9 Browser Setup for Advanced Management Console
You need to ensure the operating systems and browser version compatibility for the Advanced Management Console . You also need a browser set up and the Advanced Management Console user interface for monitoring and administering the server.
The Browser Setup for the Advanced Management Console topic contains the following sections that describe compatibility and browser set up for the Advanced Management Console:
Advanced Management Console Browser Supported Versions
The Advanced Management Console user interface is provided through a browser.
If you use Internet Explorer as your supported browser as listed in Software Prerequisites and System Requirements for Advanced Management Console Components, then ensure that Display Intranet Sites in Compatibility View is not selected in Compatibility View Settings.
Browser Setup for the Advanced Management Console User Interface (UI)
See step 6 of Figure 2-1. The Advanced Management Console UI enables the user to monitor and administer the server.
Some commands in the Advanced Management Console start Java Web Start applications by using the JRE versions listed in Software Prerequisites and System Requirements for Advanced Management Console Components are needed to run these applications.
The commands in the Installers tab use Java Web Start applications, which also run on Windows operating systems.
