Working with DER Aggregators
The DER Aggregators tab in the DERMS DER Search tool provides access to aggregator configuration. Communication monitoring settings apply to active DER devices associated with the selected aggregator.
Configuring Communication Monitoring for an Aggregator
To configure monitoring for devices associated with an aggregator:
1. Open the DERMS DER Search tool and select the DER Aggregators tab.
2. Select the aggregator and choose Edit to open the DER Aggregator dialog box.
3. On the Details tab, locate Health Check Configuration. Set a nonzero Check Interval to enable periodic health checks, and configure the following fields:
• Offline Threshold (%): The minimum percentage of health-check results reporting Offline or Unknown within the Offline Window that qualifies a device for a communication warning. Set both the threshold and the window to values greater than zero to enable this check.
• Offline Window (HH:MM): The rolling period over which the offline percentage is evaluated, entered as hours and minutes.
• No Update Period (days): The number of days without a device status update after which a device qualifies for a communication warning. Set this value greater than zero to enable this check. Set it to zero to disable this check.
• Service Request Limit: The maximum number of active service requests allowed for this aggregator. Existing active requests count toward this limit. A value of zero prevents new automatic service requests while allowing communication warnings to be generated when monitoring is enabled.
4. Select OK to save the changes.
The offline-percentage and no-update checks can be enabled independently. If both are enabled, a device can qualify by meeting either condition. These health-check settings cannot be edited when Owner Operated is selected.
To send service requests to DACS, also configure OIC_CREATE_SR_URL on the
DERMS Configuration tool's
Parameters tab with the Oracle Integration Cloud (OIC) web service endpoint used to create service requests. If this parameter is blank, Edge DERMS does not send service-request creation messages to the external system. Alert behavior and email notifications are configured on the
Alerts tab; see
Communication Monitoring and Service-Request Alerts.
