8 Java Usage Tracker Setup for Advanced Management Console
This topic contains the following sections describe the Java Usage Tracker configuration for the Advanced Management Console on Windows, macOS, and Linux operating systems:
Setting Up Java Usage Tracker on Windows, macOS, and Linux Desktops
The Advanced Management Console agent automatically configures Java Usage Tracker on agent-managed desktops on supported platforms.
See Software Prerequisites and System Requirements for Advanced Management Console Components for the list of supported platforms.
Starting from Advanced Management Console  version
            2.5, agents configure Java Usage Tracker to report records to Advanced Management Console  agents instead of sending
            them directly to the Advanced Management Console
            server over the User Datagram Protocol (UDP). Agents then re-send the records to the Advanced Management Console  server over
                https. The Java Usage Tracker ensures that every JRE located on the
            desktop sends its Java usage data to the Advanced Management Console  server.
When Advanced Management Console is running in a cluster, the agent communicates with the load balancer and the UDP listener for the Java Usage Tracker records may not be supported.Setting up Java Usage Tracker on Unsupported Agent Platforms
The Advanced Management Console  supports
                Linux distributions having systemd or upstart
                service management framework. For distributions not supported, the Java Usage
                Tracker can be configured manually.
- Enter
https://wls-hostname:port/amcwebuiin the browser, wherewls-hostnameandportare the DNS name and listen port number of Oracle WebLogic Server. - Log in to the AMC UI using your administrator credentials.
 - Click the Configuration tab and then click the Settings sub tab.
 - Click Download usagetracker.properties file to download the file.
 - Enable Java Usage Tracker by copying this
usagetracker.propertiesfile to{JRE_HOME}/lib/managementfor each JRE installed on the desktop.
The downloaded usagetracker.properties file has the Java Usage Tracker parameters (port number, separators) required by the AMC. If you prefer to create the usagetracker.properties file yourself, then specify the parameters displayed in the AMC Settings tab.
The Advanced Management Console doesn’t incorporate data from thecom.oracle.usagetracker.additionalProperties setting of the usagetracker.properties file.
