Learn How to Onboard Java Management Service to Monitor Java Usage
JMS equips you to:
- Use the insights to optimize your workloads across your enterprise (desktop, server, cloud).
- Protect your Java SE investments by identifying outdated Java installations, unauthorized applications, and Java runtime and application mismatches.
Before You Begin
Before you begin, ensure you are familiar with the following requirements and technology for a basic deployment:
- Access to Java Management Service requires an Oracle Cloud account. You may use your own cloud account or you can get an OCI Free Tier account.
- Ensure an Oracle Linux machine is setup correctly to allow the communication with
OCI services. The following are supported machines:
- An OCI compute instance that is available in your tenancy. See Create an OCI compute instance if you don't have an instance already setup.
- Host that is located on-premises or in a third-party cloud that you want to monitor with JMS.
- Review the system requirements and supported platforms at https://docs.oracle.com/en-us/iaas/jms/doc/you-begin.html.
- Familiarize yourself with JMS Key Concepts. See https://docs.oracle.com/en-us/iaas/jms/doc/key-concepts-and-terminology.html.
See the Monitor and manage your Java and Java application installations reference architecture to learn more about the JMS monitoring ecosystem.
Architecture
The network diagram below outlines the traffic flows between the JMS agent installed on your host machines (on-premises) and JMS running in OCI. Similar traffic pattern occurs between your host machines in OCI and JMS.
jms-oci-network-traffic-oracle.zip
- The JMS agent always initiates the request by authenticating itself with OCI by using an open port that is allowed by the firewall (443).
- The Management agent and JMS service from OCI don't push any data to the agent.
- The JMS agent polls the service for work requests.
- JMS agent work requests polling interval can be as low as 30 seconds.
- JMS agent polling interval is configurable, maximum polling interval is 10 minutes.
- Data transmitted is encrypted using TLS.
- The OCI services then send back the data in response to these request once connection is established.
The architecture has the following components:
- Region
An OCI region is a localized geographic area that contains one or more data centers, hosting availability domains. Regions are independent of other regions, and vast distances can separate them (across countries or even continents).
- Availability domains
Availability domains are standalone, independent data centers within a region. The physical resources in each availability domain are isolated from the resources in the other availability domains, which provides fault tolerance. Availability domains don’t share infrastructure such as power or cooling, or the internal availability domain network. So, a failure at one availability domain shouldn't affect the other availability domains in the region.
- Compartment
Compartments are cross-regional logical partitions within an OCI tenancy. Use compartments to organize, control access, and set usage quotas for your Oracle Cloud resources. In a given compartment, you define policies that control access and set privileges for resources.
- Dynamic routing gateway
(DRG)
The DRG is a virtual router that provides a path for private network traffic between VCNs in the same region, between a VCN and a network outside the region, such as a VCN in another OCI region, an on-premises network, or a network in another cloud provider.
- Instance
pool
An instance pool is a group of instances within a region that are created from the same instance configuration and managed as a group.
- On-premises network
This is a local network used by your organization.
- Security list
For each subnet, you can create security rules that specify the source, destination, and type of traffic that is allowed in and out of the subnet.
- Security zone
Security zones implement key Oracle security best practices by enforcing policies for an entire compartment, such as encrypting data and preventing public access to networks. A security zone is associated with a compartment of the same name and includes security zone policies (a recipe) that applies to the compartment and its sub-compartments. You can't add or move a standard compartment to a security zone compartment.
(DRG)
- Service
gateway
A service gateway provides access from a VCN to other services, such as Oracle Cloud Infrastructure Object Storage. The traffic from the VCN to the Oracle service travels over the Oracle network fabric and does not traverse the internet.
- Tenancy
A tenancy is a secure and isolated partition that Oracle sets up within Oracle Cloud when you sign up for OCI. You can create, organize, and administer your resources on OCI within your tenancy. A tenancy is synonymous with a company or organization. Usually, a company will have a single tenancy and reflect its organizational structure within that tenancy. A single tenancy is usually associated with a single subscription, and a single subscription usually only has one tenancy.
- OCI LoggingOracle Cloud Infrastructure Logging is a highly-scalable and fully-managed service that provides access to the following types of logs from your resources in the cloud:
- Audit logs: Logs related to events produced by OCI Audit.
- Service logs: Logs published by individual services such as OCI API Gateway, OCI Events, OCI Functions, OCI Load Balancing, OCI Object Storage, and VCN flow logs.
- Custom logs: Logs that contain diagnostic information from custom applications, other cloud providers, or an on-premises environment.
- OCI Monitoring
Oracle Cloud Infrastructure Monitoring actively and passively monitors your cloud resources, and uses alarms to notify you when metrics meet specified triggers.
- Policy
An Oracle Cloud Infrastructure Identity and Access Management policy specifies who can access which resources, and how. Access is granted at the group and compartment level, which means you can write a policy that gives a group a specific type of access within a specific compartment or to the tenancy.
- OCI Vault
Oracle Cloud Infrastructure Vault enables you to create and centrally manage the encryption keys that protect your data and the secret credentials that you use to secure access to your resources in the cloud. The default key management is Oracle-managed keys. You can also use customer-managed keys which use OCI Vault. OCI Vault offers a rich set of REST APIs to manage vaults and keys.
