- This tutorial requires access to Oracle Cloud. To sign up for a free account, see Get started with Oracle Cloud Infrastructure Free Tier.
- It uses example values for Oracle Cloud Infrastructure credentials, tenancy, and compartments. When completing your lab, substitute these values with ones specific to your cloud environment.
Use Open MPI on Oracle Roving Edge Infrastructure
Introduction
Oracle Roving Edge Infrastructure is a ruggedized cloud computing and storage platform suitable for deployment at the network edge or in locations with limited or no external connectivity. As larger, more complex and demanding workloads move toward the network edge, this can present challenges for an edge infrastructure.
Open MPI is an implementation of the Message Passing Interface (MPI) standard used for developing parallel applications in High Performance Computing (HPC). Open MPI can be used to deploy High Performance Computing and highly parallel workloads across relatively smaller pieces of infrastructure that then operate as a larger, aggregated set of resources. This approach can be used to distribute a workload to CPU and other compute resources such as GPU which allows deployment of larger, computationally intensive tasks at the network edge such as predictive modelling or other Artificial Intelligence/Machine Learning (AI/ML) tasks.
Open MPI can be used to deploy parallel workloads utilizing resources across Oracle Roving Edge Infrastructure nodes. Netfilter provides the necessary Destination Network Address Translation (DNAT) and Source Network Address Translation (SNAT) for VM instances using clustering software hosted across Oracle Roving Edge Infrastructure nodes. This tutorial implements Open MPI using Netfilter on Oracle Roving Edge Infrastructure running a prime number calculator to demonstrate improved performance when using parallel resources.
Background Information
Open MPI can run across several Virtual Machine (VM) instances within a single Oracle Roving Edge Infrastructure node or across multiple Oracle Roving Edge Infrastructure nodes. Running on a single Oracle Roving Edge Infrastructure node is seamless, and does not pose any issues. When running across multiple Oracle Roving Edge Infrastructure nodes, it is important to understand networking on Oracle Roving Edge Infrastructure VM instances and how Open MPI routes traffic to avoid possible issues.
Networking on Oracle Roving Edge Infrastructure Virtual Machine Instances
Virtual Machine instances running on Oracle Roving Edge Infrastructure use private IP addresses to communicate with other VM instances on the same subnet hosted on the same node. Public IP addresses can be assigned to VM instances hosted on Oracle Roving Edge Infrastructure to allow instances to communicate with other subnets and resources running outside of the Oracle Roving Edge Infrastructure node where it is hosted.
Note: Public IP addresses are assigned to VM instance VNICs from a public IP address pool. While the addresses are called Public IPs they are actually IP addresses on the same local network where the Oracle Roving Edge Infrastructure node is connected through its RJ-45 port. These addresses can be an IPv4 address reachable from the internet or they are addresses on a private subnet on the local network. These addresses are also referred to as external IP addresses, since they can be connected to resources external to the node where the VM instance is hosted.
It is important to understand when a VM instance running within an Oracle Roving Edge Infrastructure node attempts to access resources outside of the node, traffic goes through the external IP address which is routed within the node and out to the external network connection.
The private IP address the VM is using is translated by the hosting Oracle Roving Edge Infrastructure node to a public (external) IP address assigned from the public IP address pool.
Network traffic transits from the VM instance on the hosting Oracle Roving Edge Infrastructure node to the external network, this is effectively a 1:1 Network Address translation (NAT).
The VM instance has a public (external) IP address, but the VM instance itself never sees that IP address.
On the other hand, external traffic for the VM instance using its assigned public (external) IP address goes to the hosting Oracle Roving Edge Infrastructure node which translates the public (external) IP address to the associated private IP address of the destination VM instance.
An example VM instance on Oracle Roving Edge Infrastructure node is shown in the following image, notice the assigned public and private IP addresses.
Challenges For Running Open MPI Across Multiple Oracle Roving Edge Infrastructure Nodes
Using VM instance private IP addresses is problematic for clustering software, such as Open MPI, when it is implemented across multiple Oracle Roving Edge Infrastructure nodes. Each node is unaware of private to public IP address mappings, and the translation of the mappings for VM instances hosted on other nodes. Since the mappings are not shared, packets using private IP addresses are either routed incorrectly or lost.
