Menu Option | Description | Toolbar Icon |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See Understanding Docked Panes and Standalone Window Tools for more information on dockable and standalone windows. | -- |
Exit | Closes the SCADA Status window. | -- |
View FEP Monitor... | Opens the FEP Monitor as a tab in the docked pane. See FEP Monitor for information. | -- |
View IED Monitor... | Opens the IED Monitor as a tab in the docked pane. See IED Monitor for information. | -- |
View Point Monitor... | Opens the Point Monitor as a tab in the docked pane. See Point Monitor for information. | -- |
View Message Counts... | Opens the Message Counts as a tab in the docked pane. See Message Counts for information. | -- |
View Message Queues... | Opens the Message Queues as a tab in the docked pane. See Message Queues for information. | -- |
View Templates... | Opens a new IED Template as a tab in the docked pane. See IED Templates List for information. | -- |
View Inputs... | Display IED Inputs for the selected IED. | |
View Output... | Display IED Outputs for the selected IED. | |
View Device Links | Display device links for the selected IED. | |
View Audit Log... | Opens an Audit Log tab in the docked pane. See SCADA Audit Log for information. | -- |
View Debug Log... | Opens a Debug Log tab in the docked pane. See SCADA Debug Log for information. | -- |
Create New FEP... | Opens the FEP Details tool allowing you to create a new FEP. | |
Create New IED... | Opens the IED Details tool allowing you to create a new IED. | |
Create New IED from Template... | Creates a new IED as copy of a preconfigured template and opens the IED Details on the resulting new IED. | |
Download IED Schema... | Allows you to download the schema xsd file that defines the schema used by NMS for validating against imported IED configuration. | -- |
Export IED... | Allows you to export selected IED configuration from tree view in XML format. The default file name is IEDNAME.xml. | -- |
Import... | Allows you to import an XML file containing valid configuration. | -- |
Export FEP... | Export the selected FEP in XML format. | -- |
Export SCADA System... | Export the entire SCADA system in XML format. | -- |
Delete | Remove the selected IED. | |
Unlink IED... | Immediately disassociates the currently selected IED from the FEP and moves it to the unassociated list. | -- |
Move IED... | Invokes the Associate IED dialog box allowing you to associate the currently selected IED to one of the configured FEPs. | -- |
SCADA Status Help | Opens online help content for the SCADA Status window | -- |
Export | Export the data in the FEP Monitor table. See Exporting and Copying Table Data for details. | -- |
Exit | Closes the FEP Monitor. | -- |
FEP Details... | Display the FEP details window for the selected FEP. | |
Display IEDs for FEP... | Display the IED Monitor list filtered for IEDs on the selected FEP. |
Enable FEP | Enables the selected FEP | |
Disable FEP | Disables the selected FEP | |
Reset FEP Statistics | Resets the communication statistics for the selected FEP. | |
Reset All IED Statistics | Resets the communication statistics for all IEDs configured on the selected FEP | |
Synchronize | Resynchronizes the FEP configuration to the FEP itself. | |
Add FEP... | Creates a new FEP. | |
Remove FEP... | Removes the selected FEP component. | |
Enable Connection | Enables the selected FEP connection. | |
Disable Connection | Disables the selected FEP connection. | |
Change Active Connection | Changes the communications channel used to communicate to the FEP. Only visible if the FEP has multiple channels configured. | |
Enable Debug | Enables the logging of debug messages for the selected FEP. | -- |
Disable Debug | Disables the logging of debug messages for the selected FEP. | -- |
Line Logs... | Selecting this option invokes a browser displaying the LEC FEP line log information. Search the Configuration Assistant's Event Management Rules tab for 'Line Log Configuration' to get for details on how to configure the line log URL. |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. See Using the Sort Dialog Box. | -- |
Default | Sorts the table using the standard sort criteria. | -- |
FEP Monitor Help | Opens online help content for the FEP Monitor. | -- |
Export | Export the data in the Message Counts table. See Exporting and Copying Table Data for details. | -- |
Exit | Closes the Message Counts. | -- |
Message Counts Help | Opens online help content for the Message Counts. | -- |
Export | Export the data in the Message Queues table. See Exporting and Copying Table Data for details. | -- |
Exit | Closes the Message Queues. | -- |
Message Queues Help | Opens online help content for the Message Queues. | -- |
Exit | Closes the IED Monitor. | -- |
