Setting the Appliance Default Certificate (CLI) Use this procedure to set the default certificate for this appliance. To view all certificate entries, go to the configuration settings certificates system context, and enter the list command. To set a certificate as the default, use the default command. hostname:configuration settings certificates system> set default=cert-002 default= cert-002 (uncommitted) hostname:configuration settings certificates system> commit
