Creating a Single Port Interface (BUI)
Use this procedure to configure a single port network interface.
Before You Begin
At least one datalink must already exist. To create a datalink, see Configuring a Network Datalink (BUI).
Next Steps
- Repeat this procedure for as many IPs as needed. Ownership of an interface is defined by the node that the interface was created on. If this is a clustered configuration, create interfaces on the second controller.
 - To modify this interface, double-click the interface or hover over the interface and click the edit icon
 , make the changes, and click the APPLY button.
                      - To delete this interface, hover over the interface, click the delete icon
 , and confirm that you want to delete this interface.
When an interface is deleted, all routes associated with the interface are also removed.
