Deploy a Migrated MongoDB Workload to Oracle Exadata Database Machine
Workloads and applications that use documents and document databases to evolve data schemas and applications are popular due to the flexibility they offer to developers. Schema flexibility, rapid development, and scalability enable accelerated prototyping of application features, easier application evolution, and the ability to build iteratively smaller applications and features that developers can scale to address a large user base. However, these types of workloads have their challenges, including weaker transactional guarantees, data query versatility, and the inability to support other workloads on documents, such as analytics or machine learning.
What if these workloads can benefit from the advantages of traditional document databases and leverage the benefits of relational databases? For instance, have stronger transactional guarantees and added functionality such as analytics and machine learning, without the need to replicate data to another database or system.
Oracle Database 23ai, designed to simplify development for AI, microservices, graph, document, spatial, and relational applications, is a converged database platform offering everything that is needed in one powerful solution.
Oracle Exadata Database Machine is engineered to be the highest performing and most available platform for running Oracle Database. Exadata runs all types of database workloads including online transaction processing (OLTP), data warehousing (DW) and consolidation of mixed workloads. Simple and fast to implement, Exadata is designed to power and protect your most important databases and is an ideal foundation for Database as a Service.
Functional Architecture
This reference architecture focuses on deploying the migrated workload, and not the migration process. To learn more about the migration process, see the Explore More section.
One of the key features used in this architecture is the Oracle Database API for MongoDB, which lets applications interact with collections of JSON documents in Oracle Database using MongoDB commands. This enables existing application code to work with data stored in Oracle Database 23ai, without the need to refactor code.
The following diagram illustrates a typical application composed of a database, back-end tier, and front-end tier.
mongodb-logical-arch-migration.zip
A popular stack used to implement this pattern is the MEAN stack:
- MongoDB: Document database
- Express: Back-end framework
- Angular: Front-end framework
- Node.js: Back-end server
This architecture uses a MEAN stack as an example of an existing deployment to migrate to Oracle Database 23ai. The migration of this workload to Oracle Database 23ai consists of the following high-level steps:
- Deploy a highly available Oracle Database 23ai instance in Exadata across several database nodes, using Oracle Real Application Clusters (Oracle RAC).
- Migrate metadata and data from MongoDB to Oracle Database 23ai.
- Install and configure the back-end tier compute, whether that is VMs, containers, or Oracle REST Data Services.
- Configure Oracle REST Data Services to enable the MongoDB API so the application can communicate with the database using MongoDB drivers.
- Configure the application to use the new database connection string.
- Connect the backend application to Oracle Database 23ai using the same MongoDB tools and drivers used on the current application.
After migrating the workload to Oracle Database, you can enhance functionality by enabling additional features - such as improved security, operational reporting, analytics, and machine learning - without copying data out of the database. Oracle Database 23ai is a multi-model, multi-workload platform, which enables you to seamlessly integrate features that utilize relational, spatial, graph, or vector data types alongside your existing application.
To improve workload scalability, allocate more compute and memory to the database. Since Oracle Database 23ai is a multi-model, multi-workload database technology, additional features that rely on relational, spatial, graph, or vector data types can be added, working alongside the existing application.
Physical Architecture
Front-end tier
- The current deployment is used.
- Users can connect from the internet or the corporate network.
- DNS capability is configured to route requests to the standby data center in the event of failover.
Back-end tier
- Existing applications are deployed and used with the same compute instances.
- Customer-managed Oracle REST Data Services are colocated and deployed on the application servers. The application code can connect to Oracle Database 23ai through Oracle REST Data Services.
- Back-end tier scalability is achieved using the current scalability mechanism in place, implicitly scaling Oracle REST Data Services installed in each application server.
Database tier
- Oracle Database 23ai is deployed in Exadata, and is used to store and serve JSON documents to the back-end tier.
- The Oracle Database API for MongoDB is enabled using Oracle REST Data Services, which allows existing application code to be used without changes to code.
Business continuity
- Achieved using an Oracle Data Guard disaster recovery strategy.
- A warm disaster recovery strategy is assumed, with the back-end tier and associated resources already deployed and running.
The following diagram illustrates this reference architecture.
mongodb-exadata-machine-physical-arch.zip
The design for the physical architecture:
Business continuity
- There are two data centers with identical deployments: one active, the other on standby.
- DNS traffic steering directs user requests to the active data center. If the DNS health check probes executed on the application tier recurrently fail, DNS is reconfigured to route traffic to the standby data center workload.
- A load balancer distributes incoming requests across multiple back-end tier VMs, preventing a single point of failure.
- The back-end tier has several VMs handling user requests.
- Customer-managed Oracle REST Data Services is deployed and configured on the back-end tier VMs. As you add VMs, both the application server and Oracle REST Data Services scale automatically.
- The recovery time objective (RTO) is dependent not only on the database failover, but on complete failover to the rest of the workload components in the standby data center.
- Database RTO and RPO (recovery point objective) depend on the configured Oracle Data Guard protection mode.
- Database failover will leverage either Oracle Data Guard manual or automatic failover, depending on the business continuity detailed requirements.
Networking
- There is a public subnet that receives incoming user requests from the internet.
- Load balancer requests are routed to the back-end tier servers that serve user requests.
- The Exadata VM is attached to the client and administration networks.
- Back-end tier requests to the database via Oracle REST Data Services use client network addresses.
- The two data centers are interconnected with the bandwidth and low latency required to support an Oracle Data Guard configuration.
Database
- The Oracle Database 23ai is deployed in an Exadata VM cluster.
- The VM cluster uses several database nodes for high availability.
- Oracle RAC ensures the database uses several database nodes for the workload.
Security
- All data is secure in transit and at rest.
Potential design improvements not depicted on this deployment for simplicity's sake include:
- Use Active Data Guard to enable the standby database for read-only access and offload operational analytics queries.
Recommendations
- Application Deployment
Consider using a container-based deployment using Kubernetes if the application can run in containers. If containers are used, consider having a container image with the back-end code and customer-managed Oracle REST Data Services already installed.
- Security
Consider using Oracle Database Advanced Security Option features to encrypt data at rest and enable dynamic data redaction, an Oracle Database Enterprise Edition license is required to use Oracle Database Advanced Security Option.
- Observability
Consider using Oracle Data Safe to further increase the workload security posture and be able to perform database auditing.
- Application Evolution
- Consider deploying operational analytics and real-time reporting in Oracle Database 23ai using SQL and a frontend like Oracle APEX, keeping data within the database for trusted, real-time analysis.
- Consider using Oracle Database 23ai for machine learning using Oracle Machine Learning for SQL, to build and train models with JSON data without any need for data movement, and to deploy the models alongside the existing workload for efficient inferencing.
- Consider using the database to store additional data types (relational, vector, spatial or graph) for added workload functionality and flexibility.
- Consider using Exadata and Oracle Database 23ai for analytics beyond operational analytics, benefiting from the Hybrid Columnar Compression, an efficient columnar format tailored for data analytics, that increases analytics performance while reducing the space needed to store data. Hybrid Columnar Compression is supported in Exadata and is included with an Oracle Database Enterprise Edition license.
