| Oracle® Functional Testing OpenScript Programmer's Reference Release 13.3.0.1 E37832-12 |
![]() Previous |
![]() Next |
This chapter provides a complete listing and reference for the methods in the OpenScript EnterpriseOneService Class of EnterpriseOne Module Application Programming Interface (API).
The following section provides an alphabetical listing of the methods in the OpenScript EnterpriseOneService API.
The following table lists the EnterpriseOneService API methods in alphabetical order.
Table 17-1 List of EnterpriseOneService Methods
| Method | Description |
Identifies an EnterpriseOne Grid Control by its recorded ID and path. |
The following sections provide detailed reference information for each method and enum in the EnterpriseOneService Class of EnterpriseOne Module Application Programming Interface.
Format
The eone.grid method has the following command format(s):
eone.grid(path);
eone.grid(recId, path);
Command Parameters
a String specifying the object path.
the ID of a previously recorded navigation, used for comparison purposes.
Throws
represents an exception that may be thrown during the execution of a script where the exception should be reported to an end user through the controller.
Example
Performs an action on an EOneGrid object specified by its recorded ID and path.
eone.grid(11,
"/web:window[@index='0' or @title='Work With Leave Verification Rules']" +
"/web:document[@index='7' or @name='e1menuAppIframe']" +
"/web:EOneGrid[@gridId='0_1' or @gridName='Work With Leave Verification Rules']")
.selectRow(3);