Clustering software often examines VM instance interfaces and IP addresses and registers the information with other nodes in the software cluster.
VM instances are only aware of their private IP address and do not have a way to share their assigned public IP address.
Remote Oracle Roving Edge Infrastructure nodes hosting other cluster members also have no way to translate non-hosted VM instance private IP address to their respective public IP address.
When clustering VM instances hosted on different Oracle Roving Edge Infrastructure nodes handshake over their public IP address, their configuration exchange may contain only their private IP addresses.
- If these VM instances try to communicate via private IP addresses across Oracle Roving Edge Infrastructure nodes, the traffic will be pushed to the external network and will be likely to be dropped or routed incorrectly by the external network.
An example of how this problem might look using Open MPI:
Open MPI running on VM instances will try to determine the best network path to use to reach other VM instance members, the software might examine the local interfaces and IP addresses and register these with other nodes in the cluster.
Unfortunately, neither the source node or the destination nodes is aware of the network address translation that is required for connectivity to occur.
If
vm-node-1has a private IP of10.0.100.2(with a public IP of10.123.123.9) andvm-node-2has a private IP10.0.200.12(with a public IP of10.123.123.99), we can initially getvm-node-1andvm-node-2to handshake over their public IPs (10.123.123.x).-
The configuration they discover and exchange contains
10.0.x.xIPs (their private IP addresses). -
Thus, if
vm-node-1were to try and usevm-node-2’s private IP (10.0.200.12) to communicate, which is a non-local destination, the traffic will get pushed to the external network. -
The external network will either not know what to do with
10.0.200.12or it could be routed somewhere else entirely rather than the intended destination VM instance hosted on the other Oracle Roving Edge Infrastructure node. This is how Open MPI communication packets are lost. -
Remember that
10.0.200.12is private on a virtual instance IP hosted on an Oracle Roving Edge Infrastructure node, the external network does not know how to map the private IP address back to the VM instance. -
The external network only knows about
10.123.123.99(the public IP ofvm-node-2) which would be directed to the destination Oracle Roving Edge Infrastructure node, which will then translate the address and send the traffic to the correct VM instance.
Implement Open MPI Across Oracle Roving Edge Infrastructure
To address the non-shared nature of a Oracle Roving Edge Infrastructure’s internal network, Netfilter software on the Linux VM instances is used to rewrite network packets that are coming from, and destined for, VMs hosted on other Oracle Roving Edge Infrastructure nodes.
Design Considerations
In this tutorial, three Oracle Roving Edge Infrastructure Roving Edge Devices (RED) nodes are used to create an Open MPI cluster. All of the REDs are connected to a shared external network. Each node has been configured with its own external IP pool for allocation to a VM instances.
The RED’s external network is still a private network in RFC1918.
Each RED is configured with a VCN. In this use case, the VCN is using the CIDR of
10.0.0.0/16. -
Each RED will have a different CIDR for the subnet it will use. Using a different subnet CIDR simplifies set up and ensures that IP conflicts between VMs on different REDs will not occur.
VCN and Subnet CIDR Table
| RED Name | VCN CIDR | Subnet CIDR |
| RED1 | 10.0.0.0/16 | 10.0.1.0/24 |
| RED2 | 10.0.0.0/16 | 10.0.2.0/24 |
| RED3 | 10.0.0.0/16 | 10.0.3.0/24 |
This example is shown in the following image, two networking configurations from two different REDs.
Audience
Oracle Roving Edge Infrastructure administrators, developers and users.
Objectives
Implement Open MPI on Oracle Roving Edge Infrastructure.
Understand caveats when using Open MPI with multiple Oracle Roving Edge Infrastructure nodes.
Use Open MPI to demonstrate parallel processing across multiple Oracle Roving Edge Infrastructure nodes.
Prerequisites
Access to one or more Oracle Roving Edge Infrastructure nodes webUI, the example in this tutorial uses 3 Oracle Roving Edge Infrastructure Devices (REDs).
User permissions on Oracle Roving Edge Infrastructure to create and launch instances. For more information, see Compute Permissions for Roving Edge Infrastructure.
Set up Virtual Cloud Network (VCN) on each Oracle Roving Edge Infrastructure node. For more information, see Creating a VCN for a Roving Edge Infrastructure Device.
