Setting the Appliance Default Certificate (BUI)
Use this procedure to set the default certificate for this appliance.
- From the Configuration menu, select Settings, then Certificates, and click the System tab.
- From the System default certificate menu, select the certificate that you want to set as the default for this appliance.
- Click APPLY.
