11 Message Capture Properties
This chapter explains the options available for configuration of the property file for the Oracle GoldenGate for Java VAM.
This chapter includes the following sections:
11.1 Logging and Connection Properties
The following properties control the connection to JMS and the log file names, error handling, and message output.
11.1.1 Logging Properties
Logging is controlled by the following properties.
11.1.1.1 gg.log
Specifies the type of logging that is to be used. The default implementation is the JDK option. This is the built-in Java logging called java.util.logging (JUL). The other logging options are log4j or logback. The syntax is:
gg.log={JDK|log4j|logback}
For example, you set the logging implementation to log4j, which is the preferred logging method, as follows:
gg.log=log4j
The log file is created in the report subdirectory of the installation. The default log file name includes the group name of the associated Extract and the file extension is log.
11.1.1.2 gg.log.level
Specifies the overall log level for all modules. The syntax is:
gg.log.level={ERROR|WARN|INFO|DEBUG}
The log levels are defined as follows:
  • ERROR – Only write messages if errors occur
  • WARN – Write error and warning messages
  • INFO – Write error, warning and informational messages
  • DEBUG – Write all messages, including debug ones.
The default logging level is INFO. The messages in this case will be produced on startup, shutdown and periodically during operation. If the level is switched to DEBUG, large volumes of messages may occur which could impact performance. For example, the following sets the global logging level to INFO:
# global logging level
gg.log.level=INFO
11.1.1.3 gg.log.file
Specifies the path to the log file. The syntax is:
gg.log.file=path_to_file
Where the path_to_file is the fully defined location of the log file. This allows a change to the name of the log, but you must include the Extract name if you have more than one Extract to avoid one overwriting the log of the other.
11.1.1.4 gg.log.classpath
Specifies the class path to the jars used to implement logging.
gg.log.classpath=path_to_jars
11.1.2 JMS Connection Properties
The JMS connection properties set up the connection, such as how to start up the JVM for JMS integration.
11.1.2.1 jvm.boot options
Specifies the class path and boot options that will be applied when the JVM starts up. The path needs colon (:) separators for UNIX/Linux and semicolons (;) for Windows.
The syntax is:
jvm.bootoptions=option[, option][. . .]
The options are the same as those passed to Java executed from the command line. They may include class path, system properties, and JVM memory options (such as maximum memory or initial memory) that are valid for the version of Java being used. Valid options may vary based on the JVM version and provider.
For example (all on a single line):
jvm.bootoptions= -Djava.class.path=ggjava/ggjava.jar
-Dlog4j.configuration=my-log4j.properties
The log4j.configuration property could be a fully qualified URL to a log4j properties file; by default this file is searched for in the class path. You may use your own log4j configuration, or one of the pre-configured log4j settings: log4j.properties (default level of logging), debug-log4j.properties (debug logging) or trace-log4j.properties (very verbose logging).
11.1.2.2 jms.report.output
Specifies where the JMS report is written. The syntax is:
jms.report.output={report|log|both}
Where:
  • report sends the JMS report to the Oracle GoldenGate report file. This is the default.
  • log will write to the Java log file (if one is configured)
  • both will send to both locations.
11.1.2.3 jms.report.time
Specifies the frequency of report generation based on time.
jms.report.time=time_specification
The following examples write a report every 30 seconds, 45 minutes and eight hours.
jms.report.time=30sec
jms.report.time=45min
jms.report.time=8hr
11.1.2.4 jms.report.records
Specifies the frequency of report generation based on number of records. The syntax is:
jms.report.records=number
The following example writes a report every 1000 records.
jms.report.records=1000
11.1.2.5 jms.id
Specifies that a unique identifier with the indicated format is passed back from the JMS integration to the message capture VAM. This may be used by the VAM as a unique sequence ID for records.
jms.id={ogg|time|wmq|activemq|message_header|custom_java_class}
Where:
  • ogg - returns the message header property GG_ID which is set by Oracle GoldenGate JMS delivery.
  • time - uses a system timestamp as a starting point for the message ID
  • wmq - reformats a WebSphere MQ Message ID for use with the VAM
  • activemq - reformats an ActiveMQ Message ID for use with the VAM
  • message_header - specifies the user customized JMS message header to be included, such as JMSMessageID, JMSCorrelationID, or JMSTimestamp.
  • custom_java_class - specifies a custom Java class that creates a string to be used as an ID.
