Configuring a Management Interface (CLI)
Use this procedure to configure a management, or administrative, interface.
Next Steps
If this is a clustered configuration, repeat this procedure on the second controller. Ownership of an interface is defined by the node that the interface was created on. If an interface is needed for the second controller in a cluster, create the interface on that second controller.
