9 Other Settings
The Advanced Management Console enables administrators to specify the parameters in the Java Usage Tracker properties file. Administrators can also configure the server parameters that the agent uses.
This topic includes the following sections:
            Customizing Java Usage Tracker Properties
The Advanced Management Console agent automatically enables the Usage Tracker on agent-managed Windows and macOS desktops. However, you need to manually configure the Java Usage Tracker on the Linux operating system.
To customize the Java Usage Tracking settings:
                  Server Settings
You can edit the default values for server settings as follows:
                  - In the Advanced Management Console UI, click the Configuration tab.
- Click Settings.
- Enter the Hostname of the server.
- Enter the Port Number of the server.
- Customize the browser Session Timeout for the AMC UI. A notification is displayed informing the user about the timeout and an option to extend the session. The value should be set in the range of 5 minutes to 480 minutes(8 hours).The default value is 60 minutes.
- Click Save.
