Creating an IPMP Group Using Link-State Only Failure Detection (BUI)
Create one or more "underlying" IP interfaces with the IP address 0.0.0.0/8 to be used as the components of the IPMP group (see Creating a Single Port Interface (BUI)).
- From the Configuration menu, select Network, then Configuration.
- Click the Interface add item icon
. - Optional: Change the name of the interface.
- Click the IP MultiPathing Group check box.
- Click Use IPv4 Protocol or/and Use IPv6 Protocol and specify the IP addresses for the IPMP interface.
- Choose the interfaces created in the first step from the Interfaces list.
- Set each chosen interface to be either Active or Standby.
- Click APPLY.