Set up subnets on each Oracle Roving Edge Infrastructure node with public IP addresses. For more information, see Creating a Subnet for a Roving Edge Infrastructure Device.
Know how to import a custom compute image to Oracle Roving Edge Infrastructure. For more information, see Managing Custom Images in OCI Compute, and Importing a Custom Image from a Bucket into a Roving Edge Infrastructure Device.
Set up instances running on Oracle Roving Edge Infrastructure node(s), and access to those nodes via SSH, see Creating an Instance for a Roving Edge Infrastructure Device.
Basic understanding of Oracle Linux for connecting to an instance via SSH, working with IP tables, services, editing files, running shell scripts, changing directories, installing software, working with package repositories and using proxy servers.
Task 1: Create Virtual Machine Instances
Create a VM instance in each subnet on each RED.
Example IP address assignments:
| RED Name | VM Name | VM O/S | VM Private IP | VM Public IP |
| RED1 | redvm1 | Ubuntu 22.04 | 10.0.1.2/24 | 10.123.123.32 |
| RED2 | redvm2 | Ubuntu 22.04 | 10.0.2.2/24 | 10.123.123.67 |
| RED3 | redvm3 | Ubuntu 22.04 | 10.0.3.2/24 | 10.123.123.101 |
Note: The VM instances in this task are created using an image exported from Oracle Cloud Infrastructure (OCI) using OCI Ubuntu
22.04LTS. Any Linux distribution with suitable Open MPI packages can be used, for example, Oracle Linux 8 or 9, Fedora and so on.
On each RED, navigate to Compute, Instance and click Create Instance.
In Create Compute Instance, enter Name, select the imported Custom image, Shape, Configure networking, SSH keys and click Create.
Task 2: Install Open MPI Package On Each VM Instance
Once all the VM instances have been created, log into each VM instance via SSH with the key provided during provisioning. The following commands are suitable for Ubuntu 22.04, you may need to adapt these instructions or include additional package repositories if you are using a different Linux distribution.
Run the following command to update the system and reboot.
sudo apt update && sudo apt upgrade -yThis might take a while to complete. When this completes, reboot the instance.
sudo shutdown -r now -
Log in to the instance and install the Open MPI packages.
This will pull through quite a few dependencies.
The
libopenmpi-devpackage is only required to later compile a sample program to test with. If you are not going to be compiling Open MPI features into programs, this package is not needed.
sudo apt install openmpi-bin libopenmpi-dev -y -
Task 3: Set Up Destination Network Address Translation (DNAT) and Source Network Address Translation (SNAT)
View details of each VM instance launched and note down the private and randomly assigned public IP addresses. Navigate to Compute, Instance and click the instance name to view the details.
Create the SNATs.
If we map the SNAT rules for each VM in a table, it should look like this:
SNAT Coming From RED1 Coming From RED2 Coming From RED3 On redvm1N/A Input src 10.123.123.67 SNAT to src 10.0.2.2Input src 10.123.123.101 SNAT to src 10.0.3.2On redvm2Input src 10.123.123.32 SNAT to src 10.0.1.2N/A Input src 10.123.123.101 SNAT to src 10.0.3.2On redvm3Input src 10.123.123.32 SNAT to src 10.0.1.2Input src 10.123.123.67 SNAT to src 10.0.2.2N/A -
Use
iptablescommands for each VM.-
On
redvm1.sudo iptables -I INPUT --src 10.123.123.0/24 -j ACCEPT -m comment --comment "Allow REDs public subnet access." sudo iptables -t nat -I INPUT -p tcp -s 10.123.123.67 -j SNAT --to-source 10.0.2.2 sudo iptables -t nat -I INPUT -p tcp -s 10.123.123.101 -j SNAT --to-source 10.0.3.2 sudo netfilter-persistent save -
On
redvm2.sudo iptables -I INPUT --src 10.123.123.0/24 -j ACCEPT -m comment --comment "Allow REDs public subnet access." sudo iptables -t nat -I INPUT -p tcp -s 10.123.123.32 -j SNAT --to-source 10.0.1.2 sudo iptables -t nat -I INPUT -p tcp -s 10.123.123.101 -j SNAT --to-source 10.0.3.2 sudo netfilter-persistent save -
On
redvm3.sudo iptables -I INPUT --src 10.123.123.0/24 -j ACCEPT -m comment --comment "Allow REDs public subnet access." sudo iptables -t nat -I INPUT -p tcp -s 10.123.123.32 -j SNAT --to-source 10.0.1.2 sudo iptables -t nat -I INPUT -p tcp -s 10.123.123.67 -j SNAT --to-source 10.0.2.2 sudo netfilter-persistent save
Note: The addition of the first rule (
sudo iptables -I INPUT --src 10.123.123.0/24 -j ACCEPT) to allow access from the subnet the REDs are using for their public IPs. Without this (or a similar rule), inbound traffic from RED to RED is likely to be dropped by the receiving RED. On these VMs, the new rules are persisted withsudo netfilter-persistent savehowever, this command will likely be something else if you are using a different Linux distribution. -
Create the DNATs.
