Share and Export Workbooks and Files
You can easily share a workbook with others by copying and sharing the URL. You can also export or download your workbooks and your data to different file formats.
| Task | Description |
| Share a Workbook | Save a workbook in a shared folder and grant appropriate privileges to it so that your colleagues can access it. |
| Export a Workbook or Folder as a File |
Export a workbook or folder as an archive file (.DVA) that another user can import. Note: Opower Analytics Visualization does not use any database connections. This means that the Include Connection Credentials option in this procedure does not apply. |
| Export a Visualization or Story | Share visualizations or stories as a file in a variety of formats, such as DVA (a visualization workbook), PowerPoint (PPTX), Adobe Acrobat (PDF), PNG, or CSV (data only). |
| Export data to an Excel file. | Export data so it can be opened in Microsoft Excel format, and support a larger number of data rows. See instructions below. |
Export Data to Excel
You can download data in CSV format and open it in Microsoft Excel format (XLS). However, the CSV format is limited to approximately 100,000 rows of data. If you want to download larger amounts of data, you can download directly to Excel format, which can support up to approximately 500,000 rows. You will need to perform the export using the Publisher or Analytics component of Opower Analytics Visualization. The URL of your application changes slightly depending on which component you use.
To export to Excel using Oracle Analytics Publisher:
- Sign in to your instance of Oracle Analytics Publisher. To do this, remove
dvfrom the end of your Analytics Visualization URL, and replace it withxmlpserver. The URL should have the following format:https://ocacs.ocs.oraclecloud.com/<tenant id>/xmlpserverContact your Delivery Team if you need help with this step.
- In the Create... area, click Report.
- In the Create Report screen that displays, select Use Subject Area.
- Select the desired subject area in the drop-down and click Next.
- Select a layout and click Next.
- Create a table for the data by dragging and dropping fields.
- Click Next.
- Select View Report and click Finish.
- In the Save As window that displays, name your report and save it to any folder.
- When the report opens, click on the circle icon drop-down and select Excel. The file will be downloaded in the Excel file format.
To export to Excel using Analytics:
- Sign in to your instance of Analytics. To do this, remove
dvfrom the end of your Analytics Visualization URL, and replace it withanalytics. The URL should have the following format:https://ocacs.ocs.oraclecloud.com/<tenant id>/analyticsContact your Delivery Team if you need help with this step.
- In the Create... area, under Analysis and Interactive Reporting, click the Analysis link.
- Select a subject area from the Select Subject Area dialog box that displays.
- Build your analysis by dragging and dropping columns into the Selected Columns area.
- Click the Results tab. A tabular view of the data set you created is shown.
- Click the Export this analysis icon and click either Data or Formatted. Then click Excel.
- If a prompt displays asking you to confirm that you want to leave the page, click Leave Page. The file is downloaded to Excel.
