Base Cabinet Configurations for Oracle ZFS Storage Appliance Racked System ZS5-2 Performance Configurations
Oracle ZFS Storage Appliance Racked System ZS5-2 maximum performance configurations require two SAS-3 HBAs, which provide the maximum of eight ports of SAS-3 HBA connectivity.
The SAS-3 HBA port numbering order is ascending, from bottom (Port 0) to top (Port 3). Both SAS-3 HBA cards and Oracle Storage Drive Enclosure DE3-24 disk shelves use the SFF 8644 connectors.
Oracle ZFS Storage ZS5-2 Controller HBA Slot Numbers (Back View)
![This image shows the Oracle ZFS Storage ZS5-2 back panel with HBA slot numbers. This image shows the Oracle ZFS Storage ZS5-2 back panel with HBA slot numbers.](img/5-2_hbas.png)
Oracle Storage Drive Enclosure DE3-24P Disk Shelf HBA Connections (Back View)
![This image shows the Oracle Storage Drive Enclosure DE3-24P back panel with HBA connections. This image shows the Oracle Storage Drive Enclosure DE3-24P back panel with HBA connections.](img/de3_24p-rear-150dpi.jpg)
Oracle Storage Drive Enclosure DE3-24C Disk Shelf HBA Connections (Back View)
![This image shows the Oracle Storage Drive Enclosure DE3-24C back panel with HBA connections. This image shows the Oracle Storage Drive Enclosure DE3-24C back panel with HBA connections.](img/de3_port.png)
The Oracle ZFS Storage Appliance Racked System ZS5-2 cabling configurations follow standard cabling methodologies with additional restrictions that allow use of the cable management arm (CMA). They provide a more practical implementation for SSD log device and read cache device matching, and can be configured for maximum or optimal performance.
Any upgrades that change the number of SAS-3 HBA cards, or include more than one cabinet that is not an original Oracle ZFS Storage Appliance Racked System ZS5-2 or not compatible with Oracle ZFS Storage Appliance Racked System ZS5-2 must be re-cabled for that particular configuration. For cabling examples of connecting Oracle Storage Drive Enclosure DE3-24 disk shelves to an Oracle ZFS Storage ZS5-2 controller with 4x4 port SAS-3 HBAs, see Cabling Oracle Storage Drive Enclosure DE3-24 Disk Shelves to Oracle ZFS Storage ZS5-2 Controllers. For SAS cable length guidelines, see Cabinet and Cabling Guidelines.
The cabinets are self-contained and pre-cabled following the required cabling methodology. The following diagrams illustrate how the five base cabinet options are cabled.
Four Oracle Storage Drive Enclosure DE3-24P All-Flash Disk Shelves (maximum performance)
![This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with four Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains. This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with four Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains.](img/5-2_4_rs.png)
16 Oracle Storage Drive Enclosure DE3-24P Disk Shelves (optimum performance)
![This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with 16 Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains. This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with 16 Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains.](img/5-2_16_rs.png)
Two Oracle Storage Drive Enclosure DE3-24C (bottom left) and
12 Oracle Storage Drive Enclosure DE3-24P Disk Shelves (optimum performance)
![This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with two Oracle Storage Drive Enclosure DE3-24C (bottom left) and 12 Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains. This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with two Oracle Storage Drive Enclosure DE3-24C (bottom left) and 12 Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains.](img/5-2_14_rs.png)
Four Oracle Storage Drive Enclosure DE3-24C (bottom left) and
Eight Oracle Storage Drive Enclosure DE3-24P Disk Shelves (optimum performance)
![This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with four Oracle Storage Drive Enclosure DE3-24C (bottom left) and eight Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains. This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with four Oracle Storage Drive Enclosure DE3-24C (bottom left) and eight Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains.](img/5-2_12_rs.png)
Six Oracle Storage Drive Enclosure DE3-24C (first two chains from the left) and
Four Oracle Storage Drive Enclosure DE3-24P Disk Shelves (optimum performance)
![This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with six Oracle Storage Drive Enclosure DE3-24C (first two chains from the left) and four Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains. This image shows Oracle ZFS Storage Appliance Racked System ZS5-2 all-flash with six Oracle Storage Drive Enclosure DE3-24C (first two chains from the left) and four Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains.](img/5-2_10_rs.png)
