- Oracle ZFS Storage Appliance Administration Guide, Release OS8.8.x
- Configuring the Appliance
- Configuring Storage
- Viewing Pool and Device Status (CLI)
Use the following procedure to view pool and device status.
- Go to
configuration storage
.The default pool is selected and displayed.
- Optional: If you have multiple pools, select a different pool to view.
If the default pool is not the pool that you want to view, enter
set pool=
and specify another online pool.hostname:configuration storage (pool0)> set pool=pool1 pool = pool1
- Enter
show
.- See the table in step 2 of Viewing Pool and Device Status (BUI) for a description of the pool status value.
- See the table in step 4 of Viewing Pool and Device Status (BUI) for a description of the device status value.
View pool encryption properties.
- If the appliance is at software release OS8.8.0 or later and the Enable Pool Encryption deferred update is applied (see Enable Pool Encryption Deferred Update in Oracle ZFS Storage Appliance Customer Service Manual, Release OS8.8.x), an
ENCRYPTED
column is displayed. - If a pool is not encrypted, then the value of the
ENCRYPTED
column is a hyphen (-
) and the value of theencryption
property isoff
. - If a pool is encrypted, then the
ENCRYPTED
column displays the encryption type. See Encryption Properties. - If the selected pool is encrypted, then the
encryption
property displays the encryption type. In addition, the following four properties are displayed:keystatus
- Eitheravailable
orunavailable
. If the value of thekeystatus
property isunavailable
, then the key has been deleted.keychangedate
- The date the key was last changed. If the value of thekeychangedate
property is blank, then the key value has not been changed since the pool was created.keyname
- The name of the key.keystore
- The name of the keystore.
hostname:configuration storage (pool1)> ls Pools: POOL OWNER DATA PROFILE LOG PROFILE STATUS ERRS ENCRYPTED ->pool1 hostname mirror - online 0 aes-128-ccm pool2 hostname mirror - online 0 - pool3 hostname stripe - online 0 - Properties: pool = pool1 status = online errors = 0 profile = mirror log_profile = - cache_profile = - meta_profile = - retainedfileystems = 1 retentionexpiry = 2022-05-16-20:20:35 (expired) scrub = none requested async_destroy_reclaim_space = 0 encryption = aes-128-ccm keystatus = available keychangedate = keyname = MyKey keystore = LOCAL
If a pool is not encrypted, the four
key
values do not display but are still available by using theget
orscript
commands. - If the appliance is at software release OS8.8.0 or later and the Enable Pool Encryption deferred update is applied (see Enable Pool Encryption Deferred Update in Oracle ZFS Storage Appliance Customer Service Manual, Release OS8.8.x), an
- To see more detailed pool and device error information, go to
maintenance problems
for active errors, ormaintenance logs
for a history of all problems.
