Base Cabinet Configurations for Oracle ZFS Storage Appliance Racked System ZS9-2 MR with All-Flash/Mixed Configurations
Oracle ZFS Storage Appliance Racked System ZS9-2 MR all-flash/mixed configurations have two SAS-3 HBAs in each controller, which provide the maximum of eight ports of SAS-3 HBA connectivity.
The SAS-3 HBA port numbering order is ascending, from bottom (Port 0) to top (Port 3). Both SAS-3 HBA cards and Oracle Storage Drive Enclosure DE3-24/DE3-12C disk shelves use the SFF 8644 connectors.
The following figure shows the slot number for each HBA card, as well as the port numbers in each card.
![This graphic shows Oracle ZFS Storage ZS9-2 MR Back Panel with HBA Slot Numbers. This graphic shows Oracle ZFS Storage ZS9-2 MR Back Panel with HBA Slot Numbers.](img/g7722_zs9-2-mr-rear-panel-hbas_rev02.jpg)
As shown in the following figure, the Oracle Storage Drive Enclosure DE3-24P disk shelf has two I/O modules (IOMs) with four ports each. In all cabling configurations, Port 1 and Port 3 are never used.
![This image shows the Oracle Storage Drive Enclosure DE3-24P back panel with HBA connections. This image shows the Oracle Storage Drive Enclosure DE3-24P back panel with HBA connections.](img/de3_24p-rear-150dpi.jpg)
As shown in the following figure, the Oracle Storage Drive Enclosure DE3-24C disk shelf has two I/O modules (IOMs) with four ports each. In all cabling configurations, Port 1 and Port 3 are never used.
![This image shows the Oracle Storage Drive Enclosure DE3-24C back panel with HBA connections. This image shows the Oracle Storage Drive Enclosure DE3-24C back panel with HBA connections.](img/de3_port.png)
As shown in the following figure, the Oracle Storage Drive Enclosure DE3-12C disk shelf has two I/O modules (IOMs) with three ports each. In all cabling configurations, Port B is never used.
![This graphic shows the disk shelf rear panel, with I/O Module ports labeled. The top I/O Module shows, from left to right, ports A, B, and C. The bottom I/O Module shows, from left to right, ports C, B, and A. This graphic shows the disk shelf rear panel, with I/O Module ports labeled. The top I/O Module shows, from left to right, ports A, B, and C. The bottom I/O Module shows, from left to right, ports C, B, and A.](img/aog-624_de3-c12_cable-rear-iom-ports.png)
The Oracle ZFS Storage Appliance Racked System ZS9-2 MR cabling configurations follow standard cabling methodologies with additional restrictions that allow use of the cable management arm (CMA). They provide a more practical implementation for SSD log device and read cache device matching, and can be configured for maximum or optimal performance.
Any upgrades that include more than one cabinet that is not an original Oracle ZFS Storage Appliance Racked System ZS9-2 MR or not compatible with Oracle ZFS Storage Appliance Racked System ZS9-2 MR must be re-cabled for that particular configuration. For cabling examples of connecting Oracle Storage Drive Enclosure DE3-24 disk shelves to an Oracle ZFS Storage ZS9-2 MR controller with 4x4 port SAS-3 HBAs, see Cabling Oracle Storage Drive Enclosure DE3-24 Disk Shelves to Oracle ZFS Storage ZS9-2 Mid-range (MR) Controllers. For cabling examples of connecting Oracle Storage Drive Enclosure DE3-12C disk shelves to an Oracle ZFS Storage ZS9-2 MR controller with 4x4 port SAS-3 HBAs, see Example Mixed Disk Shelf Configurations. For SAS cable length guidelines, see Cabinet and Cabling Guidelines.
The cabinets are self-contained and pre-cabled following the required cabling methodology. The following diagrams illustrate how the six base cabinet options are cabled for configurations with Oracle Storage Drive Enclosure DE3-24C disk shelves.
Four Oracle Storage Drive Enclosure DE3-24P Disk Shelves (maximum performance)
![This image shows Oracle ZFS Storage Appliance Racked System ZS9-2 MR with four Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains. This image shows Oracle ZFS Storage Appliance Racked System ZS9-2 MR with four Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains.](img/5-2_4_rs.png)
This configuration can have one, two, or four Oracle Storage Drive Enclosure DE3-24P disk shelves utilizing the maximum performance cabling scheme.
