Deploy and Validate Solution Components
You need to deploy three different components to successfully transfer data between clouds. Once these components are deployed, you need to validate them to ensure the connection is established between Azure and OCI.
The components you need to deploy are:
- Azure ExpressRoute
- Oracle FastConnect
- Megaport Cloud Router (MCR)
Deploy Azure ExpressRoute
Log in to your Azure account and use this procedure to set up Azure ExpressRoute.
Before you begin, you need to meet the prerequistes described in
ExpressRoute prerequisites and checklist as described in "ExpressRoute prerequisites
& checklist", which you can access from the "Explore More" topic elsewhere in this
playbook.
Deploy FastConnect
Use this procedure to set up FastConnect in OCI.
Before you begin, you need to meet the prerequisites described in
FastConnect Requirements.
Deploy Megaport
OCI's private connection model is called
FastConnect. FastConnect provides private connectivity and self-service provisioning
including full API-level integration. When connecting to OCI through FastConnect with
Megaport, the Virtual Cross Connect (VXC) forms the Layer 2 component of the connection.
Layer 3 BGP connectivity is established directly between you and Oracle. The
following procedure shows how to create a Megaport connection.
Before you begin this procedure, ensure you've obtained an Azure service key and an Oracle Virtual Circuit ID.Validate the Deployments
Once deployed, you need to validate each component to ensure that these deployments were successful.
| This deployment... | Is validate when... |
| Megaport Cloud Router | While provisioning on both ExpressRoute and FastConnect, this status message: this service is waiting to come up for the first time. Once provisioning completes, click the Binoculars icon to view the different MCR Routes learned. It should show the subnet IPs from both the CSPs. |
| Microsoft Azure | The Interconnect Provider Status shows Provisioned rather than Not Provisioned. |
| Oracle FastConnect | FastConnect Status show Provisioned rather than Pending Partner. |