Similarly, if we map the DNAT rules for each VM in a table, it should look like this:
DNAT Going To RED1 Going To RED2 Going To RED3 On redvm1N/A Output dst 10.0.2.2 DNAT to dst 10.123.123.67Output dst 10.0.3.2 DNAT to dst 10.123.123.101On redvm2Output dst 10.0.1.2 DNAT to dst 10.123.123.32N/A Output dst 10.0.3.2 DNAT to dst 10.123.123.101On redvm3Output dst 10.0.1.2 DNAT to dst 10.123.123.32Output dst 10.0.2.2 DNAT to dst 10.123.123.67N/A -
Use
On
redvm1.sudo iptables -t nat -I OUTPUT -p tcp -d 10.0.2.2 -j DNAT --to-destination 10.123.123.67 sudo iptables -t nat -I OUTPUT -p tcp -d 10.0.3.2 -j DNAT --to-destination 10.123.123.101 sudo netfilter-persistent save -
On
redvm2.sudo iptables -t nat -I OUTPUT -p tcp -d 10.0.1.2 -j DNAT --to-destination 10.123.123.32 sudo iptables -t nat -I OUTPUT -p tcp -d 10.0.3.2 -j DNAT --to-destination 10.123.123.101 sudo netfilter-persistent save -
On
redvm3.sudo iptables -t nat -I OUTPUT -p tcp -d 10.0.1.2 -j DNAT --to-destination 10.123.123.32 sudo iptables -t nat -I OUTPUT -p tcp -d 10.0.2.2 -j DNAT --to-destination 10.123.123.67 sudo netfilter-persistent save
Note: On the VM instances, the new rules are persisted with
sudo netfilter-persistent save. -
Task 4: Set up Open MPI
Open MPI uses SSH to communicate between cluster members, so there are a few things that need to be taken care of before we can run jobs.
Open MPI will be using the private IP addresses of each of the VMs, make
/etc/hostsentries for each VM instance and their private IP address on every Open MPI VM instance.For example, using the configuration above the
/etc/hostsentry onredvm1will contain the following entries:127.0.0.1 localhost 127.0.1.1 redvm1 redvm1 10.0.2.2 redvm2 10.0.3.2 redvm3On
redvm2, the/etc/hostswill contain the following entries:127.0.0.1 localhost 127.0.1.1 redvm2 redvm2 10.0.1.2 redvm1 10.0.3.2 redvm3On
redvm3, the/etc/hostswill contain the following entries:127.0.0.1 localhost 127.0.1.1 redvm3 redvm3 10.0.1.2 redvm1 10.0.2.2 redvm2 -
We also need to ensure that the SSH equivalence exists between each VM for Open MPI to use.
Note: The assumption here is that these are new VMs that do not contain existing SSH keys for the Ubuntu user. If you are using older VMs that have already had SSH keys created, you will need to adapt these instructions, these instructions could overwrite existing keys and lock you out of your VMs.
On
redvm1, create a new public or private key pair (if you do not have keys created already). Usessh-keygencommand similar tossh-keygen -b 4096 -t rsa(accept the defaults, do not set a password for the new keys). This will generate~/.ssh/id_rsaand~/.ssh/id_rsa.pub. -
Add the new public key to the
authorized_keysfile by executingcat ~/.ssh/id_rsa.pub >> ~/.ssh/authorized_keysor copying them in manually via a text editor. -
Copy both
id_rsaandid_rsa.pubto theubuntuuser’s~/.sshdirectory onredvm2andredvm3. Ensure you addid_rsa.pubtoauthorized_keys, runcat ~/.ssh/id_rsa.pub >> ~/.ssh/authorized_keysonredvm2andredvm3. -
Once this has been done, from each VM, connect to all of the other VMs including the VM itself to ensure that connectivity works and that SSH trusts the other hosts.