18 Oracle Storage Drive Enclosure DE3-24P Disk Shelves (optimum performance)
![This figure shows the Oracle ZFS Storage Appliance Racked System ZS9-2 MR performance configuration with 18 Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains. This figure shows the Oracle ZFS Storage Appliance Racked System ZS9-2 MR performance configuration with 18 Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains.](img/7-2_18_rs.png)
Oracle Storage Drive Enclosure DE3-24P disk shelves in this configuration are added in pairs. Any other combination of disk shelves are added by pairs starting at the bottom of the rack. Valid disk shelf count combinations are 2, 4, 6, 8, 10, 12, 14, 16, and 18 disk shelves.
Two Oracle Storage Drive Enclosure DE3-24C (bottom left) and
Two Oracle Storage Drive Enclosure DE3-24P to 14 DE3-24P Disk Shelves (optimum performance)
![This figure shows the Oracle ZFS Storage Appliance Racked System ZS9-2 MR performance configuration with 2 Oracle Storage Drive Enclosure DE3-24C disk shelves, and 2 to 14 Oracle Storage Drive Enclosure DE3-24P disk shelves in 4 chains. This figure shows the Oracle ZFS Storage Appliance Racked System ZS9-2 MR performance configuration with 2 Oracle Storage Drive Enclosure DE3-24C disk shelves, and 2 to 14 Oracle Storage Drive Enclosure DE3-24P disk shelves in 4 chains.](img/7-2mrrs_2-2-14.png)
Oracle Storage Drive Enclosure DE3-24P disk shelves in this configuration are added in pairs. Any other combination of disk shelves are added by pairs starting at the bottom of the rack. Valid disk shelf count combinations are 2, 4, 6, 8, 10, 12, 14, and 16 disk shelves.
Four Oracle Storage Drive Enclosure DE3-24C (bottom left) and
Two Oracle Storage Drive Enclosure DE3-24P to Ten DE3-24P Disk Shelves (optimum performance)
![This figure shows the Oracle ZFS Storage Appliance Racked System ZS9-2 MR performance configuration with 4 Oracle Storage Drive Enclosure DE3-24C disk shelves, and 2 to 10 Oracle Storage Drive Enclosure DE3-24P disk shelves in 4 chains. This figure shows the Oracle ZFS Storage Appliance Racked System ZS9-2 MR performance configuration with 4 Oracle Storage Drive Enclosure DE3-24C disk shelves, and 2 to 10 Oracle Storage Drive Enclosure DE3-24P disk shelves in 4 chains.](img/7-2mrrs_4-2-10.png)
Six Oracle Storage Drive Enclosure DE3-24C (first two chains from the left) and
Two Oracle Storage Drive Enclosure DE3-24P to Six DE3-24P Disk Shelves (optimum performance)
![This image shows Oracle ZFS Storage Appliance Racked System ZS9-2 MR all-flash with six Oracle Storage Drive Enclosure DE3-24C, and two Oracle Storage Drive Enclosure DE3-24P to six DE3-24P disk shelves in four chains. This image shows Oracle ZFS Storage Appliance Racked System ZS9-2 MR all-flash with six Oracle Storage Drive Enclosure DE3-24C, and two Oracle Storage Drive Enclosure DE3-24P to six DE3-24P disk shelves in four chains.](img/7-2mrrs_6-2-6.png)
Eight Oracle Storage Drive Enclosure DE3-24C (first two chains from the left) and
Two Oracle Storage Drive Enclosure DE3-24P Disk Shelves (optimum performance)
![This image shows Oracle ZFS Storage Appliance Racked System ZS9-2 MR with eight Oracle Storage Drive Enclosure DE3-24C, and two Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains. This image shows Oracle ZFS Storage Appliance Racked System ZS9-2 MR with eight Oracle Storage Drive Enclosure DE3-24C, and two Oracle Storage Drive Enclosure DE3-24P disk shelves in four chains.](img/7-2mrrs_8-2.png)
