Skip Headers
Oracle® Database Backup and Recovery Reference
11g Release 2 (11.2)
E10643-07
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
A Deprecated RMAN Syntax
This appendix describes Recovery Manager syntax that is deprecated and describes preferred syntax if any exists.
Deprecated RMAN syntax continues to be supported in subsequent releases for backward compatibility. For example, the SET AUXNAME command replaced the SET CLONENAME command in Oracle8i, and the CONFIGURE AUXNAME command replaced the SET AUXNAME command in Oracle9i. However, you can continue to run both SET CLONENAME and SET AUXNAME in all subsequent RMAN releases.
Table A-1 Deprecated RMAN Syntax
Deprecated in Release Deprecated Syntax Preferred Current Syntax
11.2.0
CONFIGURE or SET COMPRESSION ALGORITHM 'ZLIB'
CONFIGURE or SET COMPRESSION ALGORITHM 'MEDIUM'
11.2.0
CONFIGURE or SET COMPRESSION ALGORITHM 'BZIP2'
CONFIGURE or SET COMPRESSION ALGORITHM 'BASIC'
11.2.0
V$FLASH_RECOVERY_AREA_USAGE
V$RECOVERY_AREA_USAGE
11.1.0
CONVERT ON TARGET PLATFORM
CONVERT ON DESTINATION PLATFORM
11.1.0
UNTIL RESTORE POINT
TO RESTORE POINT
11.1.0
BACKUP ... AS STANDBY
n/a
11.1.0
... KEEP [LOGS | NOLOGS]
... KEEP
11.1.0
BLOCKRECOVER
RECOVER
10.0.1
BACKUP ... INCREMENTAL LEVEL [2,3,4]
Levels other than 0 and 1 are deprecated.
10.0.1
BACKUP ... PARMS
CONFIGURE CHANNEL ... PARMS
10.0.1
COPY
BACKUP AS COPY
10.0.1
CREATE CATALOG TABLESPACE
CREATE CATALOG
10.0.1
LIST ... BY BACKUP [SUMMARY]
n/a
10.0.1
LIST ... VERBOSE
n/a
10.0.1
RESTORE ... PARMS
10.0.1
SEND ... PARMS
9.2
REPLICATE
RESTORE CONTROLFILE FROM ...
9.2
SET AUTOLOCATE
Enabled by default
9.0.1
ALLOCATE CHANNEL FOR DELETE
n/a
9.0.1
ALLOCATE CHANNEL ... TYPE
CONFIGURE CHANNEL ... DEVICE TYPE
9.0.1
ALLOCATE CHANNEL ... KBYTES
CONFIGURE CHANNEL ... MAXPIECESIZE
9.0.1
ALLOCATE CHANNEL ... READRATE
CONFIGURE CHANNEL ... RATE
9.0.1
... ARCHIVELOG ... LOGSEQ
... ARCHIVELOG ... SEQUENCE
9.0.1
BACKUP ... SETSIZE
BACKUP ... MAXSETSIZE
9.0.1
CHANGE ... CROSSCHECK
CROSSCHECK
9.0.1
CHANGE ... DELETE
DELETE
9.0.1
REPORT ... AT LOGSEQ
REPORT ... AT SEQUENCE
9.0.1
SET AUXNAME
CONFIGURE AUXNAME
9.0.1
SET DUPLEX
SET BACKUP COPIES
CONFIGURE BACKUP COPIES
9.0.1
SET LIMIT CHANNEL ...
9.0.1
SET SNAPSHOT
CONFIGURE SNAPSHOT
9.0.1
UNTIL LOGSEQ (see untilClause)
UNTIL SEQUENCE (see untilClause)
8.1.7
CONFIGURE COMPATIBLE
n/a
8.1.5
ALLOCATE CHANNEL CLONE
CONFIGURE AUXILIARY CHANNEL
8.1.5
CHANGE ... VALIDATE
CROSSCHECK
8.1.5
CLONE (see RMAN)
AUXILIARY (see RMAN)
8.1.5
CONFIGURE CLONE
CONFIGURE AUXILIARY
8.1.5
MSGLOG (see RMAN)
LOG (see RMAN)
8.1.5
RCVCAT (see RMAN)
CATALOG (see RMAN)
