Running the CM Content Upgrade Process for Flow Sets
The automated upgrade of flow sets in the testing tool saves significant time and effort by eliminating manual recreation of flow sets during Oracle Energy and Water Cloud Service upgrades. By automating this process, users can quickly and efficiently manage their upgrades to increase productivity. This results in faster testing and improves overall efficiency.
The automated upgrade of flow sets is a feature that streamlines the testing process for Oracle Energy and Water Cloud Service upgrades. By specifying the desired flow set, users can initiate an automated upgrade process, eliminating the need to manually recreate the flow set with each upgrade.
To upgrade existing flow sets:
  1. Navigate to the Administration tab.
  2. In the CM Content Upgrade section, click the Flows Sets tab.
  3. From the Flow Set drop-down list, select the flow set to be upgraded.
  4. Click Upgrade.
  5. Provide a name for the new flow set to be created.
  6. If the flow set has flows from multiple product versions, then a corresponding source target mapping needs to be defined for each product version. Else, this mapping is not needed.
  7. Click Upgrade.
    The upgrade process should run to completion displaying appropriate messages. The history of CM Content Upgrade process runs are displayed in the History section.
  8. Click View Logs to display the logs corresponding to that specific CM Content Upgrade process run. The history table also shows the following information:
    • Flow Set Name: Name of the flow set which has been upgraded.
    • New Flow Set Name: Name of the upgraded flow set.
    • Status: Current status of the upgrade process (Completed, Failed, In- progress).
    • Initiated By User: User who triggered the upgrade process.
    • Start Date Time: Start date and time of the upgrade process.
    • End Date Time: End date and time of the upgrade process.
    • Logs: To view the logs of the specific upgrade process run. The logs of the upgrade process also list the flows in the have been upgraded.
  • Before a Flow Set upgrade can be run, ensure that all the flows under that flow set have already been upgraded to the target version/versions.
  • Flow Set upgrade creates a new flow set and maps this new flow set to flow that have already been upgraded. This process does not upgrade the flows.