For example:
jms.id=time
jms.id=JMSMessageID
The ID returned must be unique, incrementing, and fixed-width. If there are duplicate numbers, the duplicates are skipped. If the message ID changes length, the Extract process will abend.
11.1.2.6 jms.destination
Specifies the queue or topic name to be looked up via JNDI.
jms.destination=jndi_name
For example:
jms.destination=sampleQ
11.1.2.7 jms.connectionFactory
Specifies the connection factory name to be looked up via JNDI.
jms.connectionFactory=jndi_name
For example
jms.connectionFactory=ConnectionFactory
11.1.2.8 jms.user, jms.password
Sets the user name and password of the JMS connection, as specified by the JMS provider.
jms.user=user_name
jms.password=password
This is not used for JNDI security. To set JNDI authentication, see the JNDI java.naming.security properties.
For example:
jms.user=myuser
jms.password=mypasswd
11.1.3 JNDI Properties
In addition to specific properties for the message capture VAM, the JMS integration also supports setting JNDI properties required for connection to an Initial Context to look up the connection factory and destination. The following properties must be set:
java.naming.provider.url=url
java.naming.factory.initial=java_class_name
If JNDI security is enabled, the following properties may be set:
java.naming.security.principal=user_name
java.naming.security.credentials=password_or_other_authenticator
For example:
java.naming.provider.url= t3://localhost:7001
java.naming.factory.initial=weblogic.jndi.WLInitialContextFactory
java.naming.security.principal=jndiuser
java.naming.security.credentials=jndipw
11.2 Parser Properties
Properties specify the formats of the message and the translation rules for each type of parser: fixed, delimited, or XML. Set the parser.type property to specify which parser to use. The remaining properties are parser specific.
11.2.1 Setting the Type of Parser
The following property sets the parser type.
11.2.1.1 parser.type
Specifies the parser to use.
parser.type={fixed|delim|xml}
Where:
  • fixed invokes the fixed width parser
  • delim invokes the delimited parser
  • xml invokes the XML parser
For example:
parser.type=delim
11.2.2 Fixed Parser Properties
The following properties are required for the fixed parser.
11.2.2.1 fixed.schematype
Specifies the type of file used as metadata for message capture. The two valid options are sourcedefs and copybook.
fixed.schematype={sourcedefs|copybook}
For example:
fixed.schematype=copybook
The value of this property determines the other properties that must be set in order to successfully parse the incoming data.
11.2.2.2 fixed.sourcedefs
If the fixed.schematype=sourcedefs, this property specifies the location of the source definitions file that is to be used.
fixed.sourcedefs=file_location
For example:
fixed.sourcedefs=dirdef/hrdemo.def
11.2.2.3 fixed.copybook
If the fixed.schematype=copybook, this property specifies the location of the copybook file to be used by the message capture process.
fixed.copybook=file_location
For example:
fixed.copybook=test_copy_book.cpy
11.2.2.4 fixed.header
Specifies the name of the sourcedefs entry or copybook record that contains header information used to determine the data block structure:
fixed.header=record_name
For example:
fixed.header=HEADER
11.2.2.5 fixed.seqid
Specifies the name of the header field, JMS property, or system value that contains the seqid used to uniquely identify individual records. This value must be continually incrementing and the last character must be the least significant.
fixed.seqid={field_name|$jms_property|*seqid}
Where:
  • field_name indicates the name of a header field containing the seqid
  • jms_property uses the value of the specified JMS header property. A special value of this is $jmsid which uses the value returned by the mechanism chosen by the jms.id property
  • seqid indicates a simple incrementing 64-bit integer generated by the system
For example:
fixed.seqid=$jmsid
11.2.2.6 fixed.timestamp
Specifies the name of the field, JMS property, or system value that contains the timestamp.
fixed.timestamp={field_name|$jms_property|*ts}
For example:
fixed.timestamp=TIMESTAMP
fixed.timestamp=$JMSTimeStamp
fixed.timestamp=*ts
11.2.2.7 fixed.timestamp.format
Specifies the format of the timestamp field.
fixed.timestamp.format=format
Where the format can include punctuation characters plus:
  • YYYY – four digit year
  • YY – two digit year
  • M[M] – one or two digit month
  • D[D] – one or two digit day
  • HH – hours in twenty four hour notation
  • MI – minutes
  • SS – seconds
  • Fn – n number of fractions
The default format is "YYYY-MM-DD:HH:MI:SS.FFF"
For example:
fixed.timestamp.format=YYYY-MM-DD-HH.MI.SS
11.2.2.8 fixed.txid
Specifies the name of the field, JMS property, or system value that contains the txid used to uniquely identify transactions. This value must increment for each transaction.
fixed.txid={field_name|$jms_property|*txid}
For most cases using the system value of *txid is preferred.
