About Loading Oracle Cloud ERP Data into Snowflake
You can load data from Oracle Fusion Cloud
Enterprise Resource Planning (ERP) or other Oracle Fusion Cloud
Applications into various cloud storage solutions, such as Snowflake, using intermediaries like
Amazon S3, Azure Blob, or Google Cloud Storage. You can implement a multicloud strategy
and have the flexibility to utilize any data warehouse or cloud service provider for
your organizational needs.
In this solution, you consider the advantages and disadvantages of three architecture options, and identify and implement the architecture with the least tradeoffs in your organization.
Before You Begin
The primary tool for extracting data from Oracle Cloud
ERP is the Business Intelligence Cloud Connector (BICC), which loads the data into OCI Object Storage.
Before you begin configuring BICC, you must first set up BICC access using the Security Console in Oracle Fusion Cloud Applications.
About Required Services and Roles
This solution requires the following services and roles:
- Oracle Fusion Cloud Applications
- OCI GoldenGate
- OCI Object Storage
- OCI Vault
- Oracle Data Transforms
- Data Flow
- Data Science
- Snowflake
These are the roles needed for each service.
| Service Name: Role | Required to... |
| Oracle Fusion Cloud Applications: Security Manager | Access the Security Console of Oracle Fusion Cloud Applications. |
| Oracle Fusion Cloud Applications: ESS Administrator | Create and manage schedules for global data extracts or jobs. |
| Oracle Fusion Cloud Applications: ORA_ASM_APPLICATION_IMPLEMENTATION_ADMIN_ABSTRACT | Access global offerings and data stores or jobs. |
See Oracle Products, Solutions, and Services to get what you need.
