About Implementing Disaster Recovery with Cross-Zone Data Guard on Oracle Database@AWS
Oracle Database@AWS offers built-in high availability and scalability with Oracle Real Application Clusters (Oracle RAC) while ensuring low latency for AWS applications. Extending the solution with an Active Data Guard standby database hosted on another Oracle Exadata Cloud Infrastructure in another availability zone within the same region enhances availability and data protection in case of an entire availability zone outage.
Active Data Guard adds comprehensive data corruption prevention with automatic block repair, online upgrades and migrations, offload workload to standby with read-mostly scale-out, and enable Application Continuity to mask database outages during planned and unplanned events from end-users and ensure uninterrupted applications.
Oracle Exadata Database Service on Oracle Database@AWS is certified at the Gold tier of Oracle Maximum Availability Architecture (MAA). This validation confirms that the service meets Oracle’s highest standards for high availability and disaster recovery, with support for failover across multiple AWS availability zones as well as across AWS regions. With Gold MAA certification, Oracle Exadata Database Service on Oracle Database@AWS blends cloud flexibility with proven resilience, ensuring your mission-critical workloads stay protected from server failures as well as data center outages.
Before You Begin
The configuration and deployment instructions in this solution playbook require the Exadata infrastructure and the Exadata VM Cluster to be already deployed in the standby availability zone, and that the network IP CIDR ranges for the primary and standby Exadata VM Clusters do not overlap.
Review the following resources:
Review these related solutions:
- Security best practices for your VPC in the Amazon Virtual Private Cloud User Guide
- Plan for AWS IP address space using ODB Network Design
About Required Services and Roles
This solution requires the following services and roles:
- Oracle Cloud Infrastructure Networking
- Oracle Exadata Database Service
These are the roles needed for each service.
| Service Name: Role | Required to... |
Service: manage database-family |
Manage the database, including adding and operating Active Data Guard deployments |
OCI Networking: manage vcn-family |
Manage the network components, including VCNs, subnets, security rules, and VCN peering |