View Details... | Display the IED configuration details. | |
Commission... | Display the commission points for the IED. |
Display IEDs on all FEPs | Removes any filters on the IED Monitor list and displays all IED's | |
Create New IED | Opens the IED Details tool allowing you to create a new IED. | |
Create New IED from Template | Creates a new IED as copy of a preconfigured template and opens the IED Details on the resulting new IED. | |
Create New Template from IED | Creates a new template IED as copy of an existing IED and opens the Template Details on the resulting new template. | |
Delete | Deletes the selected IED. | |
Enable | Enables the selected IED. | |
Disable | Disables the selected IED. | |
Reset IED | Resets the communications links to the selected IED. | |
Force Poll IED | Initiates a read of all inputs on the selected IED. | |
Reset IED Statistics | Resets the communication statistics for the selected IED. | |
Enable Connection | Enables the selected IED connection. | |
Disable Connection | Disables the selected IED connection. | |
Change Active Connection | Changes the communications channel used to communicate to the IED. Only visible if the IED has multiple channels configured. | |
Reset Connection Statistics | Resets the communication statistics for the selected IED connection. | |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. | -- |
Default | Applies the default sort. In the product configuration, the default sort is by IED Name, IED ID, and Connection ID. | -- |
IED Monitor Help | Launches online help for IED Monitor. | -- |
Exit | Closes the FEP Monitor tab. | -- |
View | Focuses the Viewer on the selected device. |
Remove Point | Removes the point from the Point Monitor. | -- |
Default | Applies the default sort. In the product configuration, the default sort is by Point ID. | -- |
Type | Applies the sort by input type. In the product configuration, this sort is by Point ID and Type. | |
IED Name | Applies the sort by IED. In the product configuration, this sort is by Point ID and IED Name. |
Save | Saves changes made in the FEP Details tool. | |
Exit | Closes the window. | -- |
Enable FEP | Enables the selected FEP | ![]() |
Add FEP | Creates a new FEP. | ![]() |
Remove FEP | Removes the selected FEP component. | ![]() |
Add Connection | Adds a new connection to the FEP. | |
Delete Connection | Deletes the current connection. | ![]() |
Enable Connection | Enables the selected FEP connection. | ![]() |
Disable Connection | Disables the selected FEP connection. | ![]() |
Change Active Connection | Changes the communications channel used to communicate to the FEP. Only visible if the FEP has multiple channels configured. | ![]() |
FEP Details Help | Launches online help for FEP Details. | -- |
Save | Saves changes made in the IED Monitor tool. | |
Exit | Closes the IED Details. | -- |
View Inputs | Display the Input points for the selected IED. | |
View Outputs | Display the Output points for the selected IED. | |
View Device Links | Display the device measurement links for the selected IED. | |
Commission... | Display the commission points display for the selected IED. Only visible for IED Details. |
Create New IED | Creates a new IED. | |
Create IED from Template | Creates an IED as a copy of a predefined template. | |
Add I/O to IED from Template | Creates new input and output points on the current IED as a copy of a predefined template. | |
Create Template from IED | Creates a new template IED as a copy of the current IED. | |
Delete | Deletes the current IED. | |
Add Connection | Adds a new connection to the IED. | |
Delete Connection | Removes the selected connection from the IED. | |
Input Sort | Input Sort defines sorts for the input points tab. • Sort Dialog…: Invokes the Sort Dialog dialog box that allows you to custom sort the input list. • Default: Sort the input list by the default sort. The default sort is based on the protocol of the IED. • DNP3: Sort on the Information Object Address • IEC104: Sort on the address • ICCP: Sort by Transfer Set • Type: Sort by the type of the input (analog and digital). • RTI Alias: Sort by the RTI Alias of the linked NMS device. | -- |
Output Sort | Output Sort defines sorts for the output points tab. • Sort Dialog...: Invokes the Sort Dialog dialog box that allows you to custom sort the output list. • Default: Sort the output list by the default sort. The default sort is based on the protocol of the IED. • DNP3: Sort on the Information Object Address • IEC104: Sort on the address • ICCP: Sort by Transfer Set • Type: Sort by the type of the output (analog and digital). • RTI Alias: Sort by the RTI Alias of the linked NMS device. | -- |
IED Details Help | Launches online help for IED Details. | -- |
