Using the Oracle ILOM Diag Shell
At the Oracle ILOM CLI prompt, you can run HWdiag commands to check the status of a system and its components, and access HWdiag logs. Depending on the server, see Run HWdiag (CLI) to use one of the methods to access the Diag shell.
For information about Oracle ILOM, refer to the Oracle ILOM Documentation Library at Systems Management Documentation.
Using HWdiag Commands
This section describes how to use the HWdiag command line.
HWdiag commands use the form hwdiag main-command [subcommand ...].
For example:
[(flash)root@ORACLESP-1234567:~]# hwdiag led get /SYS/MB/P1/D8/SERVICE
HWdiag - Build Number 117435 (May 01 2019, 17:05:36)
Current Date/Time: January 04 2019, 10:52:31
LED VALUE
/SYS/MB/P1/D8/SERVICE : off
Many subcommands require an additional subcommand to identify the actual device or devices being acted on. This target can be an individual device or all, which represents all the valid targets for the subcommand. In the above example, hwdiag led get /SYS/MB/P1/D8/SERVICE returns the state of a single LED. If you enter hwdiag led get all, it displays the state of all the system LEDs.
Main commands and subcommands are case insensitive. However, hwdiag is not. For example, hwdiag led get all is the same as hwdiag LED GET ALL.
If you enter an incomplete command line, the HWdiag utility displays the syntax for the command and a list of valid subcommands. Use this information to re-enter the command with a complete and valid set of parameters and subcommands.
The following display shows an example.
diag> hwdiag temp
HWdiag - Build Number 81018 (January 12 2019 at 00:42:14)
Syntax: hwdiag temp ...
get [all|<sensor>]
- Display Temperature Sensor Reading
info [all|<sensor>]
- Display Temperature Sensor Information
diag> hwdiag temp get
Syntax: hwdiag temp get all|<sensor>
Valid Options for Temperature :
ALL /SYS/MB/T_IN_PS
/SYS/MB/P0 /SYS/MB/T_IN_ZONE1
/SYS/MB/P1 /SYS/MB/T_IN_ZONE2
/SYS/MB/P2 /SYS/MB/T_IN_ZONE3
/SYS/MB/P3 /SYS/MB/T_IN_ZONE4
/SYS/MB/T_CORE_NET01 /SYS/MB/T_OUT_SLOT1
/SYS/MB/T_CORE_NET23 /SYS/T_FRONT
diag> hwdiag temp get all
DEVICE TEMP
/SYS/MB/P0 : 64.00 margin
/SYS/MB/P1 : 64.00 margin
/SYS/MB/P2 : 63.00 margin
/SYS/MB/P3 : 64.00 margin
/SYS/MB/T_CORE_NET01 : 38.75 deg C
/SYS/MB/T_CORE_NET23 : 38.00 deg C
/SYS/MB/T_IN_PS : 26.75 deg C
/SYS/MB/T_IN_ZONE1 : 30.75 deg C
/SYS/MB/T_IN_ZONE2 : 30.75 deg C
/SYS/MB/T_IN_ZONE3 : 29.50 deg C
/SYS/MB/T_IN_ZONE4 : 28.25 deg C
/SYS/MB/T_OUT_SLOT1 : 29.75 deg C
/SYS/T_FRONT : 24.50 deg CHWdiag Commands and Options
The following tables list the HWdiag utility commands and options.
