Creating Flow Test Data Sets
To create a flow test data set:
  1. Login to Oracle Utilities Testing Accelerator.
  2. On the Flows menu, navigate to the flow for which the test data set should be created.
  3. Click the edit icon next to the flow name.
  4. On the Flow Definition page, click Add under Flow Test Data Sets.
  5. Specify the data set name and click Add.
  6. Click Save As to save the test data of the flow.
  7. Specify the name of the test data set and click OK.
    If a test data set with the same name already exists, the application asks for confirmation to overwrite the test data.
  8. If the flow definition includes a subroutine, select the test data set for the subroutine. Right-click the subroutine and select Edit Test Data. Select the test data set from the Subroutine Flow Test Data Set drop-down list.
  9. To edit or add test data against a flow test data set, the corresponding flow test data set has to be selected on the flow structure definition pane.
  10. Navigate to the Edit Test Data page of each component in the flow and update/add the test data.
    Figure 8-34 Flow test data set selection
    Flow Creation page with the Flow Test Data Sets selector.
This figure shows flow test data sets option for the selected flow.
