Enable multicloud high availability and data protection across OCI and AWS with Colt
This architecture uses Oracle Data Guard and Colt to provide reliable failover for key databases in a multicloud environment that spans Oracle Cloud Infrastructure (OCI) and Amazon Web Services (AWS).
Maintaining business continuity and ensuring IT resiliency is a top priority for IT leaders today. Enterprises from every sector and industry are increasingly implementing multicloud solutions to benefit from best-in-class services, competitive pricing, agility, flexibility, and higher availability while enhancing risk management and avoiding vendor lock-in.
Colt is a global network provider offering private and secure interconnection to and between major public cloud providers. You can use Colt's multicloud services to set up private, reliable, low-latency, and high-bandwidth cross-cloud connectivity between a primary Oracle Database in AWS and a standby Oracle Database in Oracle Cloud Infrastructure.
Oracle Data Guard ensures high availability, data protection, and disaster recovery for mission-critical application data. With Data Guard, you can initiate failover of the primary database to the standby database either manually, by using the Data Guard Broker command-line interface (DGMGRL) or Oracle Enterprise Manager, or automatically, by configuring Fast-Start Failover (FSFO).
Architecture
This architecture shows a Data Guard configuration across OCI and AWS. Deploying a local standby database ensures high availability in the event of local failure and during planned maintenance. Standby databases across cloud providers ensure disaster recovery, higher resiliency, and simplify data migration.
The following diagram illustrates this reference architecture.
multicloud-failover-oci-aws-colt-oracle.zip
The architecture has the following components:
Oracle Cloud components
- RegionAn Oracle Cloud Infrastructure region is a localized geographic area that contains one or more data centers, called availability domains. Regions are independent of other regions, and vast distances can separate them (across countries or even continents).
- Availability domainsAvailability domains are standalone, independent data centers within a region. The physical resources in each availability domain are isolated from the resources in the other availability domains, which provides fault tolerance. Availability domains don’t share infrastructure such as power or cooling, or the internal availability domain network. So, a failure at one availability domain is unlikely to affect the other availability domains in the region.
- Virtual cloud network (VCN) and subnetsA VCN is a customizable, software-defined network that you set up in an Oracle Cloud Infrastructure region. Like traditional data center networks, VCNs give you complete control over your network environment. A VCN can have multiple non-overlapping CIDR blocks that you can change after you create the VCN. You can segment a VCN into subnets, which can be scoped to a region or to an availability domain. Each subnet consists of a contiguous range of addresses that don't overlap with the other subnets in the VCN. You can change the size of a subnet after creation. A subnet can be public or private.
- FastConnectOracle Cloud Infrastructure FastConnect provides an easy way to create a dedicated, private connection between your data center and Oracle Cloud Infrastructure. FastConnect provides higher-bandwidth options and a more reliable networking experience when compared with internet-based connections.
- Dynamic routing gateway (DRG)The DRG is a virtual router that provides a path for private network traffic between a VCN and a network outside the region, such as a VCN in another Oracle Cloud Infrastructure region, an on-premises network, or a network in another cloud provider.
- VM DB SystemOracle VM Database System is an Oracle Cloud Infrastructure (OCI) database service that enables you to build, scale, and manage full-featured Oracle databases on virtual machines. A VM database system uses OCI Block Volumes storage instead of local storage and can run Oracle Real Application Clusters (Oracle RAC) to improve availability.
- Data GuardOracle Data Guard provides a comprehensive set of services that create, maintain, manage, and monitor one or more standby databases to enable production Oracle databases to remain available without interruption. Oracle Data Guard maintains these standby databases as copies of the production database. Then, if the production database becomes unavailable because of a planned or an unplanned outage, Oracle Data Guard can switch any standby database to the production role, minimizing the downtime associated with the outage.
- ObserversObservers are Compute nodes that have the necessary Oracle Database software installed and configured to initiate FSFO of the Oracle Database in a Data Guard configuration. Having FSFO observers in the deployment removes the need for manual intervention when database failover is necessary and reduces the overall downtime.
- Object storageObject storage provides quick access to large amounts of structured and unstructured data of any content type, including database backups, analytic data, and rich content such as images and videos. You can safely and securely store and then retrieve data directly from the internet or from within the cloud platform. You can seamlessly scale storage without experiencing any degradation in performance or service reliability. Use standard storage for "hot" storage that you need to access quickly, immediately, and frequently. Use archive storage for "cold" storage that you retain for long periods of time and seldom or rarely access.
Amazon Web Services components
- RegionAn Amazon Web Services region is a localized geographic area that contains one or more data centers, called availability zones. Regions are independent of other regions, and vast distances can separate them (across countries or even continents).
- Availability zonesAn availability zone is one or more discrete data centers with redundant power, networking, and connectivity in an AWS Region. Availability zones give customers the ability to operate production applications and databases that are more highly available, fault tolerant, and scalable than would be possible from a single data center.
- Virtual private cloud (VPC)A virtual private cloud is a virtual network that you create in an Amazon Web Services region.
- Direct ConnectDirect Connect is a private network circuit between a VPC and a network outside AWS. It offers stable throughput and low latency, bypassing the public Internet. It is the AWS equivalent of Oracle Cloud Infrastructure FastConnect.
- Transit virtual interface (VIF)A transit virtual interface allows you to access one or more Amazon VPC Transit Gateways associated with Direct Connect gateways. You can use transit virtual interfaces with 1/2/5/10 Gbps AWS Direct Connect connections.
- Direct connect gateway (DGW)A direct connect gateway builds upon virtual private gateway capabilities, adding the ability to connect to up to 10 VPCs across regions.
