Technical Solution
You can quickly create a high performance computing platform on-demand and automatically shut it down following the simulations.
Architecture
This architecture shows a high performance compute architecture with a variety of data sources that uses Oracle Cloud Infrastructure services to solve complex mathematical and scientific problems across industries.
The architecture has the following components:
- Region
An Oracle Cloud Infrastructure region is a localized geographic area that contains one or more data centers, called availability domains. Regions are independent of other regions, and vast distances can separate them (across countries or even continents).
- Availability domains
Availability domains are standalone, independent data centers within a region. The physical resources in each availability domain are isolated from the resources in the other availability domains, which provides fault tolerance. Availability domains don’t share infrastructure such as power or cooling, or the internal availability domain network. So, a failure at one availability domain shouldn't affect the other availability domains in the region.
- Fault domains
A fault domain is a grouping of hardware and infrastructure within an availability domain. Each availability domain has three fault domains with independent power and hardware. When you distribute resources across multiple fault domains, your applications can tolerate physical server failure, system maintenance, and power failures inside a fault domain.
- Virtual cloud network (VCN) and subnets
A VCN is a customizable, software-defined network that you set up in an Oracle Cloud Infrastructure region. Like traditional data center networks, VCNs give you control over your network environment. A VCN can have multiple non-overlapping CIDR blocks that you can change after you create the VCN. You can segment a VCN into subnets, which can be scoped to a region or to an availability domain. Each subnet consists of a contiguous range of addresses that don't overlap with the other subnets in the VCN. You can change the size of a subnet after creation. A subnet can be public or private.
- Dynamic routing gateway
(DRG)
The DRG is a virtual router that provides a path for private network traffic between VCNs in the same region, between a VCN and a network outside the region, such as a VCN in another Oracle Cloud Infrastructure region, an on-premises network, or a network in another cloud provider.
- Internet
gateway
The internet gateway allows traffic between the public subnets in a VCN and the public internet.
- Network
address translation (NAT) gateway
A NAT gateway enables private resources in a VCN to access hosts on the internet, without exposing those resources to incoming internet connections.
- Storage Gateway
Oracle Cloud Infrastructure (OCI) Storage Gateway extends on-premises application data to Oracle Cloud. Integration with OCI Object Storage and Network File Storage (NFS) compliance make it easy to securely move files to and from Oracle Cloud. Data is encrypted both at rest and in-transit and built-in data integrity checks provides protection. Local caching provides enterprise applications instant access to files that are frequently used.
- Data integration
Oracle Cloud Infrastructure Data Integration is a fully managed, serverless, cloud-native service that extracts, loads, transforms, cleanses, and reshapes data from a variety of data sources into target Oracle Cloud Infrastructure services, such as Autonomous Data Warehouse and Oracle Cloud Infrastructure Object Storage. ETL (extract transform load) leverages fully-managed scale-out processing on Spark, and ELT (extract load transform) leverages full SQL push-down capabilities of the Autonomous Data Warehouse in order to minimize data movement and to improve the time to value for newly ingested data. Users design data integration processes using an intuitive, codeless user interface that optimizes integration flows to generate the most efficient engine and orchestration, automatically allocating and scaling the execution environment. Oracle Cloud Infrastructure Data Integration provides interactive exploration and data preparation and helps data engineers protect against schema drift by defining rules to handle schema changes.
- FastConnect
Oracle Cloud Infrastructure FastConnect provides an easy way to create a dedicated, private connection between your data center and Oracle Cloud Infrastructure. FastConnect provides higher-bandwidth options and a more reliable networking experience when compared with internet-based connections.
- Bastion host
The bastion host is a compute instance that serves as a secure, controlled entry point to the topology from outside the cloud. The bastion host is provisioned typically in a demilitarized zone (DMZ). It enables you to protect sensitive resources by placing them in private networks that can't be accessed directly from outside the cloud. The topology has a single, known entry point that you can monitor and audit regularly. So, you can avoid exposing the more sensitive components of the topology without compromising access to them.
- HPC cluster node
Designed for high-performance computing workloads that require high frequency processor cores and cluster networking for massively parallel HPC workloads. The head node provisions and deprovisions these compute nodes, which are RDMA-enabled clusters (100 gbps RoCE v2 isolated network). They process the data stored in file storage and return the results to file storage.
- Autonomous
Database
Oracle Autonomous Database is a fully managed, preconfigured database environments that you can use for transaction processing and data warehousing workloads. You do not need to configure or manage any hardware, or install any software. Oracle Cloud Infrastructure handles creating the database, as well as backing up, patching, upgrading, and tuning the database.
- File
storage
The Oracle Cloud Infrastructure File Storage service provides a durable, scalable, secure, enterprise-grade network file system. You can connect to a File Storage service file system from any bare metal, virtual machine, or container instance in a VCN. You can also access a file system from outside the VCN by using Oracle Cloud Infrastructure FastConnect and IPSec VPN.
- Object storage
Object storage provides quick access to large amounts of structured and unstructured data of any content type, including database backups, analytic data, and rich content such as images and videos. You can safely and securely store and then retrieve data directly from the internet or from within the cloud platform. You can scale storage without experiencing any degradation in performance or service reliability. Use standard storage for "hot" storage that you need to access quickly, immediately, and frequently. Use archive storage for "cold" storage that you retain for long periods of time and seldom or rarely access.
- Analytics
Oracle Analytics Cloud is a scalable and secure public cloud service that empowers business analysts with modern, AI-powered, self-service analytics capabilities for data preparation, visualization, enterprise reporting, augmented analysis, and natural language processing and generation. With Oracle Analytics Cloud, you also get flexible service management capabilities, including fast setup, easy scaling and patching, and automated lifecycle management.
- Notifications
The Oracle Cloud Infrastructure Notifications service broadcasts messages to distributed components through a publish-subscribe pattern, delivering secure, highly reliable, low latency, and durable messages for applications hosted on Oracle Cloud Infrastructure.
- APEX Service
Oracle APEX is a low-code development platform that enables you to build scalable, feature-rich, secure, enterprise apps that can be deployed anywhere that Oracle Database is installed. You don't need to be an expert in a vast array of technologies to deliver sophisticated solutions. Oracle APEX includes built-in features such as user interface themes, navigational controls, form handlers, and flexible reports that accelerate the application development process.
