3 MySQL Database Installation and Configuration for Advanced Management Console
The database for the AMC provides data storage to host all the data. The database stores information about MSI files and applications, deployment rules, and deployment rule sets. The database also stores information about agents, Java Runtime Environment (JRE) statistics, and Java Installer configurations.
The AMC is also supported on Oracle Database.
This topic contains the following sections that describe software requirements and MySQL installation and configuration for the AMC:
Software Requirements for MySQL Database
To use MySQL database with Advanced Management Console , download and install a version of MySQL Server mentioned in Software Prerequisites and System Requirements for Advanced Management Console Components.
Installing MySQL Database for Advanced Management Console
This topic contains the following sections that describe MySQL installation and configuration setup instructions for Advanced Management Console on different platforms:
Installing MySQL Database on Windows
To install MySQL database:
                              Install the MySQL database server only and select Server Machine as the configuration type.
                              Select the option to run MySQL as a service.
                              Launch the MySQL Command-Line Client. To launch the client, enter the following command in a Command Prompt window: mysql -u root -p.The -poption is needed only if a root password is defined for MySQL. Enter the password when prompted.
                              Create the user (for example, amc2)and a strong password:mysql> create user 'amc2' identified by 'amc2';To restrict access to a machine (for example, to localhostfor a user) create the user as follows:mysql> create user 'amc2'@'localhost' identified by 'amc2';
                              Create the database (for example, amc2)and grant all access to the user (for example,amc2user):mysql> create database amc2;mysql> grant all on amc2.* to 'amc2';
                              Configure your MySQL installation to handle large BLOB entries, such as AMC Agent (installation) bundle and MSI binaries. To handle BLOB entries, edit the MySQL Option Files. MySQL is a Windows Service, so it can be started or stopped from the Windows Service administrator page. Any updates to the my.iniMySQL option file must be done by the administrator.To edit the my.inifile:-
                                    Open the my.inifile in an editor. You must edit the file with administrator privileges.By default, on MySQL 5.6, the option file is located at %PROGRAMDATA%\MySQL\MySQL Server 5.6\my.ini.Note: As of MySQL 5.7.18,my-default.cnfis no longer included in or installed by distribution packages. See Server Configuration Defaults in MySQL Reference Manual.
                                    Set the options max_allowed_packetandinnodb_log_file_sizeinmy.iniin the[mysqld]section to the values shown:[mysqld] max_allowed_packet=300M innodb_log_file_size=768M Note: Ensure that there are no other values formax_allowed_packetandinnodb_log_file_sizethat override the set value.
                                    Restart the MySQL service to apply changes.
The MySQL database user credentials provided in this topic are examples. The Advanced Management Console doesn’t need to know your MySQL database user credentials. MySQL database user credentials are only required to configure the Data Source connection in the application server.
Installing and Configuring MySQL on Linux
The MySQL commands might change from one version to another. For the latest commands, see MySQL Reference Manual.Before you proceed with installation, ensure that the MySQL Yum repository is added to your system's repository list. This is a one-time operation, which can be performed by installing an RPM provided by MySQL.
