PreviousNext
JavaScript must be enabled to correctly display this content
Monitoring Replication Progress (BUI)
Use the following procedure to monitor replication progress.
From the Shares menu, select Projects, and select the replicated project, or select a project and then select the replicated share.
Click the Replication tab.
The replication initial stages are displayed below the progress bar.
The different stages are:
Connecting to replication target
Receiving checkpoint from replication target
Estimating size of update
Building deduplication tables
After the replication action is sending data, you can view the percentage of bytes sent,
estimated size, average throughput, and estimated remaining time.