For example:
fixed.txid=$JMSTxId
fixed.txid=*txid
11.2.2.9 fixed.txowner
Specifies the name of the field, JMS property, or static value that contains a user name associated with a transaction. This value may be used to exclude certain transactions from processing. This is an optional property.
fixed.txowner={field_name|$jms_property|"value"}
For example:
fixed.txowner=$MessageOwner
fixed.txowner="jsmith"
11.2.2.10 fixed.txname
Specifies the name of the field, JMS property, or static value that contains an arbitrary name to be associated with a transaction. This is an optional property.
fixed.txname={field_name|$jms_property|"value"}
For example:
fixed.txname="fixedtx"
11.2.2.11 fixed.optype
Specifies the name of the field, or JMS property that contains the operation type, which is validated against the fixed.optype values specified in the next sections.
fixed.header.optype={field_name|$jms_property}
For example:
fixed.header.optype=FUNCTION
11.2.2.12 fixed.optype.insertval
This value identifies an insert operation. The default is I.
fixed.optype.insertval={value|\xhex_value}
For example:
fixed.optype.insertval=A
11.2.2.13 fixed.optype.updateval
This value identifies an update operation. The default is U.
fixed.optype.updateval={value|\xhex_value}
For example:
fixed.optype.updateval=M
11.2.2.14 fixed.optype.deleteval
This value identifies a delete operation.The default is D.
fixed.optype.deleteval={value|\xhex_value}
For example:
fixed.optype.deleteval=R
11.2.2.15 fixed.table
Specifies the name of the table. This enables the parser to find the data record definition needed to translate the non-header data portion.
fixed.table=field_name|$jms_property[, . . .]
More than one comma delimited field name may be used to determine the name of the table Each field name corresponds to a field in the header record defined by the fixed.header property or JMS property. The values of these fields are concatenated to identify the data record.
For example:
fixed.table=$JMSTableName
fixed.table=SOURCE_Db,SOURCE_Db_Rec_Version
11.2.2.16 fixed.schema
Specifies the static name of the schema when generating SCHEMA.TABLE table names.
fixed.schema="value"
For example:
fixed.schema="OGG"
11.2.2.17 fixed.txind
Specifies the name of the field or JMS property that contains a transaction indicator that is validated against the transaction indicator values. If this is not defined, all operations within a single message will be seen to have occurred within a whole transaction. If defined, then it determines the beginning, middle and end of transactions. Transactions defined in this way can span messages. This is an optional property.
fixed.txind={field_name|$jms_property}
For example:
fixed.txind=$TX_IND
11.2.2.18 fixed.txind.beginval
This value identifies an operation as the beginning of a transaction. The defaults is B.
fixed.txind.beginval={value|\xhex_value}
For example:
fixed.txind.beginval=0
11.2.2.19 fixed.txind.middleval
This value identifies an operation as the middle of a transaction. The default is M.
fixed.txind.middleval={value|\xhex_value}
For example:
fixed.txind.middleval=1
11.2.2.20 fixed.txind.endval
This value identifies an operation as the end of a transaction. The default is E.
fixed.txind.endval={value|\xhex_value}
For example:
fixed.txind.endval=2
11.2.2.21 fixed.txind.wholeval
This value identifies an operation as a whole transaction. The default is W.
fixed.txind.wholeval={value|\xhex_value}
For example:
fixed.txind.wholeval=3
11.2.3 Delimited Parser Properties
The following properties are required for the delimited parser except where otherwise noted.
11.2.3.1 delim.sourcedefs
Specifies the location of the source definitions file to use.
delim.sourcedefs=file_location
For example:
delim.sourcedefs=dirdef/hrdemo.def
11.2.3.2 delim.header
Specifies the list of values that come before the data and assigns names to each.
delim.header=name[,name2][. . .]
The names must be unique. They can be referenced in other delim properties or wherever header fields can be used.
For example:
delim.header=optype, tablename, ts
delim.timestamp=ts
11.2.3.3 delim.seqid
Specifies the name of the header field, JMS property, or system value that contains the seqid used to uniquely identify individual records. This value must increment and the last character must be the least significant.
delim.seqid={field_name|$jms_property|*seqid}
Where:
  • jms_property uses the value of the specified JMS header property, a special value of this is $jmsid which uses the value returned by the mechanism chosen by the jms.id property
  • seqid indicates a simple continually incrementing 64-bit integer generated by the system
For example:
delim.seqid=$jmsid
11.2.3.4 delim.timestamp
Specifies the name of the JMS property, header field, or system value that contains the timestamp.
delim.timestamp={field_name|$jms_property|*ts}
For example:
delim.timestamp=TIMESTAMP
delim.timestamp=$JMSTimeStamp
delim.timestamp=*ts
11.2.3.5 delim.timestamp.format
delim.timestamp.format=format
  • MI – minutes
  • SS – seconds
For example:
delim.timestamp.format=YYYY-MM-DD-HH.MI.SS
11.2.3.6 delim.txid
Specifies the name of the JMS property, header field, or system value that contains the txid used to uniquely identify transactions. This value must increment for each transaction.
delim.txid={field_name|$jms_property|*txid}
For example:
delim.txid=$JMSTxId
delim.txid=*txid
11.2.3.7 delim.txowner
Specifies the name of the JMS property, header field, or static value that contains an arbitrary user name associated with a transaction. This value may be used to exclude certain transactions from processing. This is an optional property.
delim.txowner={field_name|$jms_property|"value"}
For example:
delim.txowner=$MessageOwner
delim.txowner="jsmith"
11.2.3.8 delim.txname
Specifies the name of the JMS property, header field, or static value that contains an arbitrary name to be associated with a transaction. This is an optional property.
delim.txname={field_name|$jms_property|"value"}
For example:
delim.txname="fixedtx"
11.2.3.9 delim.optype
Specifies the name of the JMS property or header field that contains the operation type. This is compared to the values for delim.optype.insertval, delim.optype.updateval and delim.optype.deleteval to determine the operation.
delim.optype={field_name|$jms_property}
For example:
delim.optype=optype
11.2.3.10 delim.optype.insertval
delim.optype.insertval={value|\xhex_value}
For example:
delim.optype.insertval=A
11.2.3.11 delim.optype.updateval
delim.optype.updateval={value|\xhex_value}
For example:
delim.optype.updateval=M
11.2.3.12 delim.optype.deleteval
This value identifies a delete operation. The default is D.
delim.optype.deleteval={value|\xhex_value}
For example:
delim.optype.deleteval=R
11.2.3.13 delim.schemaandtable
Specifies the name of the JMS property or header field that contains the schema and table name in the form SCHEMA.TABLE.
delim.schemaandtable={field_name|$jms_property}
For example:
delim.schemaandtable=$FullTableName
11.2.3.14 delim.schema
Specifies the name of the JMS property, header field, or hard-coded value that contains the schema name.
delim.schema={field_name|$jms_property|"value"}
For example:
delim.schema="OGG"
11.2.3.15 delim.table
Specifies the name of the JMS property or header field that contains the table name.
delim.table={field_name|$jms_property}
For example:
delim.table=TABLE_NAME
11.2.3.16 delim.txind
Specifies the name of the JMS property or header field that contains the transaction indicator to be validated against beginval, middleval, endval or wholeval. All operations within a single message will be seen as within one transaction if this property is not set. If it is set it determines the beginning, middle and end of transactions. Transactions defined in this way can span messages. This is an optional property.
delim.txind={field_name|$jms_property}
For example:
delim.txind=txind
11.2.3.17 delim.txind.beginval
The value that identifies an operation as the beginning of a transaction. The default is B.
delim.txind.beginval={value|\xhex_value}
For example:
delim.txind.beginval=0
11.2.3.18 delim.txind.middleval
The value that identifies an operation as the middle of a transaction. The default is M.
delim.txind.middleval={value|\xhex_value}
For example:
delim.txind.middleval=1
11.2.3.19 delim.txind.endval
The value that identifies an operation as the end of a transaction. The default is E.
delim.txind.endval={value|\xhex_value}
For example:
delim.txind.endval=2
11.2.3.20 delim.txind.wholeval
The value that identifies an operation as a whole transaction. The default is W.
delim.txind.wholeval={value|\xhex_value}
For example:
delim.txind.wholeval=3
11.2.3.21 delim.fielddelim
Specifies the delimiter value used to separate fields (columns) in the data. This value is defined through characters or hexadecimal values:
delim.fielddelim={value|\xhex_value}
For example:
delim.fielddelim=,
delim.fielddelim=\xc7
11.2.3.22 delim.linedelim
Specifies the delimiter value used to separate lines (records) in the data. This value is defined using characters or hexadecimal values.
delim.linedelim={value|\xhex_value}
For example:
delim.linedelim=||
delim.linedelim=\x0a
11.2.3.23 delim.quote
Specifies the value used to identify quoted data. This value is defined using characters or hexadecimal values.
delim.quote={value|\xhex_value}
For example:
delim.quote="
11.2.3.24 delim.nullindicator
Specifies the value used to identify NULL data. This value is defined using characters or hexadecimal values.
delim.nullindicator={value|\xhex_value}
For example:
delim.nullindicator=NULL
11.2.3.25 delim.fielddelim.escaped
Specifies the value that will replace the field delimiter when the field delimiter occurs in the input field. The syntax is:
delim.fielddelim.escaped={value|\xhex_value}
For example, given the following property settings:
delim.fielddelim=-
delim.fielddelim.escaped=$#$
If the data does not contain the hyphen delimiter within any of the field values:
one two three four
The resulting delimited data is:
one-two-three-four
If there are hyphen (-) delimiters within the field values:
one two three four-fifths two-fifths
one-two-three-four$#$fifths-two$#$fifths
11.2.3.26 delim.linedelim.escaped
Specifies the value that will replace the line delimiter when the line delimiter occurs in the input data. The syntax is:
delim.linedelim.escaped={value|\xhex_value}
delim.linedelim=\
delim.linedelim.escaped=%/%
If the input lines are:
These are the lines and they
do not contain the delimiter.
Because the lines do not contain the backslash (\) , the result is:
These are the lines and they\
do not contain the delimiter.\
However, if the input lines do contain the delimiter:
These are the lines\data values
and they do contain the delimiter.
So the results are:
These are the lines%/%data values\
and they do contain the delimiter.\
11.2.3.27 delim.quote.escaped
Specifies the value that will replace a quote delimiter when the quote delimiter occurs in the input data. The syntax is:
delim.quote.escaped={value|\xhex_value}
delim.quote="
delim.quote.escaped="'"
If the input data does not contain the quote (") delimiter:
It was a very original play.
The result is:
"It was a very original play."
However, if the input data does contain the quote delimiter:
It was an "uber-original" play.
The result is:
"It was an "'"uber-original"'" play."
11.2.3.28 delim.nullindicator.escaped
Specifies the value that will replace a null indicator when a null indicator occurs in the input data. The syntax is:
delim.nullindicator.escaped={value|\xhex_value}
delim.fielddelim=,
delim.nullindicator.escaped=$NULL$
When the input data does not contain a NULL value or a NULL indicator:
1 2 3 4 5
The result is
1,2,3,4,5
When the input data contains a NULL value:
1 2 4 5
The result is
1,2,NULL,4,5
When the input data contains a NULL indicator:
1 2 NULL 4 5
The result is:
1,2,$NULL$,4,5
11.2.3.29 delim.hasbefores
Specifies whether before values are present in the data.
delim.hasbefores={true|false}
The default is false. The parser expects to find before and after values of columns for all records if delim.hasbefores is set to true. The before values are used for updates and deletes, the after values for updates and inserts. The afterfirst property specifies whether the before images are before the after images or after them. If delim.hasbefores is false, then no before values are expected.
For example:
delim.hasbefores=true
11.2.3.30 delim.hasnames
Specifies whether column names are present in the data.
delim.hasnames={true|false}
The default is false. If true, the parser expects to find column names for all records. The parser validates the column names against the expected column names. If false, no column names are expected.
For example:
delim.hasnames=true
11.2.3.31 delim.afterfirst
Specifies whether after values are positioned before or after the before values.
delim.afterfirst={true|false}
The default is false. If true, the parser expects to find the after values before the before values. If false, the after values are before the before values.
For example:
delim.afterfirst=true
11.2.3.32 delim.isgrouped
Specifies whether the column names and before and after images should be expected grouped together for all columns or interleaved for each column.
delim.isgrouped={true|false}
The default is false. If true, the parser expects find a group of column names (if hasnames is true), followed by a group of before values (if hasbefores), followed by a group of after values (the afterfirst setting will reverse the before and after value order). If false, the parser will expect to find a column name (if hasnames), before value (if hasbefores) and after value for each column.
For example:
delim.isgrouped=true
11.2.3.33 delim.dateformat | delim.dateformat.table | delim.dateform.table.column
Specifies the date format for column data. This is specified at a global level, table level or column level.The format used to parse the date is a subset of the formats used for parser.timestamp.format.
delim.dateformat=format
delim.dateformat.TABLE=format
delim.dateformat.TABLE.COLUMN=format
Where:
  • format is the format defined for parser.timestamp.format.
  • table is the fully qualified name of the table that is currently being processed.
  • column is a column of the specified table.
For example:
delim.dateformat=YYYY-MM-DD HH:MI:SS
delim.dateformat.MY.TABLE=DD/MM/YY-HH.MI.SS
delim.dateformat.MY.TABLE.EXP_DATE=YYMM
11.2.4 XML Parser Properties
The following properties are used by the XML parser.
11.2.4.1 xml.sourcedefs
Specifies the location of the source definitions file.
xml.sourcedefs=file_location
For example:
xml.sourcedefs=dirdef/hrdemo.def
11.2.4.2 xml.rules
Specifies the list of XML rules for parsing a message and converting to transactions, operations and columns:
xml.rules=xml_rule_name[, . . .]
The specified XML rules are processed in the order listed. All rules matching a particular XML document may result in the creation of transactions, operations and columns. The specified XML rules should be transaction or operation type rules.
For example:
xml.rules=dyntxrule, statoprule
11.2.4.3 rulename.type
Specifies the type of XML rule.
rulename.type={tx|op|col}
Where:
  • tx indicates a transaction rule
  • op indicates an operation rule
  • col indicates a column rule
For example:
dyntxrule.type=tx
statoprule.type=op
11.2.4.4 rulename.match
Specifies an XPath expression used to determine whether the rule is activated for a particular document or not.
rulename.match=xpath_expression
If the XPath expression returns any nodes from the document, the rule matches and further processing occurs. If it does not return any nodes, the rule is ignored for that document.
The following example activates the dyntxrule if the document has a root element of Transaction
dyntxrule.match=/Transaction
Where statoprule is a subrule of stattxtule, the following example activates the statoprule if the parent rule's matching nodes have child elements of NewMyTableEntry.
statoprule.match=./NewMyTableEntry
11.2.4.5 rulename.subrules
Specifies a list of rule names to check for matches if the parent rule is activated by its match.
rulename.subrules=xml_rule_name[, . . .]
The specified XML rules are processed in the order listed. All matching rules may result in the creation of transactions, operations and columns.
Valid sub-rules are determined by the parent type. Transaction rules can only have operation sub-rules. Operation rules can have operation or column sub-rules. Column rules cannot have sub-rules.
For example:
dyntxrule.subrules=dynoprule
statoprule.subrules=statkeycolrule, statcol1rule
11.2.4.6 txrule.timestamp
Controls the transaction timestamp by instructing the adapter to 1) use the transaction commit timestamp contained in a specified XPath expression or JMS property or 2) use the current system time. This is an optional property.
txrule.timestamp={xpath_expression|$jms_property|*ts}
The timestamp for the transaction may be overridden at the operation level, or may only be present at the operation level. Any XPath expression must end with a value accessor such as @att or text().
For example:
dyntxrule.timestamp=@ts
11.2.4.7 txrule.timestamp.format
txrule.timestamp.format=format
  • MI – minutes
  • SS – seconds
For example:
dyntxrule.timestamp.format=YYYY-MM-DD-HH.MI.SS
11.2.4.8 txrule.seqid
Specifies the seqid for a particular transaction. This can be used when there are multiple transactions per message. Determines the XPath expression, JMS property, or system value that contains the transactions seqid. Any XPath expression must end with a value accessor such as @att or text().
txrule.seqid={xpath_expression|$jms_property|*seqid}
For example:
dyntxrule.seqid=@seqid
11.2.4.9 txrule.txid
Specifies the XPath expression, JMS property, or system value that contains the txid used to unique identify transactions. This value must increment for each transaction.
txrule.txid={xpath_expression|$jms_property|*txid}
For example:
dyntxrule.txid=$JMSTxId
dyntxrule.txid=*txid
11.2.4.10 txrule.txowner
Specifies the XPath expression, JMS property, or static value that contains an arbitrary user name associated with a transaction. This value may be used to exclude certain transactions from processing.
txrule.txowner={xpath_expression|$jms_property|"value"}
For example:
dyntxrule.txowner=$MessageOwner
dyntxrule.txowner="jsmith"
11.2.4.11 txrule.txname
Specifies the XPath expression, JMS property, or static value that contains an arbitrary name to be associated with a transaction. This is an optional property.
txrule.txname={xpath_expression|$jms_property|"value"}
For example:
dyntxrule.txname="fixedtx"
11.2.4.12 oprule.timestamp
Controls the operation timestamp by instructing the adapter to 1) use the transaction commit timestamp contained in a specified XPath expression or JMS property or 2) use the current system time. This is an optional property.
oprule.timestamp={xpath_expression|$jms_property|*ts}
The timestamp for the operation will override a timestamp at the transaction level.
For example:
statoprule.timestamp=./CreateTime/text()
11.2.4.13 oprule.timestamp.format
oprule.timestamp.format=format
  • MI – minutes
  • SS – seconds
For example:
statoprule.timestamp.format=YYYY-MM-DD-HH.MI.SS
11.2.4.14 oprule.seqid
Specifies the seqid for a particular operation. Use the XPath expression, JMS property, or system value that contains the operation seqid. This overrides any seqid defined in parent transaction rules. Must be present if there is no parent transaction rule.
oprule.seqid={xpath_expression|$jms_property|*seqid}
For example:
dynoprule.seqid=@seqid
11.2.4.15 oprule.txid
Specifies the XPath expression, JMS property, or system value that contains the txid used to uniquely identify transactions. This overrides any txid defined in parent transaction rules and is required if there is no parent transaction rule. The value must be incremented for each transaction.
oprule.txid={xpath_expression|$jms_property|*txid}
For example:
dynoprule.txid=$JMSTxId
dynoprule.txid=*txid
11.2.4.16 oprule.txowner
Specifies the XPath expression, JMS property, or static value that contains an arbitrary user name associated with a transaction. This value may be used to exclude certain transactions from processing. This is an optional property.
oprule.txowner={xpath_expression|$jms_property|"value"}
For example:
dynoprule.txowner=$MessageOwner
dynoprule.txowner="jsmith"
11.2.4.17 oprule.txname
oprule.txname={xpath_expression|$jms_property|"value"}
For example:
dynoprule.txname="fixedtx"
11.2.4.18 oprule.schemandtable
Specifies the XPath expression JMS property or hard-coded value that contains the schema and table name in the form SCHEMA.TABLE. Any XPath expression must end with a value accessor such as @att or text(). The value is verified to ensure the table exists in the source definitions.
oprule.schemaandtable={xpath_expression|$jms_property|"value"}
For example:
statoprule.schemaandtable="MY.TABLE"
11.2.4.19 oprule.schema
Specifies the XPath expression, JMS property or hard-coded value that contains the schema name. Any XPath expression must end with a value accessor such as @att or text().
oprule.schema={xpath_expression|$jms_property|"value"}
For example:
statoprule.schema=@schema
11.2.4.20 oprule.table
Specifies the XPath expression, JMS property or hard-coded value that contains the table name. Any XPath expression must end with a value accessor such as @att or text().
oprule.table={xpath_expression|$jms_property|"value"}
For example:
statoprule.table=$TableName
11.2.4.21 oprule.optype
Specifies the XPath expression, JMS property or literal value that contains the optype to be validated against an optype insertval, etc. Any XPath expression must end with a value accessor such as @att or text().
oprule.optype={xpath_expression|$jms_property|"value"}
For example:
dynoprule.optype=@type
statoprule.optype="I"
11.2.4.22 oprule.optype.insertval
Specifies the value that identifies an insert operation. The default is I.
oprule.optype.insertval={value|\xhex_value}
For example:
dynoprule.optype.insertval=A
11.2.4.23 oprule.optype.updateval
Specifies the value that identifies an update operation. The default is U.
oprule.optype.updateval={value|\xhex_value}
For example:
dynoprule.optype.updateval=M
11.2.4.24 oprule.optype.deleteval
Specifies the value that identifies a delete operation. The default is D.
oprule.optype.deleteval={value|\xhex_value}
For example:
dynoprule.optype.deleteval=R
11.2.4.25 oprule.txind
Specifies the XPath expression or JMS property that contains the transaction indicator to be validated against beginval or other value that identifies the position within the transaction. All operations within a single message are regarded as occurring within a whole transaction if this property is not defined. Specifies the begin, middle and end of transactions. Any XPath expression must end with a value accessor such as @att or text(). Transactions defined in this way can span messages. This is an optional property.
oprule.txind={xpath_expression|$jms_property}
For example:
dynoprule.txind=@txind
11.2.4.26 oprule.txind.beginval
Specifies the value that identifies an operation as the beginning of a transaction. The default is B.
oprule.txind.beginval={value|\xhex_value}
For example:
dynoprule.txind.beginval=0
11.2.4.27 oprule.txind.middleval
Specifies the value that identifies an operation as the middle of a transaction. The default is M.
oprule.txind.middleval={value|\xhex_value}
For example:
dynoprule.txind.middleval=1
11.2.4.28 oprule.txind.endval
Specifies the value that identifies an operation as the end of a transaction. The default is E.
oprule.txind.endval={value|\xhex_value}
For example:
dynoprule.txind.endval=2
11.2.4.29 oprule.txind.wholeval
Specifies the value that identifies an operation as a whole transaction. The default is W.
oprule.txind.wholeval={value|\xhex_value}
For example:
dynoprule.txind.wholeval=3
11.2.4.30 colrule.name
Specifies the XPath expression or hard-coded value that contains a column name. The column index must be specified if this is not and the column name will be resolved from that. If specified the column name will be verified against the source definitions file. Any XPath expression must end with a value accessor such as @att or text().
colrule.name={xpath_expression|"value"}
For example:
dyncolrule.name=@name
statkeycolrule.name="keycol"
11.2.4.31 colrule.index
Specifies the XPath expression or hard-coded value that contains a column index. If not specified then the column name must be specified and the column index will be resolved from that. If specified the column index will be verified against the source definitions file. Any XPath expression must end with a value accessor such as @att or text().
colrule.index={xpath_expression|"value"}
For example:
dyncolrule.index=@index
statkeycolrule.index=1
11.2.4.32 colrule.value
Specifies the XPath expression or hard-coded value that contains a column value. Any XPath expression must end with a value accessor such as @att or text(). If the XPath expression fails to return any data because a node or attribute does not exist, the column value will be deemed as null. To differentiate between null and missing values (for updates) the isnull and ismissing properties should be set. The value returned is used for delete before values, and update/insert after values.
colrule.value={xpath_expression|"value"}
For example:
statkeycolrule.value=./text()
11.2.4.33 colrule.isnull
Specifies the XPath expression used to discover if a column value is null. The XPath expression must end with a value accessor such as @att or text(). If the XPath expression returns any value, the column value is null. This is an optional property.
colrule.isnull=xpath_expression
For example:
dyncolrule.isnull=@isnull
11.2.4.34 colrule.ismissing
Specifies the XPath expression used to discover if a column value is missing. The XPath expression must end with a value accessor such as @att or text(). If the XPath expression returns any value, then the column value is missing. This is an optional property.
colrule.ismissing=xpath_expression
For example:
dyncolrule.ismissing=./missing
11.2.4.35 colrule.before.value
Overrides colrule.value to specifically say how to obtain before values used for updates or deletes. This has the same format as colrule.value. This is an optional property.
For example:
dyncolrule.before.value=./beforevalue/text()
11.2.4.36 colrule.before.isnull
Overrides colrule.isnull to specifically say how to determine if a before value is null for updates or deletes. This has the same format as colrule.isnull. This is an optional property.
For example:
dyncolrule.before.isnull=./beforevalue/@isnull
11.2.4.37 colrule.before.ismissing
Overrides colrule.ismissing to specifically say how to determine if a before value is missing for updates or deletes. This has the same format as colrule.ismissing. This is an optional property.
For example:
dyncolrule.before.ismissing=./beforevalue/missing
11.2.4.38 colrule.after.value
Overrides colrule.value to specifically say how to obtain after values used for updates or deletes. This has the same format as colrule.value. This is an optional property.
For example:
dyncolrule.after.value=./aftervalue/text()
11.2.4.39 colrule.after.isnull
Overrides colrule.isnull to specifically say how to determine if an after value is null for updates or deletes. This has the same format as colrule.isnull. This is an optional property.
For example:
dyncolrule.after.isnull=./aftervalue/@isnull
11.2.4.40 colrule.after.ismissing
Overrides colrule.ismissing to specifically say how to determine if an after value is missing for updates or deletes. This has the same format as colrule.ismissing. This is an optional property.
For example:
dyncolrule.after.ismissing=./aftervalue/missing