SSH connection on
redvm1.ubuntu@redvm1:~$ ssh redvm1 date The authenticity of host 'redvm1 (127.0.1.1)' can't be established. ED25519 key fingerprint is SHA256:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. This key is not known by any other names Are you sure you want to continue connecting (yes/no/[fingerprint])? yes Warning: Permanently added 'redvm1' (ED25519) to the list of known hosts. Fri Apr 5 04:28:57 UTC 2024 ubuntu@redvm1:~$ ubuntu@redvm1:~$ ssh redvm2 date The authenticity of host 'redvm2 (10.0.2.2)' can't be established. ED25519 key fingerprint is SHA256:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. This key is not known by any other names Are you sure you want to continue connecting (yes/no/[fingerprint])? yes Warning: Permanently added 'redvm2' (ED25519) to the list of known hosts. Wed Jan 31 04:29:11 UTC 2024 ubuntu@redvm1:~$ ubuntu@redvm1:~$ ssh redvm3 date The authenticity of host 'redvm3 (10.0.3.2)' can't be established. ED25519 key fingerprint is SHA256:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. This key is not known by any other names Are you sure you want to continue connecting (yes/no/[fingerprint])? yes Warning: Permanently added 'redvm3' (ED25519) to the list of known hosts. Wed Jan 31 04:29:19 UTC 2024
Repeat above steps for
redvm2connecting toredvm2,redvm1andredvm3andredvm3connecting toredvm3,redvm1andredvm2.
Create a common storage location for each cluster member.
Note: Ideally all VM instances using Open MPI will have a shared storage location. This could take the form of NFS, GlusterFS, OCFS2 or any number of other shared filesystem solutions. This is particularly important if a common working directory or data set is needed for the workload.
A shared filesystem is not needed for this example, only a location with a common name for our testing binaries. On each VM, create the common name location
/mpitest.sudo mkdir /mpitest && sudo chown ubuntu:ubuntu /mpitestIf we use a shared filesystem, the shared filesystem will then mount at this location on all VM instances.
Create a
hostfilefor use withmpirun. For more information, see How do I use the –hostfile option to mpirun?.-
We will create two
hostfilesfor testing. Onredvm1, using our common name location/mpitestcreated above, create a file/mpitest/mpihosts.txtwith the following content:redvm1 redvm2 redvm3 -
Create a file
/mpitest/mpihosts_slots.txtwith the following content:redvm1 slots=1 redvm2 slots=1 redvm3 slots=1
Note: In this tutorial, tests will only be run from
redvm1so we do not need to copy these files toredvm2andredvm3. If you want to run jobs from other VMs too, you will need to copy these files to the other VM instances, or use a proper shared filesystem like NFS.
Task 5: Test the VM Instance
A simple test of distributed commands.
A simple test is just to invoke a command such as
hostnameon all of the cluster members. Here is the expected output running across three nodes withslots=1(mpihosts_slots.txt) file. Theslotsdirective informsmpirunhow many processes can be allocated to this node rather thanmpirundetermining the number of processes.Note: Specifying
slotsmight be necessary if you are using limited resources other than CPU (for example, GPUs), where you want to limit processes to the number of the other resource. Failing to do so can result in processes failing due to not being able to allocate the other resources.ubuntu@redvm1:~$ cd /mpitest ubuntu@redvm1:/mpitest$ cat mpihosts_slots.txt redvm1 slots=1 redvm2 slots=1 redvm3 slots=1 ubuntu@redvm1:/mpitest$ mpirun --hostfile mpihosts_slots.txt hostname redvm1 redvm2 redvm3 -
Run the same test but without specifying the
slots(mpihosts.txt) file,mpirunwill determine the available CPUs and run the number of CPUshostnamecommands on each node. These three VMs have 16 CPUs, thus we should get 3 x 16 responses (16 of each hostname).ubuntu@redvm1:/mpitest$ cat mpihosts.txt redvm1 redvm2 redvm3 ubuntu@redvm1:/mpitest$ mpirun --hostfile mpihosts.txt hostname | sort | uniq -c 16 redvm1 16 redvm2 16 redvm3
Build an Open MPI test binary.
