Understanding the Feeder Load Summary
The Flex Operations Feeder Load Summary page provides a tabular list of feeders and their solution statuses, similarly to the Web Workspace Feeder Load Summary tool (see
Using the Feeder Load Summary).
The collapsible right-hand side panel includes more details not available in the main table.
Select a feeder row and open the Island Info tab in the details panel to view the sources and feeders in its power flow island. The Sources table displays the source name and device handle. The Feeders table displays the substation, feeder name, PF Mode, FLM mode, and device handle.
Select a source or feeder row and click View, or right-click the row and select View, to locate it on the Map.
Island Statistics and Solution Details
Select a feeder row to view its details in the right-hand panel. The Errors & Warnings tab includes Island Statistics for the selected source:
• PF Engine Runs / Iterations / Avg shows the number of engine runs, the total numerical iterations, and the average numerical iterations per run. The average is displayed to one decimal place and is 0.0 when there are no engine runs.
• Errors / Warnings shows the current error and warning totals for the selected source.
• Control Emulation Iterations counts post-solve control-emulation passes that require another engine run.
• SCADA Iterations counts SCADA load-allocation passes.
These counters describe power flow and load allocation, not the separate Distribution State Estimation application. There is no combined Total Iterations value.
Open the Solution Details tab to review interleaved PF Engine Run and SCADA Iteration rows. The header shows PF Engine Runs, PF Engine Iterations, Control Emulation Iterations, Tap Changes, and Control Emulations. Each run shows its numerical iteration count, tap changes, shunt changes, and DER changes.
Select Engine Iteration Details to inspect the numerical iterations within a run, including the devices with the largest voltage changes and the tap-change count. Select SCADA details, when available, to inspect device and phase allocation mismatches, including the value, measurement, scaling factor, and mismatch percentage.
Control Emulation Details appears only when the run has shunt or DER changes. Shunt details show the position change as Off or On, rather than capacitor step counts. DER details show reactive output, the reactive-power increment, average voltage, and target voltage. Tap changes remain separate from shunt and DER control emulations.
Use Back to return from a detail view to the summary.
You can open the
Feeder Load Management tab for a selected feeder and see details about forecasts for that feeder. This is similar to the Web Workspace
Feeder Load Management tool (see
Using the Feeder Load Management Window).
To view Grid
DER Details from Feeder Load Summary, select a feeder and open its load management details. Select a forecast and open its details, then select a DER on the
Distributed Generator tab and open
DER Details. For information about the display, see
Understanding the Grid DER Details View under Using the Grid
DERMS Dashboard.
