Listing Workflows Using the CLI
Use the following procedure to list workflows using the CLI.
  1. To list workflows, use the list command from the maintenance workflows context:
    hostname:maintenance workflows> list
    WORKFLOW     NAME                           OWNER SETID ORIGIN        VERSION
    workflow-018 Check metaslab_unload_delay    root  false Oracle ZFSSA  1.0
    workflow-019 Check metaslab_unload_timeout  root  false Oracle ZFSSA  1.0
    workflow-020 Example 9                      root  true  <local>       1.0
    workflow-021 Set DNLC size and ncsize       root  false Data and App  2.0
    workflow-022 Stop Existing SSH Sessions     root  false <local>       0.2
  2. To select a workflow, use the select command:
    hostname:maintenance workflows> select workflow-018
    hostname:maintenance workflow-018>
  3. To get a workflow's properties, use the get command from within the context of the selected workflow:
    hostname:maintenance workflow-018> get
                              name = Check metaslab_unload_delay
                       description = Check the value of the metaslab_unload_delay property
                              uuid = uuid
                          checksum = checksum
                       installdate = 2019-5-8 20:54:33
                             owner = root
                            origin = Oracle ZFSSA
                             setid = false
                             alert = false
                           version = 1.0
                         scheduled = true
    The owner property identifies the owner of the workflow. Changing the owner property changes the user identity associated with the workflow. To change the owner of a workflow, the user must already be permitted to modify the workflow and must also have the appropriate workflow.<target_owner>.*.changeOwner authorization as described in Workflow Authorizations. Changing the owner property does not clear the setid property. If setid is set to true, the workflow continues to execute as its owner after the ownership change.