Not all commands are available on all platforms. To find out which commands are available on your system, enter hwdiag -h.HWdiag Commands
| Component | Action | Options | Description and Options |
cpld |
CPLD, FPGA tests, and utilities. |
reg |
all|fgpa |
Dump CPLD registers. |
vr_check |
Print voltage regulator status. |
log read number_of_ last_entries |
Read the last three entries from the cpld log file. |
mbus |
(X9-8 only) Check MBUS status. |
cpu |
Display CPU information. |
capid all|cpu |
Decode CAPID values for CPU. |
info all|cpu |
-v |
Dump CPU devices and display coding for all registers. |
pirom_info all|cpu |
Dump PIROM CPU information. |
fan |
Fan test and utilities. |
get |
-m |
Display fan RPM. |
info |
-r |
Display fan presence information. |
gpio |
GPIO utilities. |
get all|gpio_pin |
Get information about GPIO pin. |
i2c |
Test the sideband i2c topology. |
scan all|bus |
Display accessible i2c devices. |
test all|bus |
Test connectivity of platform i2c devices. This test returns a pass or fail. |
io |
IO tests and utilities. |
nvme_info |
-v |
Display information from VPD and MI for NVMe devices. |
nvme_test |
-v |
Check for PCIe link width and speed of NVMe drives and NVMe add-in-cards. |
led |
Get information about LEDs. |
get all|led |
Display the state of LEDs. |
info all|led |
Display information about LED registers. |
mem |
Display memory (DIMM) information. |
info all|dimm_name |
Display memory configuration. |
spd all|dimm_name |
-r |
Display DIMM SPD information, such as size, speed, and voltage. The information displayed varies according to manufacturer. |
pci |
PCIe tests and utilities. |
dump |
Read PCIe registers. dump <socket> <bus> <dev> <func> [std|ext]|[<offset> <count>]
info all|device |
-r |
Display PCIe link information for all, or for a single device. |
read |
Read the specified PCIe register. read <socket> <bus> <dev> <func> <offset> |
scan |
Scan all PCIe devices. |
status all|pci-target(s)
Print status of pci-target(s) |
power |
Display power information. |
get |
Display sensor readings. get amps|volts|watts all|sensor. |
info all|sensor |
Display information about voltage reduction devices (VRD). sensor identifies an individual sensor. |
system |
Display system information. |
summary |
Display system summary. |
fabric test all| cpu |
Test the system fabric, including QPI bus speed, PCIe link speed, and memory frequency. |
info |
Display system configuration information. |
port80 number_of_last_codes |
-m |
Display host boot progress. Optionally, enter the number of last codes to show the last codes for port80. |
rtc |
Display the real time clock (RTC). |
thermal |
-m, –r |
Display system thermal information, including temperatures, fan speeds, and power. |
version |
Display the version of system components. |
temp |
Display temperatures. |
get all|sensor |
Display temperature sensor readings. |
info all|sensor |
Display information about temperature sensors. |
HWdiag Command Options
The following table lists the HWdiag command options.
| Option | Long | Description |
– f |
force |
Force execution of a command regardless of prerequisites.* |
– h |
help |
Display help test. |
– i |
interactive |
Prompts when you use it with a main command.* |
– l |
log <filename> |
Enable HWdiag to start logging to <filename>. Note: Use -t to add time stamp to logging. |
– m |
monitor <.1 sec> |
Set monitoring interval in increments of tenths of a second (.1 second). Overrides current monitoring interval.* |
– n |
numberloop |
Set the number of loops to run a command continually. |
– p |
persist |
Use persistent hardware presence data for all invocations of any HWdiag command. |
– q |
quiterr |
Exit HWdiag utility immediately after an error occurs. |
– r |
raw |
Modify HWdiag output for easier parsing.* |
– s |
sampleint |
Sample interval in seconds to set the number of seconds of sleep between collecting data samples. Use only with -n option. |
– t |
timestamp |
Add time stamp to logging. Use with -l option. |
– u |
unit [ 1,2,4 ] |
Control the output format of dump subcommands. Options are 1 byte (default), 2 byte, or 4 byte format.* |
– v |
verbose |
Enhance the verbosity of output.* |
– x |
exclude |
Exclude a feature.* |
*Implement the HWdiag command option only on subcommands. For details on the syntax, refer to the subcommand documentation or display the help by typinghelp hwdiag -hv.
HWdiag Logs
In addition to running the HWdiag utility commands, you can access and display the content of the HWdiag log files. The commands ls and cat are available in the Oracle ILOM SP/Diag shell.
To read the content of the logs use the cat command. For
example, type cat hwdiag/hwdiag_i2c_test.log.
