Changing a Project Encryption Key (CLI)
You can change the encryption key for a project at any time, even while it is in use by client systems. Changing a project encryption key changes the key for shares that inherit the key from the project.
If the parent pool of the project is encrypted, the project inherits encryption keys from the parent pool by default. You can change a key for a project without changing the key for the parent pool.
