Overview of Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configurations
Capacity configurations take advantage of high-capacity disk shelves and are available in a base cabinet, or a base cabinet with up to three expansion cabinets. Two Oracle ZFS Storage ZS5-4 controllers and up to 38 disk shelves can be supported, as shown in the following table.
Table 11-1 Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configurations Components
Base Cabinet | Expansion Cabinet 1 | Expansion Cabinet 2 | Expansion Cabinet 3 |
Up to 8 Oracle Storage Drive Enclosure DE3-24C disk shelves Two Oracle ZFS Storage ZS5-4 controllers |
Up to 10 Oracle Storage Drive Enclosure DE3-24C disk shelves |
Configurations are offered in multiples of two disk shelves, as well as half-rack expansion: 2 disk shelves (minimum), 4, 6, 8, 10, 12, 13 (half rack), 14, 16, 18, 20, 22, 23 (half rack), 24, 26, 28, 30, 32, 33 (half rack), 34, 36, and 38 (maximum).
Each Oracle ZFS Storage ZS5-4 controller supports two, three, or four SAS HBA cards. Four SAS HBA cards must be installed in each Oracle ZFS Storage ZS5-4 controller to support disk shelves in the expansion cabinet(s).
Clustered Oracle ZFS Storage ZS5-4 controllers that contain four SAS HBAs each support a high-availability configuration consisting of:
Two chains of four disk shelves per disk chain in the base cabinet for a total of eight disk shelves, and
One to three expansion cabinets, each cabinet supporting two chains with a maximum of five disk shelves per disk chain, for a total of 10 disk shelves for one expansion cabinet, 20 disk shelves for two expansion cabinets, or 30 disk shelves for three expansion cabinets.
The cabinets are self-contained and pre-cabled following the required cabling methodology. Pre-racked system cabling tables and diagrams, which can also be used for planning future system expansion, are provided in the section Cabling Tables and Diagrams for Oracle ZFS Storage Appliance Racked System ZS5-4 Capacity Configurations.
Each cabinet contains 42 rack units (RUs), with RU01 on the bottom. Each Oracle ZFS Storage ZS5-4 controller occupies three rack units, and its location is referenced by the bottommost rack unit number. The top controller is referred to as Controller 1 and is located in RU20 in the base cabinet, and the bottom controller is Controller 0 in RU17. The following figure shows the slot number for each HBA card, as well as the port numbers in each card.
![This graphic shows Oracle ZFS Storage ZS5-4 Back Panel with HBA Slot Numbers. This graphic shows Oracle ZFS Storage ZS5-4 Back Panel with HBA Slot Numbers.](img/5-4_hbas.png)
Each Oracle Storage Drive Enclosure DE3-24C disk shelf occupies four rack units, and disk shelves are normally installed from the bottom of the cabinet to the top for stability. To provide higher performance capabilities, disk chains are alternated from the bottom to the top of the base cabinet, with four disk shelves per chain and gaps between components. Therefore, the first disk shelf is in RU01, the second in RU05, the third in RU23, the fourth in RU27, the fifth in RU09, and so on in an alternating manner. As shown in the following figure, the Oracle Storage Drive Enclosure DE3-24C disk shelf has two I/O Modules (IOMs) with four ports each. In all cabling configurations, Port 1 and Port 3 are never used.
![This graphic shows Oracle Storage Drive Enclosure DE3-24C Back Panel with HBA Connections. This graphic shows Oracle Storage Drive Enclosure DE3-24C Back Panel with HBA Connections.](img/de3_port.png)
