Configuring a Management Interface (BUI)
Use this procedure to configure a management, or administrative, interface.
Next Steps
- If this is a clustered configuration, repeat this procedure on the second controller. Ownership of an interface is defined by the node that the interface was created on. If an interface is needed for the second controller in a cluster, create the interface on that second controller.
- To modify this interface, double-click the interface, or hover over the interface and click the edit icon
and make the changes, then click the APPLY button.
- To delete this interface, hover over the interface, click the delete icon
and confirm that you want to delete this interface.
When an interface is deleted, all routes associated with the interface are also removed.