- OCI Workflow
Oracle Cloud Infrastructure Workflow is a serverless workflow engine with a graphical flow designer for developers and architects. It accelerates the creation, running, and orchestration of OCI services such as OCI Functions or AI/ML.
- Virtual cloud network (VCN) and subnets
A virtual cloud network (VCN) is a customizable, software-defined network that you set up in an OCI region. Like traditional data center networks, VCNs give you control over your network environment. A VCN can have multiple non-overlapping classless inter-domain routing (CIDR) blocks that you can change after you create the VCN. You can segment a VCN into subnets, which can be scoped to a region or to an availability domain. Each subnet consists of a contiguous range of addresses that don't overlap with the other subnets in the VCN. You can change the size of a subnet after creation. A subnet can be public or private.
- OCI API Gateway
Oracle Cloud Infrastructure API Gateway enables you to publish APIs with private endpoints that are accessible from within your network, and which you can expose to the public internet if required. The endpoints support API validation, request and response transformation, CORS, authentication and authorization, and request limiting.
- Oracle Autonomous Database
Oracle Autonomous Database is a fully-managed, preconfigured database environment that you can use for transaction processing and data warehousing workloads. You do not need to configure or manage any hardware, or install any software. OCI handles creating, backing up, patching, upgrading, and tuning the database.
- Bastion host
The bastion host is a compute instance that serves as a secure, controlled entry point to the topology from outside the cloud. The bastion host is provisioned typically in a demilitarized zone (DMZ). It enables you to protect sensitive resources by placing them in private networks that can't be accessed directly from outside the cloud. The topology has a single, known entry point that you can monitor and audit regularly. So, you can avoid exposing the more sensitive components of the topology without compromising access to them.
- OCI Compute
With Oracle Cloud Infrastructure Compute, you can provision and manage compute hosts in the cloud. You can launch compute instances with shapes that meet your resource requirements for CPU, memory, network bandwidth, and storage. After creating a compute instance, you can access it securely, restart it, attach and detach volumes, and terminate it when you no longer need it.
- OCI DNS
Oracle Cloud Infrastructure Domain Name System (DNS) service is a highly scalable, global anycast domain name system (DNS) network that offers enhanced DNS performance, resiliency, and scalability, so that end users connect to internet applications quickly, from anywhere.
- Kafka Streams
Kafka Streams is a client library for building applications and microservices, where the input and output data are stored in Kafka clusters. It combines the simplicity of writing and deploying standard Java and Scala applications on the client side with the benefits of Kafka's server-side cluster technology.
- OCI Object Storage
OCI Object Storage provides access to large amounts of structured and unstructured data of any content type, including database backups, analytic data, and rich content such as images and videos. You can safely and securely store data directly from applications or from within the cloud platform. You can scale storage without experiencing any degradation in performance or service reliability.
Use standard storage for "hot" storage that you need to access quickly, immediately, and frequently. Use archive storage for "cold" storage that you retain for long periods of time and seldom or rarely access.
- Oracle Management Agent
Oracle Management Agent is a service that provides low latency interactive communication and data collection between Oracle Cloud Infrastructure and on premise managed instances. Management agents collects data from sources that you want to monitor. Management Agent Service, an Oracle Cloud Service, manages the lifecycle of the management agent and the plug-ins for the services.
- Oracle Cloud Agent
Oracle Cloud Agent is a lightweight process that manages the lifecycle of plug-ins running on compute instances on OCI. The JMS plug-ins collect Java metadata from your environment deployed on the managed instance in OCI. The JMS plug-in exfiltrates this Java metadata to the JMS service in OCI.
- Kiev as a Service (KaaS)
KaaS is a fully managed data platform service used primarily by Control Plane services on OCI. KaaS provides high-level NoSQL APIs for easy integration, serializable scans, change-feed streaming, and other features. KaaS is a service built on top of Kiev. Kiev is a "NoSQL key-value store" that also supports mini-transactions for convenience. To prevent concurrency bugs in applications, Kiev's mini-transactions have strong isolation which provides stronger guarantees than the weaker isolation levels that are commonly used in Oracle and MySQL. Kiev has an availability SLA of 99.9%.
About Required Services and Roles
This solution requires the following services and roles:
JMS integrates with Oracle Cloud Infrastructure Monitoring and Logging service for basic features.
- Java Management Service (JMS)
- Oracle Cloud Infrastructure (OCI)
- OCI Monitoring
- OCI Logging
- A dynamic group of managed instances (comprising of OCI compute instances and management agents). The dynamic group allows for policies to be applied collectively for communication with other OCI resources.
- JMS Fleet Manager User Group: A user group to use and manage JMS related resources.
- Managed Instance Dynamic Group: A dynamic group of managed instances (consisting of OCI compute instances and management agents). The dynamic group allows you to apply policies collectively for communication with other OCI resources.
- JMS server-components: A resource group of JMS backend components to interact with other OCI resources.
These are the roles needed for each service.
| Service Name: Role | Required to... |
| OCI OCI Identity and Access Management: administrator | create dynamic groups and govern access to OCI resources. |
| OCI: user administrator | manage users, groups, and group memberships for an identity domain. |
See Oracle Products, Solutions, and Services to get what you need.
