Loading Test Data from Flow Test Data Sets
To populate the test data from a given test data set:
  1. Login to Oracle Utilities Testing Accelerator.
  2. On the Flows menu, navigate to the flow in which the component is used.
  3. Click the edit icon next to the flow name.
  4. On the Flow Definition page, select the test data set to be populated in the flow from the Flow Test Data Sets drop-down list.
    To edit or add test data against a flow test data set, the corresponding flow test data set has to be selected on the flow structure definition pane. Navigate to the Edit Test Data page of each component in the flow and update/add the test data.
  5. If the flow definition includes a subroutine, select the test data set for the subroutine. Right-click the subroutine and select Edit Test Data. Select the test data set from the Subroutine Flow Test Data Set drop-down list.
