Configuring Management Interfaces
If you did not set a management interface during initial configuration, configure a network interface card (NIC) port as a management interface. A management interface is a network interface with administrative access.
All standalone controllers should have at least one NIC port configured as a management interface. All cluster installations should have at least one NIC port on each controller configured as a management interface.
Set the following configuration for clustered controllers:
The NIC instance number must be unique on each controller.
The management interfaces should be locked.
A management interface enables BUI connections on port 215 and CLI connections on
ssh port 22.
To configure management interfaces and lock cluster management interfaces, use the following procedures:
