Oracle ZFS Storage ZS4-4 Rear Panel Components
The Oracle ZFS Storage ZS4-4 rear panel is shown in the following figure. Base configuration PCIe cards are not depicted in this illustration. For more information about PCIe cards, see Oracle ZFS Storage ZS4-4 PCIe I/O Cards in Oracle ZFS Storage Appliance Customer Service Manual, Release OS8.8.x.
1 Power supply unit (PSU) 0 indicator panel |
2 PSU 0 AC inlet |
3 PSU 1 indicator panel |
4 PSU 1 AC inlet |
5 System status indicator panel |
6 PCIe card slots 1-6 |
7 Network (NET) 10 GbE ports: NET 0, NET 1, NET 2, NET 3 |
8 USB 2.0 connectors (2) |
9 PCIe card slots 7-11 |
10 Network management (NET MGT) 10/100/1000 BASE-T Ethernet port |
11 Serial management (SER MGT) RJ-45 port |
12 DB-15 video port |
PCIe Slots - The Oracle ZFS Storage ZS4-4 base configuration contains the following PCIe cards:
Slot 2 - One 8-port SAS-2 internal HBA
Slot 4 - One cluster interface card
Slots 6 and 7 - Two 4-port (4x4) SAS external HBAs
For information about PCIe slot order, see Oracle ZFS Storage ZS4-4 PCIe I/O Cards in Oracle ZFS Storage Appliance Customer Service Manual, Release OS8.8.x.
Ethernet Ports - Oracle ZFS Storage ZS4-4 has four RJ-45 10-Gigabit Ethernet (10GbE) network connectors on the rear panel, labeled NET 0, NET 1, NET 2, and NET 3 (bottom left to top right), as shown in the following figure. Use these ports to connect the appliance to the network.
The LEDs located above the NET ports, labeled 2, 0, 3, 1 (left to right) are Link/Activity indicators.
OFF (1)
No Link
ON (0)
Link and no activity
Blink
Link and activity
Speed is not indicated for the NET ports. -
Network Management Port - The network management connector (NET MGT) is an RJ-45 10/100/1000 BASE-T Ethernet port and provides an alternate terminal interface to the service processor (SP) console.
Serial Management Port - The serial management connector (SER MGT) is an RJ-45 port and provides a terminal connection to the SP console.
HBA Ports - The 4x4 SAS HBA provides connectivity to external Oracle Storage Drive Enclosure DEx-24 disk shelves. The HBA logical ports are numbered 0-3, bottom to top.
