9 Other Settings
The Advanced Management Console enables administrators to specify the parameters in the Java Usage Tracker properties file. Administrators can also configure the server parameters that the agent uses.
Customizing Java Usage Tracker Properties
The Advanced Management Console agent automatically enables the Usage Tracker on agent-managed Windows and macOS desktops. However, you need to manually configure the Java Usage Tracker on the Linux operating system.
Server Settings
- In the Advanced Management Console UI, click the Configuration tab.
- Click Settings.
- Enter the Hostname of the server.
- Enter the Port Number of the server.
- Customize the browser Session Timeout for the AMC UI. A notification is displayed informing the user about the timeout and an option to extend the session. The value should be set in the range of 5 minutes to 480 minutes(8 hours).The default value is 60 minutes.
- Click Save.
Database Maintenance
Cleaning of older commands are auto-scheduled and runs every midnight. However, you can use the Advanced Management Console Database cleaning tool to manually delete previous commands of the specified status and date. You can also edit the threshold date and status of the commands.
- Click Database Maintenance.
- Click Clean DB to delete all commands.
- Click Edit to change the date and select the required status of the commands.
- Click Save.
