages, you must edit the XSL documents that transform Service Alert Service generated raw XML into a user-friendly form. For example, the XSL fragment below appends city, state, and zip code information to the customer’s address.
<td>
<xsl:value-of select="concat(CUSTOMERADDRESS, ' ',
CUSTOMEREXTRA/CITY_STATE,' ',CUSTOMEREXTRA/ZIP_CODE)"/>
</td>
Adding a Service Alert XSL Stylesheet
To use a new stylesheet filename for Service Alert notifications:
1. Copy an existing stylesheet for the required notification type and delivery format, and save it with a unique filename in $NMS_CONFIG/xml. For example, copy UnplannedOutageEmail.xsl as ProjectUnplannedOutageEmail.xsl. Preserve the template that matches the notification's XML root and any required supporting templates or files, then edit the notification content.
2. Deploy the stylesheet and any required supporting files to the runtime XML directory configured by the publisher's -xmldir option. The filename registered in the database is resolved relative to this directory. Ensure the publisher can read the files.
3. Choose a TRANSFORM_ID that is unused in PUBLISHER_TRANSFORMATIONS and register the new filename. The transform filename must also be unique. For example, in SQL*Plus, replace '999' with the selected unused numeric identifier:
INSERT INTO publisher_transformations
(transform_id, transform, description)
VALUES
(999, 'ProjectUnplannedOutageEmail.xsl',
'Project unplanned outage email');
COMMIT;
4. Add the INSERT, using the selected numeric identifier in place of '999', to $NMS_CONFIG/sql/[PROJECT]_publisher.sql. Replace [PROJECT] with the project name. This preserves the registration in project configuration so it can be loaded during subsequent setup runs.
5. Ensure the publisher has loaded the new registration before sending notifications. In Service Alert Administration, use Group Manager to select the group and message type, set the appropriate notification format to ProjectUnplannedOutageEmail.xsl, and save the change. Generate a test notification and verify that the new stylesheet is used and the expected data appears.
XML Encoding Configuration
By default Service Alert Service sets encoding for the generated XML document to UTF‑8. The ‑encoding command line option allows you to specify a different encoding to be used. To avoid XSL transformation issues and ensure that the data is rendered correctly, the XML document encoding should be compatible with the character set of the data loaded from the database (check the NLS_LANG environment variable).
Format
-encoding [XML encoding name]
Example
-encoding ISO-8859-1
Include Device Attributes Information in Notifications
Service Alert Service can include device attributes in Outage, Outage affecting specific customer(s), Outage affecting critical customer(s), and Frequency of outages on a device notification messages. Active attributes maintained through the Service Alert Attribute Manager are loaded from MYC_DEVICE_ATTRIBUTES. The -devattr command-line option additionally loads device-class attribute values from the device data tables identified by the DEVICE_ATTRIBUTES configuration table.
Format
-devattr
Example
To include a device-class attribute in notifications, configure the attribute in DEVICE_ATTRIBUTES, populate its value in the corresponding device data table, and run Service Alert Service with -devattr. Loading an attribute makes it available in the raw notification XML; edit the notification's XSL stylesheet to display it.
For example, suppose a device data table contains a column named LOCATION. Its value is included as a DEVICEATTRIBUTE element under DATAAREA/DEVICEATTRIBUTELIST, with ATTRIBUTEID and ATTRIBUTENAME set to the column name LOCATION and ATTRIBUTEVALUE containing the device's location. Use the exact identifier and case present in the raw notification XML.
In the stylesheet template for the notification's root element, add the following fragment inside an HTML table. It displays the LOCATION value when the attribute is present:
<xsl:if test="DATAAREA/DEVICEATTRIBUTELIST/DEVICEATTRIBUTE[ATTRIBUTEID='LOCATION']">
<tr>
<td><b>Location: </b></td>
<td><xsl:value-of select="DATAAREA/DEVICEATTRIBUTELIST/DEVICEATTRIBUTE[ATTRIBUTEID='LOCATION']/ATTRIBUTEVALUE"/></td>
</tr>
</xsl:if>
Replace
LOCATION with the required attribute identifier. This path is relative to the notification root, such as MYC_UNPLANNED_OUTAGE in
UnplannedOutageEmail.xsl. If editing a different template context, adjust the path accordingly. To introduce a new stylesheet filename, follow
Adding a Service Alert XSL Stylesheet.
Wait Period After Device Operation
Intelligent switching devices in the electrical network (for example, Automatic Throw Over switches) can cause a single device operation to be followed by several other device operations executed automatically. Service Alert would normally generate notifications as soon as an outage matching at least one of the configured notification parameters is detected. The -devopwait command line option allows real device outage notification processing to be delayed by the specified number of seconds. Adding a delay permits the electrical network to reach a stable state so that generated notifications would have accurate information.
Format
-devopwait [wait period in seconds]
Example
-devopwait 30
Enable Crew-Related Notifications
Service Alert supports generating of notifications when outage-related crew activities occurs, such as when the crew is assigned, en-route, onsite or suspended. This support is disabled by default, but can be enabled by running Service Alert service with the -crew command line option.
Note: Enabling this option does have a negative effect on performance.
Format
-crew
