Cabling Tables and Diagrams for Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configurations
The following table describes the locations and port connections for two controllers and eight disk shelves in the base cabinet, using 3-meter SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs.
Table 11-2 Base Cabinet: Controller and Disk Shelf Locations and Connections
FROM | TO | ||||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF |
DISK SHELF PORT |
20 |
1 |
Slot 3, Port 0 |
1 |
1 |
IOM 1, Port 2 |
17 |
0 |
Slot 6, Port 0 |
1 |
1 |
IOM 0, Port 2 |
20 |
1 |
Slot 7, Port 0 |
23 |
3 |
IOM 1, Port 2 |
17 |
0 |
Slot 9, Port 0 |
23 |
3 |
IOM 0, Port 2 |
17 |
0 |
Slot 3, Port 0 |
5, 13 |
2, 6 |
IOM 1, Port 0 |
20 |
1 |
Slot 6, Port 0 |
5, 13 |
2, 6 |
IOM 0, Port 0 |
17 |
0 |
Slot 7, Port 0 |
27, 35 |
4, 8 |
IOM 1, Port 0 |
20 |
1 |
Slot 9, Port 0 |
27, 35 |
4, 8 |
IOM 0, Port 0 |
The following table describes the locations and port connections for 10 disk shelves in Expansion Cabinet 1, using 6-meter SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs. Expansion Cabinet 1 supports disk shelves 9 through 18.
Table 11-3 Expansion Cabinet 1: Controller and Disk Shelf Locations and Connections
FROM | TO | ||||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF |
DISK SHELF PORT |
20 |
1 |
Slot 3, Port 1 |
1 |
9 |
IOM 1, Port 2 |
17 |
0 |
Slot 6, Port 1 |
1 |
9 |
IOM 0, Port 2 |
20 |
1 |
Slot 7, Port 1 |
21 |
11 |
IOM 1, Port 2 |
17 |
0 |
Slot 9, Port 1 |
21 |
11 |
IOM 0, Port 2 |
17 |
0 |
Slot 3, Port 1 |
5, 9, 13, 17 |
10, 13, 14, 17 |
IOM 1, Port 0 |
20 |
1 |
Slot 6, Port 1 |
5, 9, 13, 17 |
10, 13, 14, 17 |
IOM 0, Port 0 |
17 |
0 |
Slot 7, Port 1 |
25, 33, 37 |
12, 16, 18 |
IOM 1, Port 0 |
20 |
1 |
Slot 9, Port 1 |
25, 33, 37 |
12, 16, 18 |
IOM 0, Port 0 |
The following table describes the locations and port connections for 10 disk shelves in Expansion Cabinet 2, using 6-meter SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs. Expansion Cabinet 2 supports disk shelves 19 through 28.
Table 11-4 Expansion Cabinet 2: Controller and Disk Shelf Locations and Connections
FROM | TO | ||||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF |
DISK SHELF PORT |
20 |
1 |
Slot 3, Port 2 |
1 |
19 |
IOM 1, Port 2 |
17 |
0 |
Slot 6, Port 2 |
1 |
19 |
IOM 0, Port 2 |
20 |
1 |
Slot 7, Port 2 |
21 |
21 |
IOM 1, Port 2 |
17 |
0 |
Slot 9, Port 2 |
21 |
21 |
IOM 0, Port 2 |
17 |
0 |
Slot 3, Port 2 |
5, 9, 13, 17 |
20, 23, 24, 27 |
IOM 1, Port 0 |
20 |
1 |
Slot 6, Port 2 |
5, 9, 13, 17 |
20, 23, 24, 27 |
IOM 0, Port 0 |
17 |
0 |
Slot 7, Port 2 |
25, 33, 37 |
22, 26, 28 |
IOM 1, Port 0 |
20 |
1 |
Slot 9, Port 2 |
25, 33, 37 |
22, 26, 28 |
IOM 0, Port 0 |
The following table describes the locations and port connections for 10 disk shelves in Expansion Cabinet 3, using 6-meter SAS cables. The first disk shelf is located in RU01, and each disk shelf has two IOMs. Expansion Cabinet 2 supports disk shelves 29 through 38.
Table 11-5 Expansion Cabinet 3: Controller and Disk Shelf Locations and Connections
FROM | TO | ||||
RU |
CONTROLLER |
HBA PORT |
RU |
DISK SHELF |
DISK SHELF PORT |
20 |
1 |
Slot 3, Port 3 |
1 |
29 |
IOM 1, Port 2 |
17 |
0 |
Slot 6, Port 3 |
1 |
29 |
IOM 0, Port 2 |
20 |
1 |
Slot 7, Port 3 |
21 |
31 |
IOM 1, Port 2 |
17 |
0 |
Slot 9, Port 3 |
21 |
31 |
IOM 0, Port 2 |
17 |
0 |
Slot 3, Port 3 |
5, 9, 13, 17 |
30, 33, 34, 37 |
IOM 1, Port 0 |
20 |
1 |
Slot 6, Port 3 |
5, 9, 13, 17 |
30, 33, 34, 37 |
IOM 0, Port 0 |
17 |
0 |
Slot 7, Port 3 |
25, 33, 37 |
32, 36, 38 |
IOM 1, Port 0 |
20 |
1 |
Slot 9, Port 3 |
25, 33, 37 |
32, 36, 38 |
IOM 0, Port 0 |
The following diagrams illustrate how pre-racked systems are cabled, as well as how to expand your system in the future. The legend for each diagram is as follows:
A hollow circle indicates the cable connection to the top IOM (IOM 1).
A solid circle indicates the cable connection to the bottom IOM (IOM 0).
10 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 10 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 10 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_10.png)
12 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 12 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 12 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_12.png)
13 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack)
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 13 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack) Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 13 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack)](img/5-4_13.png)
14 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 14 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 14 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_14.png)
16 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 16 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 16 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_16.png)
18 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 18 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 18 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_18.png)
20 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 20 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 20 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_20.png)
22 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 22 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 22 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_22.png)
23 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack)
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 23 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack) Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 23 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack)](img/5-4_23.png)
24 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 24 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 24 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_24.png)
26 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 26 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 26 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_26.png)
28 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 28 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 28 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_28.png)
30 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 30 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 30 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_30.png)
32 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 32 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 32 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_32.png)
33 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack)
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 33 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack) Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 33 Oracle Storage Drive Enclosure DE3-24C Disk Shelves (Half Rack)](img/5-4_33.png)
34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 34 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_34.png)
36 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 36 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 36 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_36.png)
38 Oracle Storage Drive Enclosure DE3-24C Disk Shelves
![Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 38 Oracle Storage Drive Enclosure DE3-24C Disk Shelves Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configuration: 38 Oracle Storage Drive Enclosure DE3-24C Disk Shelves](img/5-4_38.png)
