Monitoring Replication Progress (CLI) Use the following procedure to monitor replication progress. Navigate to the project or share, and enter the replication node. hostname:shares> select TestProj hostname:shares TestProj> replication hostname:shares TestProj replication> Select the replication action, then enter get: hostname:shares TestProj replication> select action-000 hostname:shares TestProj action-000> get Properties: id = aed46331-160b-48ec-8727-dcd563adbd78 target_id = 4fd3483e-b1f5-4bdc-9be3-b3a4becd0c42 target = target1 enabled = true continuous = false include_snaps = true retain_user_snaps_on_target = false dedup = true include_clone_origin_as_data = false max_bandwidth = unlimited bytes_sent = 0 estimated_size = 0 estimated_time_left = 00:00:00 average_throughput = 0B/s use_ssl = true compression = on export_path = state = sending state_description = Connecting to replication target export_pending = false offline = false next_update = Sync now replica_data_timestamp = Thu Apr 25 2019 22:18:11 GMT+0000 (UTC) last_sync = <unknown> last_try = <unknown> last_result = <unknown> replica_lag = 00:00:09 recovery_point_objective = replica_lag_warning_alert = replica_lag_error_alert = replica_lag_over_warning_limit = false replica_lag_over_error_limit = false Review property state_description for information on replication progress. The different states are: Connecting to replication target Receiving checkpoint from target Estimating size of update Building deduplication tables Sending update State Building deduplication tables is displayed only if the project or share has deduplication enabled. If state_description is Sending update, determine the replication progress by reviewing the following properties: bytes_sent estimated_size estimated_time_left average_throughput Related Topics Replication Audit Actions Using Replication Analytics Deduplicated Replication
