4 Oracle Database Installation and Configuration for Advanced Management Console
The database for Advanced Management Console provides data storage to host all the data.
The database stores information about MSI files, applications, deployment rules, and deployment rule sets. The database also stores information about agents, Java Runtime Environment (JRE) statistics, and Java Installer configurations. This chapter contains the following sections that describe software requirements for the Oracle Database as well as installation and configuration procedures:
Software Requirements for Oracle Database
To use Oracle Database with Advanced Management Console , download and install a supported version of the Oracle database from Oracle Database Software Downloads.
Installing Oracle Database on Windows
This topic describes installation steps for Oracle Database.
Configuring Oracle Database on Windows
After installing Oracle database for Advanced Management Console on Windows, you need to configure it.
The Oracle Database user credentials provided in this topic are examples. The AMC doesn’t need to know your database user credentials. Oracle database user credentials are only required to configure the Data Source connection in the application server.
Installing and Configuring the Oracle Database on Linux
                           Download ORAchk from MOS.Note: MOS is available at https://support.oracle.com.
                           Copy orachk.ziponSRVDBand extract it.
                           Run ./orachkas a root user to check the Oracle database and generate HTML report. This creates a zip file of the report that contains an HTML file. The report includes any issues that were found along with links to MOS notes or documentation to fix the issues.