- Transit Gateway (TGW)Transit Gateway connects virtual private clouds and on-premises networks through a central hub. This simplifies your network and puts an end to complex peering relationships. It acts as a cloud router, and each new connection is only made once.
- Amazon Simple Storage Service (Amazon S3) Amazon Simple Storage Service is the AWS equivalent of Oracle Cloud Object Storage Service. You can use it to store data such as Oracle Database backups.
Colt components
- The Colt IQ NetworkThe Colt IQ Network connects over 1000 data centers across Europe, Asia Pacific, North America, and Australia. It connects some of the world’s largest business hubs, with over 29,000 on-net buildings and growing. Colt has built its reputation on putting customers first. Colt's customers include data-intensive organizations that span over 213 cities in more than 30 countries. Colt is also a recognized innovator and pioneer in Software Defined Networks (SDN) and Network Function Virtualization (NFV).
- Circuit On-Ramp POPA Circuit On-Ramp POP is an exchange point where the circuit extending from the Cloud Provider infrastructure is connected to the Service Provider infrastructure. Colt has 225+ PoP locations distributed across its global Colt IQ Network. These are located as close to the major Cloud providers as possible, minimizing latency and benefiting business application performance. Usually, the interconnects between Colt and Oracle are shared NNIs which do not need physical cabling to be installed.
- Partner InterconnectThe circuit between the Cloud Provider and Colt PoP is referred to as a partner interconnect. This is usually a shared data center cross-connect or Ethernet circuit between Colt and Oracle (or other CSPs) and is sufficient for most use cases. Other dedicated interconnect options exist, but are not required for this architecture.
- IP GatewayColt hosts a global network of IP Gateways that are centrally controlled by an orchestrator and close to common cloud on-ramp locations. These Gateways are used to establish layer 3 connectivity to the CSP and use BGP to exchange routing prefixes. For a diverse design, you can use Multiple Gateway devices.
Recommendations
Use the following recommendations as a starting point to set up Oracle Data Guard for your multicloud environment. Your requirements might differ from the architecture described here.
- VCNSelect CIDR blocks that don't overlap with any other network (in Oracle Cloud Infrastructure, your on-premises data center, or another cloud provider) to which you intend to set up private connections.
- Choice of interconnection locationThis architecture requires one or more geographic locations for its components: the Oracle Cloud Infrastructure (OCI) region and associated Oracle Cloud Infrastructure FastConnect edge node, the Amazon Web Services (AWS) region and associated AWS Direct Connect edge node, and the Colt’s Circuit On-Ramp PoP location. To achieve the optimal end-to-end latency, we recommend that you select a metro that has each of these architectural elements in close proximity.
- PoP DiversityColt recommends using diverse partner interconnects when connecting to a city or region. This improves the level of geographic diversity by using different Colt PoP building locations.
- High availabilityThis architecture shows a redundant and resilient design that uses dual FastConnect connections and dual AWS Direct Connect or Azure ExpressRoute connections, which are routed via dual Colt IP Gateways. For application that are not production or that are not business critical, a single node architecture may suffice. To achieve the highest availability, we recommend that you deploy redundant network resources for each component of the architecture.
- Observer LocationAn FSFO best practice is to run the observer process on a host that is located in a different data center than both the primary and standby database. To achieve this, this reference architecture deploys a master and a backup observer in different data centers than those hosting the databases.
- Active Data GuardEnable Active Data Guard to benefit from advanced capabilities such as offloading production read-only workload to a synchronized standby, unique block corruption detection and automatic repair, rolling upgrade, fast incremental backups, and application continuity.
- Standby BackupsCreate database backups from the standby database to offload the backup overhead from the primary host.
- Fault domainsIn OCI regions with a single availability domain or AWS regions with a single availability zone, use different fault domains to host the primary database, the standby database, and the FSFO observer. A fault domain is a grouping of hardware and infrastructure within an availability domain. Each availability domain has three fault domains with independent power and hardware. When you distribute resources across multiple fault domains, your applications can tolerate physical server failure, system maintenance, and power failures inside a fault domain. Fault domains aren't shown in the architecture diagram.
Considerations
When implementing connectivity for a cross-cloud topology, consider the following factors:
- PerformanceThe IP Gateway can scale from 10 Mb/sec to 10 Gb/sec. Higher bandwidths can be supported as a bespoke requirement. Therefore, the Gateway can scale to support the highest data rates supported by the cloud service providers. The rate limit is an aggregate capacity that determines the speed for all connections through the Gateway.
- SecurityThe cross-cloud interconnection shown in this architecture is based on a private connection, which is more secure than the public internet. You can choose to encrypt this traffic, but it is not encrypted in this architecture.
- AvailabilityColt has 21 Oracle PoPs and 52 AWS PoPs across its network. Oracle and AWS are available in 8 locations: Los Angeles, London, Amsterdam (two locations), Ashburn, Frankfurt, Milan, and Stockholm.
- CostThe total cost of the cross-cloud interconnection depends on: - ColtThe number and bandwidth of the connections.
- Amazon Web ServicesThe AWS Direct Connect Port fee, the egress data transfer fee, and the cost of Amazon S3.
- OracleThe cost of Oracle Cloud Infrastructure FastConnect and Oracle Object Storage. There are no egress fees from Oracle Cloud Infrastructure.
- Colt
Deploy
The deployment is self-service through Colt. Deploying this reference architecture requires access to the Colt Portal, Oracle Cloud Portal, and Amazon Web Services Portal. Colt takes care of the OCI and AWS interconnection points.