For a proper test with a program that uses Open MPI, we use a prime number calculator example from John Burkardt. That will need to be downloaded and compiled on
redvm1. For more information, see Prime Number Calculator by John Burkardt.ubuntu@redvm1:~$ cd /mpitest ubuntu@redvm1:/mpitest$ curl https://people.sc.fsu.edu/~jburkardt/c_src/prime_mpi/prime_mpi.c -o prime_mpi.c % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 4699 100 4699 0 0 2990 0 0:00:01 0:00:01 --:--:-- 2991 ubuntu@redvm1:/mpitest$ mpicc prime_mpi.c -o prime_mpi ubuntu@redvm1:/mpitest$ ls -l prime_mpi -rwxrwxr-x 1 ubuntu ubuntu 16736 Apr 5 05:38 prime_mpiSince a shared filesystem is not set up for testing, the
prime_mpibinary needs to be copied toredvm2andredvm3in the same location that it is onredvm1. Run the following command.ubuntu@redvm1:/mpitest$ scp prime_mpi redvm2:/mpitest prime_mpi 100% 16KB 27.4MB/s 00:00 ubuntu@redvm1:/mpitest$ scp prime_mpi redvm3:/mpitest prime_mpi 100% 16KB 28.3MB/s 00:00 -
For a baseline to compare, run an Open MPI binary standalone. Run
prime_mpiwithout Open MPI for a baseline or comparison.ubuntu@redvm1:/mpitest$ ./prime_mpi 31 January 2024 06:08:17 AM PRIME_MPI C/MPI version An MPI example program to count the number of primes. The number of processes is 1 N Pi Time 1 0 0.000003 2 1 0.000000 4 2 0.000000 8 4 0.000000 16 6 0.000000 32 11 0.000001 64 18 0.000002 128 31 0.000022 256 54 0.000019 512 97 0.000066 1024 172 0.000231 2048 309 0.000810 4096 564 0.002846 8192 1028 0.010093 16384 1900 0.037234 32768 3512 0.137078 65536 6542 0.515210 131072 12251 1.932970 262144 23000 7.243419 PRIME_MPI - Master process: Normal end of execution. 31 January 2024 06:08:27 AMNote: The number of processes is 1 and it takes about 10 seconds to complete.
A distributed run using Open MPI. Run
prime_mpiwith Open MPI across all the available CPUs on the three VM instances using thempihosts.txtfile.ubuntu@redvm1:/mpitest$ mpirun --hostfile mpihosts.txt ./prime_mpi 31 January 2024 06:09:02 AM PRIME_MPI C/MPI version An MPI example program to count the number of primes. The number of processes is 48 N Pi Time 1 0 0.020740 2 1 0.000428 4 2 0.000331 8 4 0.000392 16 6 0.000269 32 11 0.000295 64 18 0.000374 128 31 0.000390 256 54 0.000380 512 97 0.000331 1024 172 0.000351 2048 309 0.000385 4096 564 0.000740 8192 1028 0.001931 16384 1900 0.006316 32768 3512 0.021577 65536 6542 0.078834 131072 12251 0.273368 262144 23000 0.808825 PRIME_MPI - Master process: Normal end of execution. 31 January 2024 06:09:03 AM48 processes are used and it takes about 1 second to run.
Explore Open MPI by running the same example, but with
mpihosts_slots.txtfile. You should see an improvement compared to runningprime_mpistandalone, but it will only use 1 processor on each node (total of 3) rather than the full complement on all nodes. By changing the number of slots on each VM instances, you can control the distribution of the job.
Related Links
Acknowledgments
- Authors - James George (Master Principal Cloud Architect), Melinda Centeno (Senior Principal Product Manager)
More Learning Resources
Explore other labs on docs.oracle.com/learn or access more free learning content on the Oracle Learning YouTube channel. Additionally, visit education.oracle.com/learning-explorer to become an Oracle Learning Explorer.
For product documentation, visit Oracle Help Center.
F96255-01
April 2024
