Working with the DERMS Configuration Tool
The DERMS Configuration Tool displays common Edge DERMS configuration options. This tool is available to the DERMS Administrator user. The functions are grouped into tabs:
• Users
• Alerts
Users
The Users tab displays a list of DERMS users and user types.
Select a row in the Current Users table to populate the Available User Types and Current User Types tables, and then add or remove user types as desired. You can also add and remove users or edit user details to subscribe to DERMS event state change notifications.
Standard Roles and Customer Permission Sets
The standard DERMS role combines Grid and Edge tool permissions; an NMS-hosted deployment still needs the corresponding license for each product. The Edge DERMS role receives Edge tool grants. Flex Full Operations plus Switching includes the Grid group-management, DAM, and DAGC grants, and does not include Access Edge DERMS DER Group. Edge group access can be assigned explicitly through a customer permission set or a direct user grant.
In standalone Edge DERMS, the existing access model is retained after successful login, including configured overrides and user permissions. The DERMS User, DERMS Supervisor, and DERMS Administrator roles receive the independent Edge Alerts, Alert History, and DER Search permissions. DERMS Administrator also receives Edge group-management access.
For customer-defined permission sets, explicitly add the required independent tool permissions. Do not infer them from previous Dashboard, Events, or combined DER Group grants. Maintain these assignments in customer configuration so that normal setup and later upgrades preserve them. Retain the existing action, approval, and Switching permissions required for each workflow. Changing permissions does not grant a product license.
Permissions
The Permissions tab displays permissions associated with each user type, and optionally permissions associated with specific users.
Select a user type in the User Types table to add or remove permissions for that user type. Similarly, select a user in the User Name table to add or remove permissions for that user.
DERMS Tool Permissions
Assign each tool permission explicitly. Existing Dashboard, Events, or combined DER Group access does not grant access to the independent tools below.
Permission
Tool or Capability
Access DERMS Optimization
Grid optimization objectives: Peak Shaving, Economic Dispatch, and NCA
Access DERMS VPP
Grid Virtual Power Plants
Access DERMS Day Ahead Market
Grid Day Ahead Market
Access DERMS DAGC
Grid DERMS Automatic Generation Control
Access Grid DERMS DER Group
Grid DERMS group management
Edge DERMS group management
Access DERMS Management
Grid DERMS Management
Access DERMS Contract Rules
DER Contract Rules
Access DERMS Alerts
Edge DERMS active alerts
Access DERMS Alert History
Edge DERMS alert history
Access DERMS DER Search
Edge DERMS resource search
Access Derms Dashboard remains the separate permission for the DERMS Dashboard. In NMS-hosted Flex Operations, the tool must also have its corresponding Grid DERMS (derms) or Edge DERMS (ge_derms) entitlement. The Dashboard accepts either entitlement.
Tool access does not replace the existing permissions for creating, updating, or deleting groups, executing actions, approving events, or performing Switching operations. DAM/DAGC group inspection does not grant group editing. Smart Inverter program editing remains separate from group-definition editing. Alerts, Alert History, and DER Search can be assigned independently.
For the Grid capability-to-license mapping, see Licensing and Tool Access in Flex Operations in Chapter 18.
Parameters
The Parameters tab displays global DERMS configuration options, with explanations for each. Select a row and edit it or clear it.
Strategy Types
The Strategy Types tab displays configurable strategy type categories. Select a row and edit it or deactivate it. Higher priority event types that can be scheduled with conflicts will force a cancellation of lower priority events.
Programs
The Programs tab displays the list of available programs, as received from Oracle Utilities Digital Asset Cloud Service (DACS). Right-click and Edit a program to modify some display values for the program and to flag certain rules as override-able.
Data Upload
The Data Upload tab allows you to perform the following actions:
• Import a temperature reduction file using the displayed XML file format. The Upload option in the Actions menu imports the selected file. The Clear option clears the selection.
• Export network model information to an external web service endpoint. The Export Model option in the Actions menu initiates the export process. Web service URL is specified by the OIC_MODEL_EXPORT_URL configuration parameter (accessible on the Parameters tab).
Alerts
The Alerts tab allows you to configure alert types and email recipients for failures to send messages to external systems and for monitored conditions, including DER device communication problems.
The alerts table contains rules for messages sent to external systems and for monitored conditions. It also includes four general classifications:
• Software Exceptions
• General Alerts
• General Warnings
• General Info
Alert List Columns
• The Classification column defines the type of message or error condition.
• The Type column indicates whether an Alert, Warning or Info alert is generated. Alerts are deemed to be higher priority than Warnings. If the type is set to Info, then the alert will never appear in the Alerts tool, but will instead be visible in the Alerts History tool and is used for auditing only.
• The Retry column indicates whether the system will attempt to resend the message associated with the alert.
• The Audit Successful Messages column indicates whether an Info alert will be placed in the Alert History tool when the message is successfully sent.
• The Send Email column indicates whether an email should be sent when a message fails to be sent or the error condition occurs.
• The Email Recipients column contains a comma separated list of email addresses to send the email notification to.
Alert List Actions
• The Edit Alert Rule action invokes a dialog box to allow editing of a selected alert row.
• The Reload action refreshes the contents of the list.
• The Service Recache action sends any updates made to the configuration to the server.
Communication Monitoring and Service-Request Alerts
The following classifications support communication monitoring and service requests:
• DER Status: Reports devices that meet the configured offline-percentage or no-status-update criteria. This rule controls the device communication warning and associated email notification. It does not resend a message to an external system. The default alert type is Warning, with retry disabled.
• Asset Service Request: Controls alerts for failures to send service-request creation messages to the external service. The default alert type is Warning, with retry enabled. See Understanding Retries for automatic and operator-initiated retries.
• General Alerts: Includes the notification that an aggregator's maximum number of active service requests has been reached.
Configure the rule using the columns and actions described above. For the monitoring thresholds and service-request endpoint, see Configuring Communication Monitoring for an Aggregator.
