PreviousNext
JavaScript must be enabled to correctly display this content
Downloading Workflows Using the CLI
Use the following procedure to download workflows using the CLI.
Workflows are downloaded to Oracle ZFS Storage Appliance via the download command, which is similar to the mechanism used for software updates:
hostname:maintenance workflows> download
hostname:maintenance workflows download (uncommitted)> get
url = (unset)
user = (unset)
password = (unset)
You must set the url property to be a valid URL for the workflow. This may be either local to your network or over the internet. The URL can be either HTTP (beginning with "http://") or FTP (beginning with "ftp://"). If user authentication is required, it may be a part of the URL (for example, "ftp://myusername:mypasswd@myserver/export/foo"), or you may leave the username and password out of the URL and instead set the user and password properties.
hostname:maintenance workflows download (uncommitted)> set url=ftp://foo/example1.akwf
url = ftp://foo/example1.akwf
hostname:maintenance workflows download (uncommitted)> set user=bmc
user = bmc
hostname:maintenance workflows download (uncommitted)> set password
Enter password:
password = (set)
hostname:maintenance workflows download (uncommitted)> commit
Transferred 138 of 138 (100%) ... done
