- Oracle x86 Servers Diagnostics and Troubleshooting Guide
- Oracle ILOM Diagnostics
- Using the Fault Management Shell
You can use the Oracle ILOM Fault Management Shell to view faults and determine the components affected by the faults.
The Oracle ILOM fmadm faulty command is the preferred method to
display fault or defect information and determine the FRUs involved.
View Faults Using the Fault Management Shell
- From the Oracle ILOM CLI, to launch the Oracle ILOM Fault Management Shell, type start /SP/faultmgmt/shell.
- To display the commands available in the Fault Management Shell, type help.
- To display information about the components, type fmadm
faulty.
In the following example, the output shows one faulty CPU.
The
AffectsandStatuslines identify the component affected by the fault and its relative state. In this example, a single CPU is affected. It is marked "faulted".Beneath the
Statusinformation, the data for the impacted FRU (field-replaceable unit) displayed. The location string (also called the FRU label) is "/SYS/MB/P0." It should match the label on the physical hardware or the value displayed by Oracle ILOM.The
Statusof the FRU displays asfaulty.The Action section might also include other specific actions instead of, or in addition to, the usual reference to the
fmadmcommand.-> start /SP/faultmgmt/shell Are you sure you want to start /SP/faultmgmt/shell (y/n)? y faultmgmtsp> help Built-in commands: echo - Display information to user. Typical use: echo $? help - Produces this help. Use 'help <command>' for more information about an external command. exit - Exit this shell. External commands: fmadm - Administers the fault management service fmdump - Displays contents of the fault and ereport/error logs fmstat - Displays statistics on fault management operations faultmgmtsp> fmadm faulty ------------------- ------------------------------------ -------------- -------- Time UUID msgid Severity ------------------- ------------------------------------ -------------- -------- 2000-06-18/22:39:23 00cbca46-d34d-6938-ba47-d9f69e8ccceb SPX86A-8007-Q1 Critical Problem Status : open Diag Engine : fdd 1.0 System Manufacturer : Oracle Corporation Name : ORACLE SERVER X9-8 Part_Number : 7336847-B2 Serial_Number : 1715XC4010A System Component Firmware_Manufacturer : Oracle Corporation Firmware_Version : (ILOM)5.1.0.0 Firmware_Release : (ILOM)2018.03.16 ---------------------------------------- Suspect 1 of 1 Problem class : fault.chassis.fw.platform-info.invalid Certainty : 100% Affects : /SYS/SMOD0/MB Status : faulted FRU Status : faulty Location : /SYS/SMOD0/MB Manufacturer : HON HAI PRECISION INDUSTRY CO LTD Name : SMOD TOP LEVEL ASSY Part_Number : 7339666 Revision : 07 Serial_Number : 465136N+1743PJ001J Chassis Manufacturer : Oracle Corporation Name : ORACLE SERVER X9-8 Part_Number : 7336847-B2 Serial_Number : 1715XC4010A Description : The BIOS has detected that the platform information structure (SPI flash) is invalid. Response : The chassis wide service-required LED is illuminated. Impact : The system is unable to power on. BIOS does not have valid platform information to boot properly. Action : Please refer to the associated reference document at http://support.oracle.com/msg/SPX86A-8007-Q1 for the latest service procedures and policies regarding this diagnosis.
